Old 07-18-2016, 05:39 PM   #1
DaveCamp's Avatar
2016 27' International
Anywhere , USA
first time towing down the mountains
I'm probably overthinking this but it never hurts to ask. We managed to get ourselves up in to the Adirondacks, having owned our Airstream (27FB) all of 2 weeks. Now we have to get back down this week. We have a 2016 Tundra and with tow haul on the way up wasn't too bad, the roads are a little twisty turny. But now on the way back down I want to avoid riding the brakes on longer hills, I understand tow haul manages a lot of that, or should I consider switching to manual and downshifting myself? There's really only one hill (Minerva if anyone is familiar, before exit 26 in Pottersville getting on 87/Northway) I'm concerned about and I'm sure just prudent braking will be enough but I don't want to smoke them Any tips/advice welcome!
DaveCamp is offline   Reply With Quote
Old 07-18-2016, 05:43 PM   #2
2007 22' International CCD
first timing towing down the mountains
Rule of thumb is do not go down any faster than you went up.
I'm sure other owners of your Tundra TV will chime in.
KE4GNK/AE
'The Silver HamShack' (2007 International 22FB CCD 75th Anniversary model)
Old 07-18-2016, 05:51 PM   #3
1976 31' Sovereign
Oswego , Illinois
Very def. down shift to keep speed down and not smoke brakes, if you do they will be useless after smoked. Keep speed down and don't worry about speed racers going hell bent, just take easy so don't wind up looking at wrong side of grass. Truckers down shift and use exhaust brake to keep under control, be safe.
featherbedder is online now   Reply With Quote
Old 07-18-2016, 06:33 PM   #4
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Assuming you have a modern vehicle, your brakes are powerful and less expensive to maintain and repair than your engine or transmission. That said, don't ride them. Slow down to your target speed...45, 55, your choice. You determine your target speed by trying your brakes. A speed that requires what you define to be too long a distance to make a full stop is too fast.
On a reasonable grade (3-6%) slow down to 5 mph below your target speed. Then let off the brakes and allow the rig to increase in speed to your target and repeat your slow down to 5 mph under. This is how you descend the grade. Apply the brake smoothly so you do not unsettle the rig. Letting off the brakes lets them cool. Be ready to stop completely if someone pulls out or stops in front of you.
On a significant grade (6-10%), you may need to cycle through 10 mph around your target speed as the rate of acceleration between braking cycles will be more and you will gain speed faster.
If you feel more comfortable, downshift to the gear you would be in to climb the grade at your target speed. Do not allow the engine to over-rev as you descend the grade. Brake before a curve. A light pressure on the brakes can help settle the rig in a turn, but apply smoothly and release so you do not ride the brakes and allow heat to build.
Set your brake controller per your operating instructions. On a very long grade, you may want to stop and let the brakes cool. Brake maintenance is appropriate if you use them.
Travel safe. Pat
Old 07-18-2016, 06:47 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
On long steep grades, my advice is to shift down to second in manual mode at the top and try to maintain a speed that YOU are comfortable at. Don't do something unless you are comfortable.
On these grades, if there is a posted maximum speed for trucks that is what I usually try to do as a maximum. When I reach that point or a little over, I'll start using the brakes to slow down 5-10 mph then give the brakes a minute to cool before doing it again. I've done some 8% and 10% grades recently. At lesser grades I find the brakes may not be required at all. That truck speed limit is where I feel good. I don't like one of those 80,000 lb semis riding my bumper, so I'll move over and let them pass if they want to go faster.
Don't be afraid to let the RPMs get up around 4k or more. As long as you don't red-line the tach, that is what you and the truck are supposed to do.
add edit:
I done the above many times using a half ton pickup, sometimes towing at over 14,000 lbs combined weight.
Alan
Old 07-19-2016, 11:06 AM   #6
2016 23' Flying Cloud
2014 Interstate Coach
Birmingham , Alabama
Gunnrack
Just back from the west coast, I found putting my f150 in the manual mode helped, also start your decent slow,20MPH, down shift to 2nd gear, that should do it. FYI, I'm in Alabama, Roll Tide!
jmgunn1 is offline   Reply With Quote
Old 07-19-2016, 11:10 AM   #7
Hans Grim's Avatar
1993 29' Excella
Brighton , Ontario
Just back from a trip to the Gaspe in Quebec, Newfoundland and Labrador. Lots of 11 to 13% grades. Coming into Perce on the Gaspe there's a 17% grade into the little town with a speed limit of 50 kph (30 mph). Started at the top at 50 k in first gear, let the speed climb to 60/65 then used the brakes moderately hard down to 50, then let it climb back to 60/65. The grade is not that long so only had to do that a few times. Just made sure that by the time I got to the bottom where all the tourists are, I was totally in control. In my mind drivers behind me didn't exist.
Do whatever it takes to be safe and comfortable. You're the one responsible for anything that happens with your rig.
Hans Grim
1993 29' Excella
2011 GMC Sierra 2500 HD 6.0L
Hensley Arrow
Hans Grim is offline   Reply With Quote
Old 07-19-2016, 11:13 AM   #8
2014 27' Flying Cloud
Stowe , Vermont
This is something that I wrote last year (2015) 2015 - F250 Diesel - 1st Major Trip Stats -
OK, here’s what’s happening on the first leg of our first long trip with our new F250 - crew cab, short bed, 26 gal. tank - cap on truck bed - much gear and generator in bed.
