Old 03-28-2006, 01:15 PM   #29
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Little Checklists are better..
Mike-
Glad trip worked out well.. I think we've stayed in same camground down the hill by creek in Big Sur.. Won't mention our problems.. Not likely to be able to un-bend the jack stand, but they are easy to replace, with Atwood or other brands. Lifting at an angle is unstable, and any load moving around inside trailer when parked on angled jack stand might result in failure fracture and front of trailer on ground... I tried to pull ours forward when jack extended on concrete pad at house (strange screaking noise....) and so can speak with some authority.. We have shiny new jackstand, and some vintage owner here proudly willing to take old one and attempt to unbend flange...
As for checklists, as Pilot I am believer, but the shorter the better.. Real long and complicated ones get ignored or steps skipped. We keep a pair of these laminated and inside trailer (in case we lose or loan one out) and they work well, along with a walk-around... Tried scanned and reduced version with no luck. Attached now is MS Word version.. Colors just for variety, and to help move from item to item. Best part is that it works interchangeably from set up to prep for towing... You may want to search out dumb mistakes threads here, as there are a lot of fabulous learnings to enjoy...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 03-28-2006, 01:17 PM   #30
myoung's Avatar
Nipomo , California
Images: 24
Originally Posted by azflycaster
I looked at your lists, what is disconnect battery at door?
Right at the door there is a switch that disables the battery for storing the trailer. I think I am saying this correctly. It's like a breaker switch and by turning it off, all the battery powered items are shut off for certain.
Mike Young & Rosemary Nelson
Bowlus Road Chief "Endymion"
BMW X3 xDrive 28D
myoung is offline   Reply With Quote
Old 03-28-2006, 02:25 PM   #31
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I sure you'll get a lot of comments about disconnecting the battery. This is a very bad idea, as your electric brakes will not function.
Welcome to the club - if it weren't for the adventure, we'd all stay in hotels.
Pat
pmclemore is offline   Reply With Quote
Old 03-28-2006, 02:38 PM   #32
myoung's Avatar
Nipomo , California
Images: 24
No, no, no. This isn't what happens. The brakes work perfectly fine as do all the various exterior lights. The battery disconnect switch is for interior items only.
I don't have my owner's manual handy so I can't explain this more accurately. Perhaps others could explain the function of this switch better than I. Also, this switch may be a feature of recent models. I simply do not know. Hope I haven't created any confusion or conveyed misinformation.
BMW X3 xDrive 28D
Old 03-28-2006, 02:50 PM   #33
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
Don't feel too bad... one of the first learning mistakes I did myself in my excitement to hook up was to raise the electric jack while the stabilizers were down... As you can imagine, even for only a few inches of force can damage the rear stabilzers as the front end raises up.
I always did wonder why we couldn't wire in a switch somewhere hidden that would disable the electric jack. I'm always afraid of kids or someone leaning against it may accidently trigger the switch and raise or lower it when it wasn't ready (i.e. at a campsite when the stabilizers are down).
Kevin
Bambi_Bandit is offline   Reply With Quote
Old 03-28-2006, 03:14 PM   #34
nazz300's Avatar
Decherd , Tennessee
Electric Brakes
Pat
We have the same 25' trailer as myoung. The brakes are operated by 12V current from your tow vehicle. An electonic controller is installed in line with the brakes in the tow vehicle. This controller will synchronize the trailer brakes with your tow vehicle brakes. It is designed to apply the trailer brakes when you hit the tow vehicle brakes. The brake controller has an adjustment knob to dial in the correct setting for safe comfortable stops.
I'm sure he has an electronic controller installed in his tow vehicle.
The battery disconnect switch located in the trailer will have no effect on the braking system.
--Nazz
nazz300 is offline   Reply With Quote
Old 03-28-2006, 03:42 PM   #35
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Battery cutoff switch
You'll have to reset the time on your clock (in the radio) and also anything else you have in the trailer; alarm clock, microwave clock, etc. So if you're just moving between campgrounds you might want to leave it on. If you're going to be on the road, your tow vehicle will provide a trickle charge to the battery so you can go ahead and leave it on. If you're storing it or not planning to use it for a week or more, you'll want to turn it off or risk running down your battery.
Paula Ford
Old 03-28-2006, 03:52 PM   #36
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Pat
Even if you remove the battery(s) the electric brakes should still function, they are powered from the brake controller in the TV. If the trailer was to break away, the breaks would not function once the cable from the TV pulls out.
Richard
Old 03-28-2006, 08:53 PM   #37
CanoeStream's Avatar
St. Cloud , Minnesota
Numerous variations are out there. Personalizing your own departure checklist is best! Here are only a few, though the 1st isn't a departure or walk-around list at all...
New Trailer Shopping List
Hitting the road check list
Check Lists
5 meter Langford Nahanni
Old 03-29-2006, 06:15 AM   #38
Ready-to-Travel
pmclemore's Avatar
I woke up last night realizing my comment was incomplete. AZ has it right - if you lose connection with the tv, then it will be the battery that operates the brakes. But not if the disconnect is turned off. Sorry for the mistake.
See what happens when you lose concentration?
Old 03-29-2006, 06:23 AM   #39
myoung's Avatar
Nipomo , California
Images: 24
So what you are suggesting is that when the switch is turned to the "store" position, the off position, the brakes will not function when the emergency disconnect plug is pulled from the trailer a-frame when the trailer brakes loose. Now, that is a major, MAJOR problem!!
If you are correct, then there ought to be a huge warning sign somewhere indicating that fact. Have I missed something? Can we get confirmation, because this is a serious safety issue.
BMW X3 xDrive 28D
Old 03-29-2006, 06:45 AM   #40
2002 25' Safari
Dewey , Arizona
Images: 62
My reply was with the battery(s) removed from the trailer. My 75 does not have a battery disconnect switch. I have no knowledge of what it does.
Richard
Old 03-29-2006, 07:09 AM   #41
We can tow it!
tin sista's Avatar
1996 28' Excella
Where the water tastes like wine , Michigan
Images: 82
Smile Great forum support!
So sorry you had that experience Mike. We all get our first trip/or later oops! I learn daily from the collective wisdom and checklists on this forum! We were lucky to benefit from the wisdom of others on our first trip out, and gave copies of some forum arrival/departure checklists to the folks who bought our 79. I'm sure that it helped.
Check Lists
Steph in MI Air# 6996-
I Hockeytown USA!!
tin sista is offline   Reply With Quote
Old 03-29-2006, 08:10 AM   #42
nazz300's Avatar
Decherd , Tennessee
I spoke with the AS dealer and they verified this:
In the event of an accidental separation of the TV and the trailer, the break-away switch will set and lock the trailer brakes for a sufficient length of time to stop the trailer. The switch is activated when the wire attached to it and to the TV pulls out the small pin in the front of the unit.
This switch will function no matter what position your battery disconnect is in.
--Nazz
Longest Trip in a Classic AIRSTREAM Motorhome winner Airstream Motorhome Forums 17 01-26-2005 08:11 PM
Longest Trip with a Vintage Airstream Pick On The Road... 7 11-03-2002 07:44 AM
South Carolina Trip Ideas rdm Our Community 4 10-17-2002 09:17 AM
Trip report (long and maybe boring) mkeith54 On The Road... 4 07-26-2002 09:39 PM
Took Globetrotter on first real trip Jim Clark On The Road... 4 07-01-2002 09:41 PM
