04-15-2016, 01:24 PM
2015 23' Flying Cloud
Plainville
, Connecticut
Garden State Parkway - NJ - Need Advice
Hi All,
I know you can pull a trailer on the GSP, but was wondering if there was a better route. We're heading from New England to Cape May, and really want to avoid NYC. We're planning to come across I-84 to I-684, and then across the Tappan Zee Bridge to the GSP. If you have experience on these roads, especially the GSP, we would be very interested to hear your advice. Thanks!
04-15-2016, 02:29 PM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
You can take the Turnpike to Exit 7 and then go down to 206 South. 206 in that area shouldn't be too bad.
Ultimately, I think the GSP is your best bet. The road itself is fine but the lanes are a bit narrow (particularly in the Oranges). If you are really concerned pick your time of day wisely. Rush hour anywhere north of Woodbridge could be problematic. As will anything south of Woodbridge on a Friday/Saturday when people go down the shore. Particularly as the weather starts to get nicer.
@living.somewhere.yonder | Instagram
04-15-2016, 02:32 PM
Princeton
, New Jersey
As a local I might use some shortcuts but in your case I suggest you just bite the bullet and use the GSP.
Just try not to use it during commuter hours. South bound in the am on the upper half or north bound on a Sunday evening.
2004 Excursion 4x4
04-15-2016, 03:54 PM
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
Hi Scott. We travel your route quite a lot. I have used the GSP but personally I avoid doing so and recommend you also avoid it. When I head to New England from Central NJ I use RT. 287 to the New York Thruway then cross the Tappan Zee Bridge. You can easily just do the reverse. Lately the bridge is under a great deal of construction so if your research tells you of heavy delays think about using 84 to cross Ct. into NY then hit the NY Thruway. Tolls have gotten pretty steep especially when towing but I probably would bite the bullet and take HowiE's advice and use the NJ Turnpike south from 287 ( Exit 10) to Rt. 206 ( Exit 7). There are other routes that we locals would probably use but that's the easiest way to tell a "foreigner".
It's not a bad ride but beware, you never know.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
04-15-2016, 04:13 PM
Sag Harbor
, New York
Originally Posted by Scott-Andrea
Hi All,
That is route I would take if Cape May is your final destination. If you are heading further south via the ferry to Lewes MD, I would recommend something else depending on how far south you are going.
Definitely avoid rush hour, and be prepared for really fast drivers in NJ on the GSP where the speed limit goes up to 75 MPH as I recall, and that is considered a minimum by many . . . [IMO]
04-16-2016, 10:54 AM
2014 Interstate Ext. Coach
melrose
, Massachusetts
Always
We drive an as interstate and now tow a Mini Cooper behind it from Boston area. We always use the tappen zee and garden state when headed south
04-16-2016, 11:22 AM
2015 27' FB International
mesquite
If it was me' i would take I-84 straight across to pa.&pickup I-8 south! May be out of your way but lot better road. Why put up with all that Hassel?
Suggest you get a trucker road atlas andcheck out the routes available to you.
I live in Dallas and original from n.England. been there and done your rt.and wouldn't do it again that way!
04-16-2016, 12:39 PM
Sag Harbor
, New York
To get to Cape May, New Jersey?
04-16-2016, 12:55 PM
Princeton
, New Jersey
A slight misunderstanding as to where you want to go.
I think he meant I 81 south to go to Texas not Cape May NJ
It all hinges on when you are going to be crossing NJ. The GSP can be a 2 1/2 drive top to bottom or it can be a 5 hour drive during summer weekends. Plan the timing.
2004 Excursion 4x4
04-16-2016, 01:19 PM
2002 25' Safari
1977 20' Argosy 20
northern valley
, new jersey
Alternate route
You really want to avoid the GSP through Essex and Union counties at rush hour.
That, nearly as badly as you want to stay off I95 south and westbound across the Bronx and Manhattan, at almost any time of day, and most nights, too!
It's a 40 mph, but mostly scenic route, by taking Route 9W south from the TZB to Fort Lee, NJ (home to the western side of the GWB.). The last two or three miles into Fort Lee is suburban office / business / commercial, but doable.
In Fort Lee, you can jump onto I80 west / I95 south, down to Exit 11 from the NJ Turnpike where you cross over to the GSP at Exit 129. Cape May is Exit 1.
We have lived here for a very long time, and we've towed throughout this entire metropolitan NY NJ area. PM or email me and I'll write up the details for you.
Ymmv!
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
https://defendwally.org/
04-16-2016, 08:29 PM
Plainville
, Connecticut
Thank you all for the responses! Local experience is always best!
To clear up any confusion, we are trying to plan a trip to Cape May, NJ. We have decided to run down I-95 to Rt. 206. It's a longer trip, but we think it will be easier on the nerves. I'll update this thread when we return.
04-17-2016, 12:39 PM
Curtis Wright
Eyren Haven
, South Jersey
206. That is a odd way to Cape May. If you get the GSP early in the morning, heading south will be as easy as any route. 206 can be difficult any time of the day. So much of it is 2 lane with much truck traffic. But Atsion is nice to visit, and Pick-a-Lilly is good for lunch. But if I made the choice it would be GSP. It is not easy to get south of Hammonton on the 206 route.
04-17-2016, 12:53 PM
Curtis Wright
Eyren Haven
, South Jersey
Sorry. I should have offered my help if you come down 206. I am located a bit east on 30. I can help with local roads. 206 south across 30 to 54 south, AC Expressway east to GSP south. Unless you like places to stop and enjoy the garden part of the Garden State.
04-17-2016, 12:54 PM
2014 25' FB International
Orleans
, Massachusetts
We are from Cape Cod and do this route all the time. I-84 to the Fish Kill bridge, to Newbergh, NY. We avoid I-684 like the plague as it was so rough! It's not that much further on this route and your camper will thank you. From Newbergh get on I-87 South and then follow signs to the GSP. On your return the toll is much less than the Tappan Zee also! Good luck.
04-17-2016, 04:33 PM
1976 25' Tradewind
Kimberton
, Pennsylvania
Rout 206 through the Pine Barrens
You noted that you’ll be traveling along Rt 206 from Exit 7 of the turnpike. About 40 minutes south of the turnpike you’ll enter the Pine Barrens and pass next to Atsion Lake the headwater for the Mullica River. There are a number of nice public and private campgrounds in the area. If you have the time to explore the area and the restored iron ore town of Batsto NJ you’ll have some fun. Here’s a website from Mick’s Canoe the foremost canoe/kayak rental in the Pine Barrens. His site is more direct and informative for this area than most info on the web. http://www.mickscanoerental.com/camp.html
04-17-2016, 04:35 PM
1976 25' Tradewind
Kimberton
, Pennsylvania
Taking Rt 206 through South Jersey
