Old 08-02-2013, 07:37 PM   #1
TCA and GPO's Avatar
2013 27' FB International
2016 28' Land Yacht
Baton Rouge , Louisiana
Gas for generator
We have a new Honda EU3000is generator.
As my husband GPO (great and powerful Obiwan) would say-" Quiet it is".
My question: there is a gas station in town selling ethanol free gas. Other stations indicate their gas may contain up to 10% ethanol. Will the generator run better on the ethanol free gas?
Thanks!
TCA and GPO is offline   Reply With Quote
Old 08-02-2013, 07:44 PM   #2
JFScheck's Avatar
Rockville , Maryland
Images: 33
You won't see any negligible difference...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 08-02-2013, 07:44 PM   #3
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
It will have more power with 100% gasoline. Ethanol has less BTUs per unit of measure than gasoline. Your owners manual should give you guidance how much ethanol can be used before voiding the warranty.
Old 08-02-2013, 08:18 PM   #4
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
If you can get ethanol-free gas for your generator, do it. Running fresh ethanol/gas blends in your generator will not harm it, however...ethanol is an alcohol and alcohol has a natural affinity to attract and absorb water. Since water and petroleum don't mix, over time this can contribute to octane loss and phase separation which is a contamination of the fuel. This contaminated fuel should not be used. In your automobile, we burn through fuel at a faster rate so it is not so much an issue. Generators, and other gas power tools tend to be used sporadically and when the fuel sits it them it will eventually become a problem. Honda generators are particularly sensitive to old fuel, and can readily develop fuel related carburation problems.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 08-02-2013, 08:40 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The easiest solution is, always make sure the tank and carburetor bowl are empty when you store your generator. In other words, run it completely out of fuel when you're done with it. No fuel means nothing to phase separate, nothing to absorb water.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-02-2013, 08:40 PM   #6
2016 28' Land Yacht
Thanks for the posts and great info from CA Streamer. We're going ethanol free whenever we can!
Old 08-02-2013, 08:47 PM   #7
1974 Argosy 20
Kooskia , Idaho
I have a Honda 1000 and a 3000 generator. I always use ethanol free gas in both, as well as all of my other small engines such as my mower and my ATV's. It has improved the operation of every one and there is far less maintenance. I think it makes a real difference in carburetor engines, but not much difference in fuel injected ones, such as full sized recent cars.
Old 08-02-2013, 08:56 PM   #8
2016 28' Land Yacht
My intuition told me that the pure gas must be better...so it is terrific to have some science to support that assumption!
We are in hurricane season down here in Louisiana so properly functioning generators are pretty important. Will take Protagonist's advice about storing the generator empty and will store up some of the good stuff.
It's great to get such knowledgeable feedback so quickly. Love the forum.
Tin Cannie Annie
WBCCI # 7100 ( we like MMMMMMMC)
Old 08-02-2013, 09:41 PM   #9
TinShack's Avatar
2005 28' Safari S/O
This solution is certainly a second best case scenario, and one I use since I don't have ethanol free fuel available to me. This approach means I have to empty the generator tank of fuel which is not easy to do, then start and run the gen until it quits. I don't want to do this all the time, and quite frankly, I forget to do it. However, since petroleum fuel deteriorates very slowly over time, IMHO it is much easier to use it, and not have to worry about about dumping the existing ethanol mixed fuel.
Steve
Old 08-02-2013, 09:55 PM   #10
However, since petroleum fuel does not deteriorate over time, IMHO it is much easier to use it, and not have to worry about about dumping the existing ethanol mixed fuel.
No argument there. But not everyone has access to ethanol-free gasoline. Ethanol-free fuel does degrade over timeó but it takes a couple of years, not months, so for most people it doesn't make a difference.
If the generator (or lawn mower, or whatever small carburated engine) is going to be stored for less than two months, it's probably okay to store it even with ethanol fuel in it; a rule of thumb is the e-fuel is only good for about three months from the date of purchase. Maybe less in really humid climates like the Gulf Coast where phase separation happens more quickly.
WBCCI #1105
TAC LA-4
Old 08-03-2013, 08:00 AM   #11
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Gasoline of either flavor will deteriorate over time. That's why it's a good idea to add Stabilizer.
Ahab is offline   Reply With Quote
Old 08-03-2013, 08:09 AM   #12
switz's Avatar
2014 31' Classic
Images: 8
Second the use of fuel stabilizer additive. It is inexpensive enough to use it all the time, just in case. The power can go out on a random interval schedule, so if your gasoline is treated and is usable, you are ahead of the game.
Old 08-03-2013, 08:28 AM   #13
panheaddale's Avatar
1964 26' Overlander
1968 30' Sovereign
somewhere , Tennessee
Why not convert to propane on your generator, No more hauling around gas cans or fuel stabilizers, or draining gas tanks. Burns cleaner, leas engine wear. Do a google search for propame conversions and there will be a lot of interesting reading. One company is Generator Conversion Kits to Propane and Natural Gas.. I am not associated with this company in any way.
panheaddale is offline   Reply With Quote
Old 08-03-2013, 08:31 AM   #14
Images: 59
For all my small engines, I use non-oxygenated fuel and add polyetheramine (Techron). I close the fuel valve and run the carburetor dry if I don't plan to use it within 3 months. I used to add Stabil stabilizer, but it got to be just too many things to do.
