Old 10-01-2010, 06:56 PM   #1
Over59's Avatar
Putnam , Connecticut
Images: 37
European Standards
I'm have some trouble finding a good source for European propane and electrical standards. What modifications do I need to run the trailer and diesel truck in France, Spain, Germany and Italy?
Over59 is offline   Reply With Quote
Old 10-01-2010, 07:53 PM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Diesel and propane shouldn't be a problem. Electricity however is different. In all three countries you listed, it is a 220v system instead of the 110v we have here in the States. I would suggest a PM to Lili/Hans of the Journey thread, or one of the forums other European members asking about necessary transformers and adapters. Low power adapters are readily available, but I don't know about a 30 amp adapter.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 10-01-2010, 08:33 PM   #3
OO , OO
Send a message via Skype™ to cruiser54
The electricity on the camping places in Germany and in Switzerland is enough, security 16 Ampère/230 Volt. In the south to European countries, for example Italy, it is critical. A roof climate arrangement does not run, generators are forbidden because of the noise.
Greetings from Switzerland
Werner
cruiser54 is offline   Reply With Quote
Old 10-02-2010, 09:50 AM   #4
Over59's Avatar
Images: 37
So that's 220 single phase? Nasty juice... Thanks
Old 10-02-2010, 11:17 AM   #5
OO , OO
There is even 230 volts, was adapted a few years ago to the European norm...
Old 10-02-2010, 12:20 PM   #6
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
They also have 50 cycle (Hertz) instead of our 60.
Although it is common to refer to 110 and 220 v., they have been 120 and 240 v. for many years in the US and Canada. Checking some websites I found voltages were misstated for the US at 110. But it doesn't matter that much since the necessary equipment will work no matter whether you call it 110 or 120.
Plugs here are standardized for different voltages, amps, phase, but other countries have different standard plugs.
Here's a link with voltages and plug types and some info about transformers and converters. Be glad you are not going to Brazil where there are no standards. Electricity around the world: everything about plugs, sockets, voltages, converters, etc.
Gene
Old 10-03-2010, 12:58 PM   #7
1986 32' Excella
vledder , drenthe
Images: 8
you need something like this ebay 400130073063
Most campsites overhere have a special 3 pin plug
But you also see the normal 2 pin european plug
remcolent is offline   Reply With Quote
Sae towing standards for 2012 Denis4x4 Tow Vehicles 51 06-08-2010 03:27 PM
SAE towing standards j2807 Denis4x4 Towing, Tow Vehicles & Hitches 4 12-26-2009 02:59 PM
Repacking hubs of Safari - What are standards for synthetic Cable Axles 3 02-08-2009 07:09 PM
Trailer length standards jcanavera Airstream Trailer Forums 4 08-10-2006 05:16 PM
The More I Polish...The Lower My Standards are Getting !! MileHigh Cleaning, Stripping & Polishing 49 06-08-2004 12:06 PM
