Old 03-29-2006, 08:18 AM   #43
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Maybe the new ones are different - but I don't see how they can be. My owners manual (97 Safari) warns against towing with the battery disconnect set to Off. The reason given is that the battery will be the only source of power in the event the break-away switch is pulled.
Perhaps check with your airstream dealer again - ask him what will be the power source to power the brake magnets if the battery is disconnected? Does he think the battery disconnect is bypassed with a direct link or something? Or something else?
pmclemore is offline   Reply With Quote
Old 03-29-2006, 08:48 AM   #44
2006 30' Classic
Farmington , New Mexico
Images: 14
Originally Posted by myoung
I knew the grey water tank was full because the shower wouldn't drain. I'm pretty sure the monitor indications are accurate. However, the monitor may not be as linear as the markings indicate. It seems as if the amount of water needed to go from half to full in the fresh water tank and in the grey water tank was less than necessary to go from zero to half. Not a scientific study, just an impression.
Our AS has pretty good capacities, among the best in the Safari line. Supposedly, they are 39 gallons each for black and fresh and 37 gallons for grey. If I could change the proportions, I'd reduce the black and add the reduced amount to both grey and fresh, probably with more allocation to the grey. Don't even want to contemplate filling the black before using up all the grey.
In an emergency or to get by for a short time you can drain off some gray into a bucket and dump into the toilet. Sometimes to save gray space wife will do dishes in a pan and pour into the toilet. You can easily stretch you gray another day sometimes two. Pieman
Mike Lewis is offline   Reply With Quote
Old 03-29-2006, 09:21 AM   #45
myoung's Avatar
Nipomo , California
Images: 24
Thanks, Mike. I really like these ideas. The black water tank has much more capacity than needed so your suggestions will help us even out the distribution in the tanks.
Mike Young & Rosemary Nelson
Bowlus Road Chief "Endymion"
BMW X3 xDrive 28D
myoung is offline   Reply With Quote
Old 03-29-2006, 09:53 AM   #46
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
I think that "battery disconnect" is almost misleading. It's actually a battery isolator that completely isolates the battery from the coach. Unless they've done something different in the wide body coaches that would keep the breakaway switch 'hot' while everything else is dead?
Roger
Old 03-29-2006, 02:22 PM   #47
munimula's Avatar
1993 34' Excella
1962 16' Bambi
New Haven , Connecticut
here's a link to the old wally byam checklist...
http://dwmorrison.com/airstreamchecklist.pdf
it appears in one of the more recent airstream books - i forget which one.
don't feel too bad, last year i tore off all four stabilizers. i was in a real rush packing up as i was trying to get to a ny giants football game. needless to say, we missed the kickoff.
i now keep a supply of the checklists in my glove box.
--dave
munimula is offline   Reply With Quote
Old 03-29-2006, 04:00 PM   #48
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Roger
Thanks for clearing that up!
Richard
Old 03-29-2006, 05:24 PM   #49
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
From time to time in my forgetfulness I approach the MoHo from the drivers side.... no door there dummy.... then proceed to walk around the rear to get to the side door. It looks like a walk around but is actually just a "fake out" for anyone who might be wondering what the heck I'm doing on the wrong side of the bus.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 03-29-2006, 07:37 PM   #50
2003 25' Safari
Eden Prairie , Minnesota
When in more wild camping areas (where we usually go) we attach a green garden hose to a special cap for our dump valve and let the grey water trickle out into the weeds away from the campsite. It's just soapy water, soaks into the ground, and no different than the tenter next door pouring his dishwater into the grass. This does not apply to crowded "civilized" RV parks, but they usually have full hookups anyway.
Dan
dmac is offline   Reply With Quote
Longest Trip in a Classic AIRSTREAM Motorhome winner Airstream Motorhome Forums 17 01-26-2005 08:11 PM
Longest Trip with a Vintage Airstream Pick On The Road... 7 11-03-2002 07:44 AM
South Carolina Trip Ideas rdm Our Community 4 10-17-2002 09:17 AM
Trip report (long and maybe boring) mkeith54 On The Road... 4 07-26-2002 09:39 PM
Took Globetrotter on first real trip Jim Clark On The Road... 4 07-01-2002 09:41 PM
