Old 04-18-2011, 10:36 AM   #1
Smoky's Avatar
Eau Claire , Wisconsin
Images: 8
Fridge stopped working after tire blowout
I experienced my first tire blow out on my trailer which resulted in a lot of shaking and jostling inside the trailer. There was no major damage but my refrigerator is not cooling now. What could have happened? It's a newer electric one...should I try turning it upside down or is burping just for propane ones?
1961 Avion T-27
Smoky is offline   Reply With Quote
Old 04-18-2011, 10:38 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
When you say "newer electric" you mean it's a dual propane/electric? Or it's a compressor-based electric-only unit?
David
Old 04-18-2011, 10:46 AM   #3
Smoky's Avatar
Images: 8
I mean it is a compressor electric only unit.
1961 Avion T-27
Old 04-18-2011, 10:51 AM   #4
1977 Argosy 24
Milltown , Wisconsin
Does the light come on when you open the door? Just to check that it didn't come unplugged in the shaking.
ventport is offline   Reply With Quote
Old 04-18-2011, 10:55 AM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Can you hear the compressor run?
Bill
Just my personal opinion
Old 04-18-2011, 10:57 AM   #6
Smoky's Avatar
Images: 8
Yes the light comes on. I reached behind it and the big metal thing/compressor? feels hot.
1961 Avion T-27
Old 04-18-2011, 10:59 AM   #7
jackson center , Ohio
Have you tried it on 110? Have you checked the gas supply line under the trailer for damage?
Schu is offline   Reply With Quote
Old 04-18-2011, 11:04 AM   #8
Smoky's Avatar
Images: 8
Bill
It was making a hum sound but I just turned it off and back on via the internal temp adjuster and now I can't hear the hum.
1961 Avion T-27
Old 04-18-2011, 11:04 AM   #9
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
If the shaking was severe enough maybe you created a leak in the refrigerant lines somewhere. Find leak, fix and replace refrigerant.....Phil
pgr32e is offline   Reply With Quote
Old 04-18-2011, 11:05 AM   #10
Smoky's Avatar
Images: 8
It is just a regular electric, not a 12 volt or propane.
1961 Avion T-27
Old 04-18-2011, 11:06 AM   #11
Smoky's Avatar
Images: 8
Ok, I'll pull it out of the cabinet and take a closer look.
1961 Avion T-27
Old 04-18-2011, 11:08 AM   #12
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Smokey,
Do you have a household refrigerator or an RV DanFoss compressor unit?
If the former, perhaps the jolt was enough to break the unit.
Bill
Old 04-18-2011, 11:16 AM   #13
Smoky's Avatar
Images: 8
Smokey,
Bill
It's just a household fridge. These things can't be that complicated. Is there a relay I can test with a meter?...hmm as I was just typing this it kicked in and is now humming.
1961 Avion T-27
Old 04-18-2011, 11:42 AM   #14
1971 29' Ambassador
Leonardtown , Maryland
Look for a loose connector or a loose ground lug, Possible a dirty connector, Contacts can be cleaned with an eraser.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Tire alignment sawyerpoint Tires 4 06-29-2011 05:04 AM
Bias vs Radials, blowout, damage to trailer bmklawt Tires 1 04-15-2011 06:18 PM
License plate light not working worksology Lights - Interior & Exterior 7 04-08-2011 05:05 AM
wanting to sell my 1959 Norcold 2 way fridge cindy Refrigerators 4 02-26-2011 10:17 AM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
