Old 10-04-2015, 07:53 AM   #1
LakeState's Avatar
2006 25' Safari
Howell , Michigan
First trip as a Snowbird, Mi to Fl in January 2016
I'M confident that the AS is ready for the trip, the tow vehicle too. Now if I could just find those places along I 75 South to stop overnight. I have no issue getting to Kentucky just after crossing the Ohio river for my first day of travel.
De-Winterizing most likely wont happen till I'M in southern Georgia. A dump station would be perfect then. Gotta get above those freezing temps. If you have been this route before during the winter I would like to hear your stories and experiences regarding this snowbird flight.
Lake State
LakeState is offline   Reply With Quote
Old 10-04-2015, 08:20 AM   #2
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
We have been doing the snowbird thing for the last 16 winters - either Arizona, California, or Florida.
Maybe not for everyone, but here is the way we continue to do it ....
We try to get a really early start on day one - certainly on the road by 6am, (weather permitting.)
The purpose is to get as far south on day one as we can to get to as warm a spot as we can.
Typically we will drive until maybe 7 or 8 pm and waste as little time as possible en route.
I do some research in advance and look for Flying J truck stops along our planned route. I usually pick a few because even though one is a target, we never know for sure how far we will get - depending on developing rather situations, traffic tie ups, etc.
We then stop the first night at a Flying J. Initially I was a bit nervous about doing this as we had never done it before, and of course there are no guarantees, but so far we have not had the slightest issue at a Flying J.
Generally there is space to park the rig and FJ welcome it. The spots are separate from the 18 wheeler parking. The parking spots will not be too far from the pumps and so are well lit. Even though the lights are on all night and minimal traffic continues at the pumps, we are so whacked from the long drive that we never have trouble sleeping!
It will still be cold. Probably freezing or lower. We eat supper at the FJ and spend the evening in the trailer. I run the furnace during the evening and also overnight on our coach batteries - I disconnect the truck so as not to risk running the truck batteries down. I drop the thermostat temp to maybe 55F overnight. We have never had a problem doing this.
More recently, I started carrying a Honda gennie so we have all the power we need during the evening for tv, lots of heat, etc.
I lock the gennie to the trailer tongue - but once we retire for the night, I put it away in the truck and we run the furnace overnight on the coach batteries.
Staying overnight at the FJ and not unhooking the truck makes an early start in the AM easy. We grab a coffee from the FJ, have a quick breakfast in the trailer, fill up the truck and get on the road by maybe 7am or so.
Overnight, if we need to use the toilet (to pee!) we use the trailer toilet and flush with antifreeze since the trailer is still winterized.
Our planned distance for day two will be a lot less and we plan to stop mid to late afternoon at a commercial rv park close to the interstate. Upon arrival, I de-winterize the trailer and enjoy a gin & tonic or two!
We continue this way until final destination.
There have been times (usually due to bad weather / bad traffic jams) where we have made much worse mileage on day one and then have resorted to two nights in FJ truck stops rather than one. Not a problem, and FJ have showers ($) if you want.
This has always worked well for us and hopefully we will be doing it again next February. Plans already made for Florida and reservations booked!
Good luck and enjoy your trip!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 10-04-2015, 09:34 AM   #3
LakeState's Avatar
2006 25' Safari
Howell , Michigan
Thank you so much for your quick reply Brian.
Your story has generated a few questions and if you have time let me know your answers. I never gave FJ a thought. I was sure that I would be stuck with Walmart and ghost stops. It's a great idea and I will check out their locations before we go.
1. Breakfast in the morning, FJ breakfast or are you serving up something from the AS fridge And stove?
1b. do you run the fridge while towing in the winter? If so any adverse effects?
2. On Our day 2 it will still be below freezing and might be on day 3 as well. So at what temperature are you De-winterizing? I would think above 32 degrees, no pun intended.
3. May I ask where your Home state is? Ours is Mid-Michigan. On a good day in the summer no AS I drive 12 hours to Tennessee. That puts me in Kentucky in 12 hours with AS, still freezing there most of the time..
Old 10-04-2015, 10:05 AM   #4
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
We leave Fairbanks in Feb with sub-zero temps and run both the heat and fridge while on the road. We stay in the AS and cook in it. Also use the AS toilet with RV antifreeze. We de-winterize when daytime temps go above freezing and dont worry to much above overnight low. But for us issue is finding open campgrounds with water where we can fill our fresh water tank. We have had overnight lows below zero with no problems, done this for several years.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 10-04-2015, 10:41 AM   #5
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
We run the furnace while on the road if temperatures are below freezing. Never had an issue and never had anything freeze up on us. If you make the run south from Michigan, you are going to run into more moderate temperatures someplace in KY unless you are unlucky, and don't keep an eye on the weather.
Bob Martel
WBCCI# 5766
Old 10-04-2015, 10:50 AM   #6
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
We are Florida Snowbirds. We live in Illinois. We chose to stay on I 65 and go thru Bingingham instead of traveling on more hilly I 75 if there is snow up north. The Chattanooga hill is frequently bad in December. There are a number of campgrounds that stay open south of Nashville. There is a 4 lane highway to Maryanne and we take I 10 in Florida to get to the east coast or Florida 19 to take the Gulf route.
Old 10-04-2015, 12:18 PM   #7
LakeState's Avatar
2006 25' Safari
Howell , Michigan
Nice to hear other folks get out and travel in the winter. Your responses have been what I hoped for but wanted to hear it from others before going. My wife has suggested I bring plenty of LP, but we will be stopping and filling up for that. The I 65 route sound intriguing since I have always used 75. crisen, seems you could store water in the AS if the heaters going.
