Old 04-18-2011, 11:51 AM   #15
Smoky's Avatar
Eau Claire , Wisconsin
Images: 8
I just set it on it's back and a bunch of clear fluid spilled out...so I'm assuming I have a coolant leak somewhere. How does one repair that..is there some kind of epoxy?
1961 Avion T-27
Smoky is offline   Reply With Quote
Old 04-18-2011, 11:55 AM   #16
1977 Argosy 24
Milltown , Wisconsin
Silver solder the leak and recharge.
ventport is offline   Reply With Quote
Old 04-18-2011, 11:59 AM   #17
Smoky's Avatar
Images: 8
I do happen to have some silver based solder I use when I build guitar effect pedals...I hope that works. Now to locate the leak...
1961 Avion T-27
Old 04-18-2011, 12:20 PM   #18
1985 31' Excella
Fresno , Texas
Did you have it running on an inverter at the time of was if off for transit? If it was running and was bounced around it probably damaged the compressor. You could try a new starter capacitor but should probably just take it by an appliance service place and let them check it.
You might try to tap the compressor immediately after plugging it in. Male sure it has cooled down before doing this.
Wsmith is offline   Reply With Quote
Old 04-18-2011, 08:53 PM   #19
Smoky's Avatar
Images: 8
No it wasn't running on an inverter at the time. I think the compressor must have a leak since there was some clear oil that leaked from it. It just hums now and gets hot but does not cool the fridge. I bought some 134 coolant today but can't find a leak anywhere. I guess I'll just buy a new fridge.
1961 Avion T-27
Old 04-18-2011, 09:09 PM   #20
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Electric vs propane/electric refrigerator
I guess that's why "they say" that a home refrigerator isn't designed for the bumping and shaking that can happen to an RV model. The ammonia based propane/electric refrigerators are quite a bit more expensive, but have a lot fewer solder joints and bits and pieces to break. Many people do successfully use home reefers - but if there is a LOT of travel in your future you might want to get an RV model. It's not at all uncommon to find a 30 year old RV with the original reefer still working.
Paula
Old 04-18-2011, 09:18 PM   #21
Smoky's Avatar
Images: 8
Yes. Lesson learned. All the weak aspects of my setup are being exposed as I continue to travel. I'm gaining a lot of experience and learning though. My tire blowout was my fault because I wasn't diligent about checking my air pressure and overall tire condition.
1961 Avion T-27
Old 04-18-2011, 10:02 PM   #22
Smoky's Avatar
Images: 8
actually..I really hate giving up. So I inspected it some more and did find a crack in the copper tubing. I'm going to solder it now. anyone know how to recharge the compressor? I don't see a port.
1961 Avion T-27
Old 04-18-2011, 10:25 PM   #23
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Generally there isn't one when they come from the factory, even on full-sized fridges. When I had the compressor on mine in the house replaced under warranty, they brazed in a Schrader valve.
David
Old 04-18-2011, 11:13 PM   #24
Smoky's Avatar
Images: 8
Ok..then I officially give up. Its' a shame having to throw away a perfectly good fridge because of a small leak in a copper tube, but it's cheaper to buy a new one then to purchase the specialized tools needed for the repair.
1961 Avion T-27
Old 04-19-2011, 05:42 AM   #25
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Don't give up yet. Get one of these, and get a can of R134a and charging kit from your local auto parts store:1/4" Bullet Line Tap Valve For All Refrigerants Install on the High Side Line: American HVAC Parts
According to the label, it only takes a small amount of refrigerant, so you won't need the whole can. Probably more important is to figure out how much oil you lost, and replace that so the compressor doesn't burn up.
Old 04-19-2011, 11:16 PM   #26
Smoky's Avatar
Images: 8
I think I will have a go at fixing this. I'm pretty sure I'll need a vacuum device too. Is a propane torch hot enough for the silver solder? At any rate, this job will have to wait til I get back to home base. Thanks for all the ideas everyone.
1961 Avion T-27
Old 04-20-2011, 05:49 AM   #27
Well Preserved
1993 21' Sovereign
Yes, that's what I used "back in the day" when I was working with copper pipes.
Tire alignment sawyerpoint Tires 4 06-29-2011 05:04 AM
Bias vs Radials, blowout, damage to trailer bmklawt Tires 1 04-15-2011 06:18 PM
License plate light not working worksology Lights - Interior & Exterior 7 04-08-2011 05:05 AM
wanting to sell my 1959 Norcold 2 way fridge cindy Refrigerators 4 02-26-2011 10:17 AM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
