Old 07-08-2008, 05:09 PM   #1
2008 25' Safari FB SE
Grand Haven , Michigan
Fresh water tank fills when hook up to city water
Hi, we just picked up a 2008 Safari 25FB two weeks ago. When we hook up to city water, our fresh water tank fills to overflowing. Is there a by-pass valve that is open? Where should I look? Any help would be appreciated. Aren't Airstreams cool?
Jonah is offline   Reply With Quote
Old 07-08-2008, 05:24 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Water is back flowing through your pump. It has something stuck in it keeping the valves open or the valves have failed.
You will need a new pump. and a check valve after the pump so it does not see city water pressure would help.
Michelle TAC MT-0
Sarah, Snowball
Old 07-08-2008, 06:01 PM   #3
UpNorthAir's Avatar
1970 31' Sovereign
Horton Bay , Michigan
Here is a good diagram I came across a while ago. Maybe this will help you dissect the problem. I agree it sounds like a check valve problem.
Water, Water, Everywhere!
Good Luck
Joe
UpNorthAir is offline   Reply With Quote
Old 07-08-2008, 07:00 PM   #4
Dan@LED4RV's Avatar
Denton , North Carolina
Water pump
The water pump is suppose to, if installed correctly, also serve as a check valve. It keeps the water from flowing that direction.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 07-08-2008, 07:17 PM   #5
Over59's Avatar
Putnam , Connecticut
Images: 37
Call the dealer. Make a list of all the issues and take it in. The more you find the fewer your trips to the dealer to get everthing right.
Over59 is offline   Reply With Quote
Old 07-08-2008, 07:22 PM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question Hi wp
After it's repaired you might check your city w/press, and install a regulator. Have heard of high pressure causing a pump failure.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 07-08-2008, 07:36 PM   #7
_
hi jonah and welcome to the forums...
yep it's under warranty so the fix shouldn't cost more than the trip to the dealer...
construction debris can become stuck inside the pump and lead to this issue OR the back flow feature can fail...
lots of back flow failures on the model pump in question...
so many that i think a/s recently switched to a different model pump as oem...
here is another thread on the same issue, and the details may help u some...
http://www.airforums.com/forums/f443...h20-21678.html
cheers
2air'
Old 07-08-2008, 07:37 PM   #8
arm4's Avatar
Cazenovia , New York
Yes you are right...Streams are cool. I have an '08 25FB and also enjoy it . I did put a regulator on my city water and have not experienced water passing through the pump. I wish you many happy miles and great adventures. Randy Miller
arm4 is offline   Reply With Quote
Old 07-08-2008, 07:44 PM   #9
arm4's Avatar
Cowboy....
Just in case you wondered how long I have been taken by Airstreams.....I am the little cowboy in the middle of my avatar...some 50 years ago...my dad did all the early photography for Airstream and I still go back to some of the great locations...and relive wonderful times.....Randy
Old 07-08-2008, 08:32 PM   #10
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Welcome to the Forums, Jonah! Yes, Airstreams are cool...you'll find no argument on that here... Once your water issues are taken care of, it will be even cooler...
Glad you could join us AS Crazies.
TB & Greg and Abbey Schnauzer
#3954
Old 07-08-2008, 09:00 PM   #11
Ottawa , ON
Jonah, congratulations on your new investment and welcome to the Forum!
On anything with as many parts as an AS TT, I would expect to have a few items needing attention. Do a walk through with your family and make a list of everything you think isn't right, however small it seems.
Then, make a copy of the list and do the same walk through with your dealer's Customer Service person.
Maybe some of your items are things you just don't understand yet, but for sure you'll have some stuff needing attention. Your list will speed up getting them all attended to, and will be handy for you to follow up.
It's the start of your Maintenance Log! Mazel Tov and enjoy!
Old 07-09-2008, 06:07 AM   #12
Thank you everyone. It is also cool to have so many people care about each other.
Old 07-18-2008, 04:47 PM   #13
Master of Universe
Gene's Avatar
Grand Junction , Colorado
I thought the '08's (and maybe before) had a built in pressure regulator. There seems to be a vague reference to one in some materials that come with the trailer, though I can't remember where. I use a separate regulator since I'm not sure if there is a built-in one. And a regulator can fail though a good check valve on the pump should not let water pass through. Anyway, ask the dealer.
Gene
Old 09-23-2008, 10:34 PM   #14
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
Send a message via AIM to Airboss Send a message via MSN to Airboss Send a message via Yahoo to Airboss
Well my daughters 72 Safari did that so I installed a new pump.. Still does it.. Any ideas???
"If your not living life on the edge... Your taking up too much room. WANTED, Single lady who loves and has a Airstream. Please send photo of Airstream and Tow Vehicle
Operation "SAVE RUDY" Strike Team (Charter Member) RALPH, KW8G..WBCCI # 4201 Metro Detroit & 4CU TAC # MI-007
Airboss is offline   Reply With Quote
1971 overlander rear bath city water hook up durbin Fresh Water Systems 2 05-25-2008 07:29 PM
Ratio of Fresh Water/Grey Water Tank, Help! erikjware Waste Systems, Tanks & Totes 1 05-08-2008 10:42 AM
Early Model City Water Hook-up ga501 Fresh Water Systems 1 03-27-2006 07:59 PM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
'85-34ft Sovereign City Water Hook up E&T Stutts 1984 - 1989 Sovereign 1 10-31-2002 06:31 PM
