Old 07-21-2016, 12:30 PM   #1
2018 30' International
Wilsonville , Oregon
Flying Cloud medicine cabinet door
We have a 2016, 25ft. Flying Cloud. I am tall and find the top hinged swing up medicine cabinet door awkward to use. Has anyone changed that type cabinet door to horizontal sliders? Was it difficult and do you like it better?
Wonder why Airstream uses that type of door instead of sliders?
zigz is offline   Reply With Quote
Old 07-21-2016, 01:16 PM   #2
2015 28' Flying Cloud
Newtown , Pennsylvania
Wow. What a great idea. I hate that door on a good day. After every trip, I grab a screwdriver and tighten the loose hinges. I have to hold it up with my head while I look for what I need.
Bruce
AstroBruce is offline   Reply With Quote
Old 07-21-2016, 01:29 PM   #3
abqdor's Avatar
2016 25' Flying Cloud
Albuquerque , New Mexico
That was one of the things that bothered us when we took possession of our Flying Cloud FB '25. I searched the forum and found that some people have put pneumatic lift hinges on the door to keep it open. There are also pictures of the install. Haven't done it yet, but it is on the project list.
2015 Flying Cloud 25FB - Page 7 - Airstream Forums
http://www.airforums.com/forums/.../...-125637-7.html
'17 Ford F-150 Ecoboost, max tow package
'13 GMC Yukon Denali 6.2L V8
'04 GMC Yukon SLT 5.3L V8
abqdor is offline   Reply With Quote
Old 07-21-2016, 05:36 PM   #4
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
I put a "boat hatch support" or something like that on our 27fb top-hinged med cab door in our Pete from West Marine. It's a spring rod maybe 20" long that mounts to the bottom corner of the cabinet doorframe and the bottom corner of the mirrored door.
When you open the top-hinged door, the spring "locks" open and the door stays there, no headaches. To close the door, lift the door slightly, bend the spring so it folds onto itself and whalaa. A little tricky to get mounted but once in it works great.
Hope this helps.
ShinyPete is offline   Reply With Quote
Old 07-21-2016, 05:47 PM   #5
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
I put "piano bench" hinge supports on the medicine cabinet door and the door over the fridge on our 2014 25fb and it solved all the issues. I got the idea from a previous thread on the same subject.
George
gandttimes is offline   Reply With Quote
Old 07-21-2016, 05:59 PM   #6
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Here's a short video of my solution. A simple pneumatic lifter. Two screws. Maybe 20 minutes to install.
https://youtu.be/IqY8Vyh13sY
kscherzi is offline   Reply With Quote
Old 07-21-2016, 07:05 PM   #7
2002 19' Bambi
Lafayette , California
Here is another solution: http://www.airforums.com/forums/f295...ml#post1821838.
Tim
Tim A. is offline   Reply With Quote
Old 07-22-2016, 11:39 AM   #8
2016 27' Flying Cloud
McDonough , Georgia
The cheap lightweight plastic latch on our very heavy mirrored medicine cabinet lift-up door broke on our first long trip in our 2016 FC 27 - found it hanging loose on the upper hinges when we checked things at a rest area. That mirror door is way too heavy for that application. Also, as has been said, it's inconvenient to actually get things out from the shelf while trying to hold door open. Husband took door and hinges off entirely for the rest of the trip.
So far I don't mind having just the open shelf up there - mostly miss the mirror (been propping a hand-held up on the shelf for now).
I had been thinking about a sliding mirror/door that would cover maybe half the space. Now we're thinking instead about simply putting up an acrylic mirror with glue or strong tape on the flat wall to the right of the sink just above all the switches and leaving the shelf open. Figure the acrylic won't break if it falls, it's lightweight, and can be cut to fit the space.
Still thinking of options...............
Kittycatcat is offline   Reply With Quote
Old 07-22-2016, 11:47 AM   #9
2015 25' FB Flying Cloud
Sandy , Utah
Great Idea! Where did you get them and what sizes did you use? Did you put one on both sides or just one?
rocco52 is offline   Reply With Quote
Old 07-22-2016, 12:50 PM   #10
Stowe , Vermont
Scherzi - great idea. Tim A - also a good idea. Hardware store here I come.
