Old 06-02-2019, 08:47 PM   #43
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Airstream Fiamma Bike Rack Issue.......
After struggling with the known issue of breaking brackets on the Fiamma rack. I just couldn’t bring myself to ordering replacement parts that I knew were substandard and would simply just break again.
During a call with Sean Woodruff from ProPride Hitches I articulated my frustration and asked if he thought he could help. He didn’t just pander my frustration he actually took an interest and jumped all over it. About a week later he calls to say he had the replacement parts designed and produced. It’s a perfect substitute to the original but made of stainless steel and a whole lot stronger.
We installed a set on my trailer and it was dead simple as even the old screw holes lined up. I think this nagging issue with the Fiamma racks is finally put to bed!
If anyone is interested, just give Sean a call at ProPride I’m sure he can fix you up.
ID:	342340   Click image for larger version
ID:	342342   Click image for larger version
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 06-03-2019, 12:05 AM   #44
2007 22' International CCD
Sean does some really pretty work.
rmkrum is online now   Reply With Quote
Old 06-03-2019, 09:21 PM   #45
CruizinDux's Avatar
Tracktown USA , Oregon
THANK YOU, Arcticfox¡!!!!!
CruizinDux is offline   Reply With Quote
Old 06-11-2019, 09:46 PM   #46
2019 19' Flying Cloud
Mount Pleasant , Michigan
Just returned home from our third trip with our new FC 19CB. This was the first time using the Fiamma rack installed at Colonial Airstream prior to picking up the unit. Was shocked to find in the drive way that one of the arms had pulled completely out of the AS on the right side and it had started to do the same on the left side as well. I don't think the parts failed, they pulled out of the camper making me think this is an installation issue. Until I come up with a fix, what would be the best way to seal the screw holes to prevent wanter from entering the wall? The screws have insulation on them so I fear getting water in there.
TrailDude is offline   Reply With Quote
Old 06-11-2019, 09:57 PM   #47
Sorry, trying to figure out the picture thing
ID:	343097   Click image for larger version
ID:	343099   Click image for larger version
Old 06-11-2019, 10:01 PM   #48
CruizinDux's Avatar
How about some metal roofing screw with grommets or similar. Might need a larger size.
https://www.lowes.com/pl/Roofing-scr...are/4294710844
I'd go to ace for more variety. May want to do some probing in the hole for the bottom other than insulation. You may also try a plastic sheetrock anchor with a screw and metal backed grommet. The plastic anchors come in a variety of sizes.
Please post the final diagnosis. The oem screws may not have found any meat.
ps, that screw looks pretty short...about long enough to make it thru the skin and that's about all. That's scary.
pss, interesting you bracket stradles the row of rivets and arcticfox's at least on one side is directly on top of the row and maybe a vertical metal stud???
Old 06-11-2019, 10:14 PM   #49
CruizinDux's Avatar
Check out my post #26. It is an older fiamma failure thread and seems i recollect discussed experience re portable interior anchoring options. Maybe a thru bolt right into some backing on the inside.
Old 06-12-2019, 10:48 AM   #50
ProPride, Inc.
Sean Woodruff's Avatar
Grand Blanc , Michigan
Send a message via Skype™ to Sean Woodruff
Not sure if this link is allowed but a moderator can delete if not. Here is a link to the replacement mounts. We ran out of the first batch we made but are working on more now. We will be shipping them by the end of the month.
https://store.propridehitch.com/airs...cement-mounts/
Let me know if you have any questions.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Sean Woodruff is offline   Reply With Quote
Old 06-12-2019, 04:12 PM   #51
Thanks! Waiting to hear what Airstream has to say before I make any decisions!
Old 06-13-2019, 10:27 AM   #52
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
Bad installation. I always screw the outside row into the vertical support locating them between the rivets, using as fat of stainless steel screws that will fit through the bracket. I rivet the inside row through the sheet aluminum, not so much for support but for guidance.
Seal the holes with Sikaflex, not silicone (incompatible with aluminum).
I've done it this way on my last three trailers without failure.
SilverWind is offline   Reply With Quote
How do you lock your bikes on your fiamma bike rack? BoldAdventure Our Community 47 02-12-2017 10:52 PM
Fiamma Bike Rack kscherzi General Repair Forum 4 02-08-2014 07:49 AM
How to attach Fiamma bike rack to 19ft bambi Whitewater99 General Repair Forum 2 07-25-2013 04:49 AM
2010 Airstream International Signature 23D Travel Trailer WIth Fiamma Bike Rack eBay Watch Airstreams on eBay 0 05-27-2013 02:30 PM
EB Fiamma Bike rack StagrLee Eddie Bauer - All Models 2 05-08-2013 05:05 PM
