Old 09-27-2003, 10:36 AM   #1
frame replacement source
Has anyone ever tried to replace the aluminum channel that makes up the framework of roof? I am replacing rear curved panels on '61 and just realized that a piece of the channel is damaged from tree vs. roof incident. I would like to replace it with aluminum channel but it has a curve to it and looks like something custom made. Any ideas? Maybe someone has a parts Airstream that they would be willing to sell some pieces of?
I have all of the segments that form the curve for replacement, however while I'm going to all of this trouble I would like to find one more segment to install. If you are looking at the rear endcap and the middle piece is No. 1, I need the segment that is two over from that if you move in a clockwise position.
Thanks for any leads on the segment and channel.
cherring is offline   Reply With Quote
Old 09-27-2003, 11:21 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
How bad is the damage?
If it is just bent You could remove it and either straighten it yourself, of have a metal shop do it for you. If it is cracked/broken they could also MIG weld it for you.
The only way I know to get one of the ribs is a boneyard or someone with NOS. If you can find a section of rib that will span the damage in he current rib the manual says to rivet it on the back with a 6 inch overlap using bucked rivets. I would assume olympics would work.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 09-27-2003, 05:25 PM   #3
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
You might check with some fabrication shops or sign shops (that make big lighted signs) or makes big awnings for store fronts. The factory channel is a C channel but a fabrication shop that can handle bending box.
Steel place I use has a shop and they have a bender that could make a 20ft arch or a 10 inch arch. Then you could split it down the middle to make a c-channel and get what you need.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
Do you know of a source for replacement mattresses? Dave Jenkins General Interior Topics 15 03-08-2004 09:22 PM
Frame rust Ken J Repairing/Replacing Floor &/or Frame 5 07-13-2003 06:39 AM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
