Go Back   Airstream Forums > Airstream Community Forums > On The Road...
View Poll Results: Do you travel with an extra can of fuel?
Yes 4 12.50%
No 28 87.50%
Voters: 32. You may not vote on this poll
Old 07-04-2004, 06:21 PM   #21
LOST , Hawaii
Diesel pumps need to be primed either by a hand pump in line, the electric pump in tank or pressurizing the system with air.
John
74Argosy24MH is offline   Reply With Quote
Old 07-05-2004, 07:09 AM   #22
mcneon's Avatar
Originally Posted by markdoane
Quick question: I know marine diesels need to be primed if they run out of fuel. Is the same true for modern day pickup trucks with diesels?
I've had two diesels, and I ran out once in each one.
The first was a '92 Dodge Cummins with mechanical injection. In this one, you had to loosen the fittings on every injector with a couple of wrenches, then crank the starter motor until all the air was purged from the lines.
The second was a '95 Ford Powerstroke Turbo in an E250 van. The Powerstroke has EFI, so I had high hopes that I could just add fuel and drive off. For some reason, though, I had to pour fuel into the filter housing, which is in the vee on top of the engine. It's probably a very accessible location in a pickup, but a major pain to get to in a van - lots of disassembly of air inlet pieces and heat shields.
I hope more modern diesels are easier to get running that either of these, but if you have one, I'd advise you not to find out!
Bob McKeown
Nashville
mcneon is offline   Reply With Quote
Old 07-05-2004, 10:13 AM   #23
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
I have not run out yet in my DuraMax but the book says I will have to bleed and prime the system at the fuel filter. Done this at a filter change not a problem. Hope I don't have to do it for real.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 07-05-2004, 11:23 AM   #24
Retired.
. , At Large
Originally Posted by JohnG
If we have learned anything it is that ANYTHING can be fixed.
Show me where the buzzer is, and give me a pair of wire cutters. I will fix it. You will never hear it again.
Old 07-05-2004, 11:30 AM   #25
Retired.
. , At Large
John
A simple thing to do on EFI Diesels would be to program the ECM to turn off the injectors when the fuel quantity is less than 1 gallon. OBDII can tell fuel quantity that closely. That means that you have 1 gallon less of usable fuel, but think of the aggravation it could save, just adding a few gallons of fuel, restarting the engine, and driving away. No priming, no grease, no removing covers. No cursing and gnashing of teeth. The only down side would be if the fuel sender malfunctioned, but that is what we have AAA for...
Old 07-05-2004, 11:51 AM   #26
MarkE's Avatar
1969 18' Caravel
, Iowa
Nail Biting
I haven't carried extra fuel along on any of my trips, so far. But, I agree with Tinsel Loaf that it can be very tense when driving at night, with the 'low fuel'
warning lit (for quite a few miles), hoping that over the crest of the next hill will be a gas station.
I've had that happen a couple of times and it ain't fun. Soooo, from now on, when on long Airstream excursions, I think I WILL be taking along a small amount of extra gas.
MarkE
WBCCI #4568
MarkE is offline   Reply With Quote
Old 07-05-2004, 01:01 PM   #27
norbert's Avatar
1993 30' Excella
whitewater , north of cheddar curtain
Images: 24
well, mr.mastercylinder.....if its that simple, why havent those brilliant engineers thought of it?
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 07-05-2004, 01:39 PM   #28
Retired.
. , At Large
They have. It is used on larger diesel engines, like the ones in big trucks, trains and ships. They are even more of a pain to prime than our little ones.
Old 07-05-2004, 01:41 PM   #29
norbert's Avatar
1993 30' Excella
Images: 24
guess it boils down to the almighty dollar......