Old 10-04-2015, 12:47 PM   #8
crisen's Avatar
Fairbanks , Alaska
We do add water when we de-winterize, we just don't have water in tank when we leave here since we regularly hit temps in -20's F. Don't want to risk damage if furnace should fail. Carry jugs of water to use until we get to more moderate temps.
Rick
Old 10-04-2015, 01:18 PM   #9
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Cracker Barrel is another free option, if allowed at the specific location/town. Call ahead and ask the manager. Usually the answer will be; have a meal with us and you are welcome.
I like to find a state/federal park along the way, to get away from the traffic.
Keep an eye on the weather, even in GA and FL. The only time I have had a water line freeze and burst was near Brunswick GA, right on the FL state line. I did not have the heat turned on thinking I was beyond that necessity.
Alan
Old 10-04-2015, 01:24 PM   #10
Wingeezer's Avatar
2005 30' Classic
Usually we don't like to have a big breakfast and so we generally just have a bowl of cereal in the trailer along with our FJ coffee!
We don't run the fridge certainly on them first day of our travels as the outside temp is usually below freezing anyway, plus we don't carry much food from home at all and usually stock up the first day we get to warmer climes.
After that, we do run the fridge on gas while travelling. Doing so is always a subject of debate among RV'ers but we always have run ours. With modern fridge having auto ignition, if the flame should blow out it re-lights.
I have to admit I don't even shut ours down when fueling the truck - probably I should!
As for when I dewinterize, I just watch the weather forecasts to judge as we travel, but almost always am able to do so on our second night out. Once dewinterized, I think you would need a fairly extended period at quite a bit below freezing to cause any problems, especially with heat on in the trailer. One tip if concerned is to leave faucet in the trailer running at a slight trickle to keep water flowing through - assuming your sewer hose is connected and gray tank valve open.
Our winters are probably not too much different than yours - we live in Burlington Ontario midpoint between Toronto and Hamiton, about an hour from Buffalo.
Hope I answered your questions!
All the best .............. Brian
PS - it just happens that we have not stopped at Walmarts or Cracker Barrels, many others do, and if we got stuck without a nearby FJ, we might give that a try. If really stuck we would just stop for our first night in a motel with enough space to park the trailer.
Whenever we do stop on the road to sleep in the trailer, i always feel better about it if there are other RV's present - pretty much always seems the case at FJ's.
FJ is now owned by Pilot. We have also stopped at Pilot truck stops but prefer the FJ's. Most actually have double length parking spots out front specifically for RV's.
If you go on their website you can find a map with details of all their locations and what facilities they have. Brochures available in the store as well.
A tip I have found handy when I am planning where we might stop is to look at the FJ on google earth to see what their parking setup for RV's is.
Most do have good accommodation for RV's but there are a couple we have run across that do not, so this avoids surprises you don't want to have!
If memory serves me, the FJ in Albuquerque has no RV parking. That might be the only one we have encountered.
The ones away from busy cities are best as they have much more land!
2005 Classic 30'
Old 10-04-2015, 01:36 PM   #11
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I agree with the strategy to tough out the first day or so and get to warmer weather as quickly as possible, then take your time and enjoy the trip. See some stuff along the way; if your going to Florida head to Texas first.
We left Minnesota mid-winter for several years, Florida, New Mexico, Arizona, Calif destinations, then decided on a better solution. Leave mid-October, head back mid-April, and see some country taking the long way. Been doing this six years, take a flight back for the Holidays.
We're prepping the Airstream today, looking forward to the trip. Some of these winter resorts can be a blast, we meet up with a bunch of snowbirders, locals and relatives and have the time of our lives.
Doug and Cheryl
Old 10-04-2015, 02:28 PM   #12
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by dkottum View Post
<snip>.......decided on a better solution. Leave mid-October, head back mid-April, and see some country taking the long way ............ back for the Holidays......<snip>
^^^ the best answer^^^
That what we do now. We are in FL by the end of Oct. and back home the first week of April. Home with family on holidays.
Alan
Old 10-04-2015, 03:46 PM   #13
2007 28' Classic
Ivanhoe , Virginia
We go from Virginia to Florida each winter, with few exceptions. Going to Florida, we get to the coast ASAP, safe to de- winterize usually as night times are not horrible. When we go to Lake Havasue, we again head south to I-10, have yet to have any freezing problems on either route. First trip this year with our new to us AS (2007 classic) and hope our luck continues. Good luck to you, safe journeys.
senioryakker is offline   Reply With Quote
Old 10-04-2015, 04:32 PM   #14
Plan-B's Avatar
2016 26' Flying Cloud
2016 25' Flying Cloud
1997 21' Excella
Watervliet , Michigan
Being from Mich. too just pick a day the roads are dry. Far less salt pushed up in corners of the AS that will do its damage over time. Even if dry as soon as you get out of salt powder on the road, hit the car wash and do a good job and on its tummy and brake area. Good luck.
Greg
2016 RAM 2500 6.7L Cummins, 4WD, Crew, Rear Air
Plan-B is offline   Reply With Quote
2016 AlumaFandango 9/20-25/2016 Glenritas Other Rallies & Events 14 09-26-2016 09:40 AM
Is it too late to plan a snowbird escape for Winter 2015? FCloud9 On The Road... 59 02-27-2015 10:45 PM
Snowbird help needed Silver_Star Airstream Lifestyle 10 12-22-2012 12:56 PM
Snowbird Migration...Spring Can't be far behind wahoonc On The Road... 0 04-03-2004 06:45 AM
Snowbird question.... Silver Bullet Our Community 2 09-26-2002 10:44 PM
