Old 06-11-2014, 03:08 PM   #99
2016 30' Classic
Erie , Colorado
What goes up must come down. Very nice with a diesel, at least on the GM Duramax if equipped, is using the engine exhaust brake in conjunction with the transmission to control the speed.
Biggest difference I've seen in my mountain driving (Colorado) gas vs diesel is uphill and even on the flats being in 5th gear most of the time on the flats and lower gears on the hills. Pulled fine, usually at 55mph on most grades. Diesel most of the time even on some hills is in 6th gear.
Downhill big difference. Tow haul on the gas helps but it is relying on the transmission for speed control. Diesel exhaust brake relies more on engine braking.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 06-11-2014, 03:44 PM   #100
SteveH's Avatar
Common Sense , Texas
My Dodge has the engine brake, and you will probably get different opinions on how it should be used. I engage mine any time I am towing in hilly terrain, but it does not apply the trailer brakes. They work normally either when you step on the brakes, or operate the lever. The engine brake simply makes the truck decelerate more when you remove pressure from the accelerator peddle.
Regards,
Steve
Old 06-11-2014, 03:57 PM   #101
2016 30' Classic
Erie , Colorado
While towing I just leave mine turned on. Helps during any deceleration like an off ramp. Would be a big help in an immediate braking situation. Maybe someone know if there are any down sides.
Gary
2015 Classic
ProPride
NVPN
Old 06-11-2014, 03:59 PM   #102
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I also have the exhaust brake function in my 2011 Silverado. It's one of the nicest features of the diesel genre. Mine works in conjunction with the Allison Transmission. It really makes me more confident on long significant downgrades. I no longer get that "runaway train" feeling that I would sometimes experience on a long downhill with the Suburbans.
Brian
SuEllyn & Brian McCabe
Old 06-11-2014, 04:01 PM   #103
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Originally Posted by AnnArborBob View Post
My new 2015 F-250 Diesel has an engine braking button on the dash. I'm pleased to know it's there and I know how it works and what it does but really don't know how or when to use it while towing. Also, if I use it, how will the trailer brakes get engaged so they can do their job?
Bob, the goal is to not use the truck and trailer brakes for long hill descents. You use those brakes to rapidly decrease speed, but the goal is to use the engine brake to hold a safe speed without heating up or otherwise wearing out your wheel brakes. An engine exhaust brake completely negates the need for disc brakes on a trailer in my opinion, but that is different thread topic to troll the truck/car/gas/diesel/hitch debate teams.
The NSA -- The only part of the government that listens.
newroswell is offline   Reply With Quote
Old 06-11-2014, 08:30 PM   #104
moosetags's Avatar
I had a very interesting, but rather disappointing, conversation with a salesman at the Ford Dealership in Fort Walton Beach, Florida today. Based upon Pappy19's information, I priced a 2015 F-350 6.2 gas, crew cab, long bed, SRW on the Ford Website.
Within a couple of hours of pricing this truck, I received a call from one of the sales staff at the Fort Walton Beach Ford Dealer. We talked for quite a while, and I was satisfied that this guy knew what he was talking about.
I explained my needs to him in great detail, and he told me that he did not think that I would not be satisfied with the 6.2 gasoline engine, and highly recommended that I go with a diesel engined truck. He did not think that the 6.2 could adequately handle my needs.
This interchange has thrown me back to the diesel side.
Brian
Old 06-11-2014, 10:13 PM   #105
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I used the engine braking and gear down shifting in my 2007 Mercedes ML 320 CDI diesel and drove the mountains out West. I got 105,000 miles out of the first set of brake pads.
Towing now with with much more weight with a Cummins diesel power Dodge, the engine brake allows me to descend with no need for the truck brakes to be applied. The engine brake coupled with disc brakes on the trailer and truck can make very impressive quick stops.
The diesel engine brake should be standard equipment for every diesel engine powered vehicle manufacturer just for the safety factor.
For me, the big secret is the published speed limits on the side of the road for descents. Doing that speed with just using the engine brake is possible, but going faster than posted just makes handling more dicey and the use of all the brakes is much more likely generating more wear and tear then necessary.
Old 06-11-2014, 10:17 PM   #106
Chief Chili Cook
newroswell's Avatar
Brian, you seem to have be the best of both worlds.
