06-21-2015, 02:06 PM
Cincinnati
, Ohio
Florida
Do anyone know any routes to get to st Petersburg Florida from Cincinnati
The fastest
06-21-2015, 02:13 PM
I'm In
, Kentucky
The fastest
I-75 south, turn right at Tampa
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Mantua
, Ohio
Interstate 75 straight through to Tampa.
06-21-2015, 02:15 PM
Cincinnati
, Ohio
Will this cut a few hours I heard once u hit the diner an u make them right it cut a few hours
06-21-2015, 02:19 PM
Mantua
, Ohio
Huh?
06-21-2015, 02:20 PM
Cincinnati
, Ohio
Is this the fastest way I-75
06-21-2015, 02:21 PM
Mantua
, Ohio
Unless you fly!
Cincinnati
, Ohio
I was told I could get there 3 hours head of time
06-21-2015, 02:22 PM
Mantua
, Ohio
Google Cincinnati to st. Pete.
06-21-2015, 02:25 PM
Cincinnati
, Ohio
I did it said avoid the mountain an something about 6
Route 77
06-21-2015, 02:26 PM
1949 22' Liner
Cincinnati
, Ohio
The fastest route for driving from Cincinnati to St. Petersburg is I-75 south to about 15 miles north of Tampa, then take I-275 through Tampa to St. Petersburg. If you stay on I-75 you will instead bypass both of those cities, miles to the east.
06-21-2015, 02:29 PM
Cincinnati
, Ohio
Thanks how long for this way take
06-21-2015, 02:49 PM
Mantua
, Ohio
I 75 will take you there. Common sense and a map will get you the rest of the way. It's a big area, where in Tampa, st Pete do you want to go?
06-21-2015, 03:08 PM
Cincinnati
, Ohio
Clear water
06-21-2015, 04:50 PM
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo
I 175 over the Howard Frankland Bridge and take the 688 (Ulmerton ) exit and follow the signs to Clearwater.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
06-21-2015, 06:08 PM
1949 22' Liner
Cincinnati
, Ohio
Driving a van (not towing) I've gone from the Tampa airport to Cincinnati in just under 18 hours. That included about 3 hours of stops for food, gas, restroom, and miserable weather. I was doing around 70+ MPH the entire way (except in Kentucky).
The entire Kentucky portion was subject to a heavy snow storm that forced me to reduce speed. I also had to stop 2-3 times because the wiper blades needed to be cleared of ice some of the snow was sticking to them and refreezing, even with wipers at maximum and the heat/defrost settings on maximum. But that was in early March.
06-21-2015, 06:11 PM
1949 22' Liner
Cincinnati
, Ohio
>>ron<<
I think you mean I-275. I believe I-175 is spur off I-275 towards the old airport just southeast of downtown St. Petersburg.
06-22-2015, 03:50 AM
2011 30' Classic
1993 32' Excella
Largo
You are correct. I meant 275. Thanks for noticing.
>>ron<<
