Old 03-29-2012, 06:12 AM   #1
Lucky Dog's Avatar
2014 25' FB Flying Cloud
Down the Shore , New Jersey
Gatlinburg to Cherokee on Rt 441
At the end of April we are looking to travel from Gatlinburg, TN thru the Smokies to Cherokee, NC using Rt. 441. Looked at various maps and it appears to be a "principal, undivided" road but can't tell if it is single or dual lane. Also appears to be "closed to commercial traffic" which I figure is no 18 wheelers, which is probably not a good sign. Looks like a lot of swirchbacks, etc. Any body have any experience pulling their AS thru there? Our TV (Silverado Duramax) is up to the task, but not sure I'm looking forward to a 6 hour white knuckle tour. Would appreciate any feedback. Thanks
Rich
Rich
WBCCI #1512
2014 25FB Flying Cloud
2006 Chevy Silverado 2500 Duramax/Allison
Lucky Dog is offline   Reply With Quote
Old 03-29-2012, 06:52 AM   #2
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
You can trace every yard of the route on Google Streetview. Not towed up through there but drove it last year; good road but a long way up and a long way down the other side.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 03-29-2012, 07:03 AM   #3
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
That road is one of the most spectacular roads I have ever driven on! I'd suggest that you be certain that the TV is up to the task and is not marginal in any way ....
Bruce
Bruce B is offline   Reply With Quote
Old 03-29-2012, 07:28 AM   #4
twobikes's Avatar
1997 25' Safari
Montgomery , Alabama
It's a pretty drive, not a great adventure. It's 45 MPH, very smooth two lane, climbs to some spectacular vistas only a few of which you will be able to pull the trailer into unless you drive over early in the morning. Your real white knuckle adventure will be in Gatlinburg. Once over Newfound Gap, just gear down and enjoy until you bottom out at Smokemont Campground. If you are planning to continue on the Blue Ridge Parkway, check the Park roads number or the website: they had a couple pieces closed yesterday.
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at http://airgo.blogspot.com
twobikes is offline   Reply With Quote
Old 03-29-2012, 09:22 AM   #5
Lucky Dog's Avatar
Thanks for the responses. I appreciate it. We'll do a little more homework.
Rich
Rich
WBCCI #1512
Old 03-29-2012, 09:32 AM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Have pulled it a couple of times. good road. well paved and maintained. steep, long grades, and some tight curves. No commercial is because it is in a park that does not need extra traffic. Look foward to it instead of fearing it. It is good to check your route in this area of the country. There are some other roads in the TN-NC region in this area that you do want to stay away from.
Old 03-29-2012, 02:30 PM   #7
Lucky Dog's Avatar
Thanks Bill M, I appreciate the info and the encouragement.
Rich
WBCCI #1512
Old 03-29-2012, 02:54 PM   #8
Gainesville , Florida
Smokey mt national park is what the road goes through. If you get a ticket it is probably a federal one. jim
Old 04-03-2012, 05:14 AM   #9
JFScheck's Avatar
Rockville , Maryland
Images: 33
I don't know - catch another trailer coming up the opposite direction and it could be a close call - one or the other move towards center line and it could be a bit of a scrape - this ain't Nascar - so no rubbing allowed...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-03-2012, 05:43 AM   #10
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
It is no problem. Last time i was through there it had just reopened after an April snow and that got touchy at one or two spots but normally a nice drive
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-03-2012, 10:17 AM   #11
Luckyducks's Avatar
2018 27' Flying Cloud
Panama City Beach , Florida
I've driven from Cherokee to Gatlinburg (and vice versa) a number of times without my trailer but I'll be doing the drive this summer with my 25' trailer. I've seen a lot of other RVs on this road - just go slow and use your lower gears to help brake. I've researched the web on this subject and found the following info:
1. The drive is 31 miles or 55 minutes (per mapquest)
2. The steepest grade on the road is 5%
3. The speed limit is mostly 35 mph
4. Their are a quite a few pull offs if you want to take a break or catch the views.
Russ
Russ and Linda
2018 Flying Cloud 27'
2012 F250 Powerstroke 6.7
AIR#24440 WBCCI#11740
Luckyducks is offline   Reply With Quote
Question on 2nd /AC or generator input mefly2 Electrical - Systems, Generators, Batteries & Solar 9 06-18-2012 08:04 AM
New AS Owner Needing Advice on Weight Distribution Hitch BigGrey Towing, Tow Vehicles & Hitches 21 04-13-2012 08:35 AM
12 volt TV looking to buy Lothlorian Electronics & Connectivity 47 03-28-2012 09:10 PM