In June we did a shakedown trip from Vermont to the Maine coast with 27ft. AS FC & 2, 17ft. kayaks on roof/cap rack. All went well. Now we are headed west to Yellowstone and the Grand Tetons, where we have been many times. We are towing our AS fully loaded but no kayaks on this trip. Our last truck was a 2007 Ram with a Cummings and Jake Brake and 30+ gallon fuel tank. These are some stats that may be interesting to fellow truck geeks. We averaged about 650+ miles per day for the first 3 days going on the Interstate from VT, thru NY, PA, OH, IN, IL, WI, MN, SD, WY. Day one included 3 hours of slower state routes in VT to get to the NY Thru-way. Averaged 13+ mpg - fair weather driving to OH. We found fueling up was a more common occurrence with this small tank, but thought that it got us out to stretch more often. In reality we miss the longer range of the Ram tank. When we hit quarter tank in our F250, we were looking actively for fuel. Day 2 thru OH, IN, ILL and WI we were in the 12.5+ mpg, keeping our speed at about 65 mph. Day 3 was “interesting” thru MN and especially SD. We had a headwind that was up to 35mph. Our mpg tanked at 10mpg, and that was keeping my speed at 70mph, when the posted speed was 80mph. Day 4 the wind subsided as we continued across SD into WY. I found that 68mph the best for my fuel economy, but it was humbling as we were passed by most people going 85+. We were close to 13mpg that day until we hit the Big Horn Mountains and Powder River Pass (Rt 16). Going up the mountains we had the low of 6.2mpg. The diesel had power to spare. The going down was “interesting”, as I experimented on some of the shorter inclines before the BIGGIES - STEEP pitches including hairpin turns at 20mph. This is what I found best. I left the transmission in “Drive” while engaging my “Jake (engine) Brake”. One light tap on the brake dropped me from 6th gear to 5th. Next tap brought me to 4th - next to 3rd - next to 2nd for the steepest sections with the hairpins. The engine did all the work. I didn’t have to brake at all once I was in 2nd gear. Awesome!!! The down mountain and flat roads to Cody WY got my mpg up from the low of 6.2 up to almost 13. An interesting trip so far to say the least. We are at 2327 miles as of Cody with about 90 miles left to go for Yellowstone.
VT Wanderer is offline   Reply With Quote
Old 07-19-2016, 12:53 PM   #9
dalecamp`'s Avatar
Pearland , Texas
If you have 4WD. Stop at the top and shift to 4WD low range. I do that in Colorado. It'll take me to the bottom going about 30-35 with very little use of the brakes. Then I pull over and go back to 2WD in tow haul. Good luck. Be safe.
dalecamp` is offline   Reply With Quote
Old 07-19-2016, 01:20 PM   #10
belen , New Mexico
the TOW HAUL on my 06 f350 v-10 does all the work downshifting on these huge AZ mountains! So I would take advantage of that as it knows how to keep gravity at bay! I put it on and as im going down the hill I brake once at the speed I want to keep and it takes over!
SIMPLY AMAZING!
alantbird is offline   Reply With Quote
Old 07-19-2016, 01:21 PM   #11
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
Reseda , California
Personal experience from my previous post:
Down shift, use lower gear to help you go down slow. If you have a brake controller, set it to max, so you trailer will brake more than your TV.
Just go nice and slow.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
"Sweat is your fat crying"
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 07-19-2016, 02:12 PM   #12
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I had a 2010 Tundra with a P2 controller. Took the Airstream out to Utah and back via Colorado in June 2015. I always tow with tow haul on. Didn't think it helped on the down hills so I always shifted manually. Set the transmission in S and then towed in 5th. On up hills manually shifted down and down hills manually shifting down since the transmission wouldn't do it automatically. On several down grades on I70 in Colorado I felt my Tundra brakes vibrating under heavy braking. Once the brakes cooled they were smooth again.
My Tundra was a 2x4 and after that trip I decided to switch since I wanted 4x4 and more payload for future extensive trips after retirement. Ended up with a 2015 Ram Big Horn 4x4 Crew with the Cummins. The integrated brake controller is much better than the Prodigy P2. The tow haul actually works on the Ram. Touch the brakes and it starts to shift down. Coupled with the exhaust brake heavy braking on the hills is no longer required.
Hopefully, Toyota on the 2016 Tundra with integrated brake control has improved tow haul.
Kelvin
Old 07-19-2016, 02:24 PM   #13
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
So far this summer I've learned some important lessons. Both involving hills!
We traveled from Ohio thru Tenn. to attend Springstream. We chose to do the diagonal off 75. We hit several miles of quick curves and tight grades. We made it home safely to Ohio with new respect for the South.
Shortly after, we attended International in Lewisburg WV. No problem as I have traveled WV before. Well, I never towed East of Beckly! Those are some doozies there!
My TV is a 1996 2500 2wd Suburban w/350 and the wrong gears. I've been told I should be downshifting to save brakes, but have been leary to do so. Tranny work is $$.
After arriving in Lewisbug, my brakes were toasted. They rotors felt very warped and I was frankly somewhat concerned about making it home without a brake job.
Time came to head to Ohio. I elected to "see how it goes". The big passes were within the first dozen miles or so. I downshifted to third and second. Everything felt much better. The truck did great. I certainly did not win any races, but my knuckles were not white either! It was much more comfortable.
So from now on, it's "let'um pass me". I'll catch up later.
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 07-19-2016, 02:47 PM   #14
2004 25' Safari
1968 17' Caravel
Fountain Valley , California
Don't do what I did on a 6% down grade, complete with wind and a ripple in the road...
WindyJim is offline   Reply With Quote
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
Towing In The Mountains with a 2006 3500 Chev. Express van Schnick Tow Vehicles 7 07-20-2010 06:06 PM
First Time and Full Time! JRoss3030 Member Introductions 9 03-20-2010 11:28 PM
first-time poster.....long-time reader ("lurker") happyfella Member Introductions 3 08-21-2006 08:55 PM
Towing a 25 footer in the mountains with a Suburban terry & pat Tow Vehicles 27 02-16-2006 06:53 PM