VT Wanderer is offline   Reply With Quote
Old 07-22-2016, 01:53 PM   #11
McDonough , Georgia
Kscherzi & Tim - like both of these! Now to show the resident handyman (aka spouse) & see which one he likes. Also much cheaper than new mirror.
Old 07-22-2016, 07:03 PM   #12
amaier7771's Avatar
2013 25' FB Flying Cloud
Colorado Springs , Colorado
I fixed that frustrating FC Medicine cabinet "lift up" door", and also the similar "up opening" door over the refrigerator by adding these simple "gas shocks". Now both doors stay fully up when wanted and still close and stay latched when traveling.
Apexstone 100N/22.5lb Gas Struts/Gas Springs/Gas Strut Lift Support/Gas Shocks Lift Lid,Set of 4
Worked well for us.
amaier7771 is offline   Reply With Quote
Old 07-23-2016, 10:32 AM   #13
BoscoMN's Avatar
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount , Minnesota
Here is what I did on our 2015 19' FC:
http://www.airforums.com/forums/f295...or-153833.html
BoscoMN is offline   Reply With Quote
Old 07-30-2016, 08:33 AM   #14
FishByFly's Avatar
2019 22' Sport
Fort Worth , Arkansas
Amaier7771, did you use two struts per door or is one each adequate?
FishByFly
because I catch fish on a fly...
2005 30' Safari Bunkhouse
2010 F250 Lariat
FishByFly
2017 25' Safari FB
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 07-30-2016, 08:49 AM   #15
aftermath's Avatar
Spokane , Washington
Here is another one of those "I am scratching my head" posts. I have a 2006 25 FB with the bathroom mirror that you describe. Mine came with, and still has, a metal piano lid support type of latch. I have never had trouble with it not staying up and I haven't had to use my head to keep it open.
The gas shocks do look like a sexy alternative and I will probably look into something similar for the little door above the fridge. I see where the complaints come from late model owners. Did they put in a "new and improved" version of this latch?
My wife has never liked the mirror because she has to always look up to use it. Of course when we looked inside the new Classic with that full wall mirror, she said this is what she wants.
aftermath is offline   Reply With Quote
Old 07-30-2016, 10:53 AM   #16
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Hi Aftermath, the new units with that mirror have nothing at all to hold the mirror in the up position - except your hand or head. Best, Joe
jayseejay is offline   Reply With Quote
Old 07-30-2016, 02:30 PM   #17
MomcatA's Avatar
Glendale , California
Thank you amaier7771! Purchased a set from Amazon- they're going into the trailer next week. Love the Forums- have a problem, just wait long enough and there will be a thread about it.
MomcatA is offline   Reply With Quote
Old 07-30-2016, 03:00 PM   #18
aftermath's Avatar
Wow, I find that quite unbelievable. I wouldn't be happy either. I guess $80K doesn't get you what it used to.
Thanks for the information.
Old 07-30-2016, 08:10 PM   #19
2009 19' Flying Cloud
Akron , Ohio
That I can attest to with my recent non upgrade in an AS trailer. Funny, I had the same complaint with my 19 ft., more than a few forehead bruises and fixture adjustments after a long day. My new 25 ft came with a small vanity swing out mirror. Way better as you can move it according to weather you are blow drying, plucking, or just admiring your attire for an awesome night in your Airstream. May be worth taking a look at on video and installing on the side if you can avoid having to get in the cabinet so much for stuff. Sometimes retail solutions are better, try "googling bathroom storage in an rv."
robi is offline   Reply With Quote
Old 07-30-2016, 09:24 PM   #20
duncans's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mount Angel , Oregon
The Flight of the Phoenix
All of this time I had thought that the lousy closure on the medicine cabinet door was due to the fire!
duncans is offline   Reply With Quote
Plastic medicine cabinet latches willbrackman General Interior Topics 6 05-08-2017 08:07 AM
Medicine Cabinet Replacement 36"x9" outbackbob 1999 Safari 2 07-25-2016 01:03 AM
Heavy mirror above medicine cabinet titleists Cabinets, Counter Tops & Furnishings 12 05-24-2013 10:26 AM
'81 Excella Center Bath Medicine Cabinet Latch perryg114 General Interior Topics 10 11-03-2011 12:38 PM
Medicine cabinet door won't stay closed jordandvm Cabinets, Counter Tops & Furnishings 10 10-03-2004 08:24 AM