Originally Posted by moosetags View Post
I am currently using two different two vehicles for my Airstream. One is a 2005 GMC Yukon XL 2500, four wheel drive, Quadrasteer, powered by the 6.0 liter gasoline V8. Our other tow vehicle is a 2011 Chevrolet Silverado 3500 Duramax four wheel drive.
On our shorter flat country trips, we tow with the Suburban. On the cross country jaunts, we use the Duramax.
What deficiency in your tow vehicle fleet has you shopping for a new vehicle?
Old 06-12-2014, 07:05 AM   #107
moosetags's Avatar
I'm not actually shopping yet, just doing some preliminary exploration. My 3/4 ton Suburban is approaching 10 years in age and 150,000 miles. We are trying to decide what to do when Olivia needs to be retired. Her running gear still works great, but her interior and accessories are wearing out.
We had been thinking that a second diesel would be in order as were were really impressed with our Duramax's towing and stopping capabilities. The dependability problems with the diesel DEF system on our Duramax has us doing some rethinking.
Regardless of some of the comments in this thread, I have pretty much decided that going to a gasoline-powered one ton to handle our truck camper/Airstream combination would not be a good idea. I am hopeful that Ford, GM, and Dodge will come up with a fix for their DEF systems.
Brian
Old 06-12-2014, 07:32 AM   #108
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
As a daily driver in a urban/suburban situation, diesels are generally too large to be practical. Half tons are somewhat more svelte. I'll stick with the V6 ecoboost as a decent compromise. Speed limit in California towing is 55 so powering uphill at 75 is a mute point anyway.
kscherzi is offline   Reply With Quote
Old 06-12-2014, 07:53 AM   #109
1987 25' Sovereign
Oregon , Ohio
In the movie CARS the statement was made that years ago that people hit the road to "have a good time, not to make good time". Is not Airstreaming about having a safe relaxing GOOD time. So what if a tow vehicle can not pull a grade at 70 mph or more, isn't the idea to get to the other side of that grade and see what is there????
msmcv51 is offline   Reply With Quote
Old 06-12-2014, 10:23 AM   #110
2012 30' Classic
Homosassa , Florida
I am very pleased with my 15 Silverado Duramax 2WD. My overall mileage at 6,000 miles is 16.7. It's quieter than the gasser I had, but in fairness it had dual exhaust with an aftermarket muffler. I loved the 5.3 gasser but pulling the 30' Classic through the Smokies just wasn't much fun and at 103,000 miles I just hoped something wouldn't pop. I appreciate the heavier drive train and the diesel torque. Most importantly, my wife is completely comfortable driving the HD Silverado. If I still had the 25' I would have stayed with a new 5.3 but for us we are happy with the choice we made. Fortunately, we don't all like the same thing because that would really be boring. Bottom line, get what will do the job you anticipate will meet your needs over the period you will have the vehicle and remember if you buy something that meets the minimum you can't haul bigger. If you go bigger, you can always haul smaller.
Sent from my SCH-I545 using Airstream Forums mobile app
Tater is offline   Reply With Quote
Old 06-12-2014, 10:40 AM   #111
Gainesville , Florida
My one ton dodge is the same size as a half ton. Short bed crew cab single rear wheels. Not four wheel drive. It is a Cummins. The misconception that a 2500 or 3500 is larger than a half ton is dependent on the particular vehicles. Jim
Old 06-12-2014, 12:00 PM   #112
moosetags's Avatar
That's true. My Silverado one ton crew cab, long bed is exactly the same dimensions as a Silverado half ton crew cab, long bed.
Brian
What fitting for GAS on Atwood gas/elec WH rlindberg Water Heaters, Filters & Pumps 1 04-09-2010 11:29 PM
3/4 Ton Test Drives (8.1L Sub Gas, Exc Diesel, F250 Diesel) big_john Tow Vehicles 7 02-21-2010 12:02 PM
Need pictures of gas line for Magic Chief oven gas connection dghaas General Repair Forum 1 01-30-2009 09:04 PM
Gas or No Gas, that's the question... oldtrucksrul LP Gas, Piping, Tanks & Regulators 14 11-16-2008 10:29 AM
Locking Gas Cap for 2003 AS Gas Motorhome spat61 Land Yacht/Legacy Motorhomes 11 10-27-2008 11:37 AM
