Old 06-18-2002, 08:21 AM   #1
Ann Arbor
essential tools
Greetings.
Next week I'll leave on my first major trip in my "new" '77 Sovereign, cross-country from Michigan to Arizona. I'm putting together a tool kit and would appreciate any suggestions for essential tools for travelling. I've looked at Frank's earlier post, but don't have the array he has to select from
So your recommendations will take me on a buying trip to Ace or Camping World, or wherever.
Thanks.
Eugenie
maznblu is offline   Reply With Quote
Old 06-18-2002, 08:54 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
When we traveled full time in our 77 sovereign I carried the following tool and supplies.
Basic hand tools: Screwdrivers, Phillips and Standard, 16 oz hammer, Small socket set, 2 crescent wrenches 6-8 inch size, Makita battery powered drill with charger, drill bits of various sizes, pop rivet gun with rivets of various sizes, a pair of pliers and a small screw top tube of silicone (I know silicone is bad, but when you need to fix a leak in the rain NOW you worry about undoing it and fixing it later) A test meter of some sort for AC/DC and continuity, assorted screws in different lengths, and some short 1-2 ft pieces of wire of varying gauges. I also carried the tools to crimp on ends and such but if the problem is that severe you may want to take it into a shop.
If your Sovereign is a center bath model I would suggest also buying a set or two of the closet door hinges. I know it sounds silly, but we seemed to have a set break every 6-8 months. We would enter the rig after arriving and the door would be lying in the hall or flopping from the top hinge. 3-4 bucks and worth it as you will not find them easily on the road. I also recommend a can of silicone lube and a can of lithium grease, as well as a tire iron that fits the lugs on the trailer. Bulbs and other safety items can usually be had on the road at the auto supply stores.
Let me put it this way. If you have it and think you may need it take it if you can, weight permitting of course.
Good luck on your trip.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 06-20-2002, 05:04 AM   #3
norpentig's Avatar
EAP,
Another suggeston would be 1 or two small ramps approx 12-15" long and 3" high. This will allow you to change a flat tire by driving the good wheel/wheels up on the ramp, thus lifting the flat tire off the ground without using a jack. You can make the ramps yourself from wood blocks or buy the plastic ones from your local RV supply store.
The 'which tools to carry' question doesn't have a universal answer since everyone has personal tool preferences. Trial and errror and experience will soon show which stuff you need.
Norm , Penny & Tigger
norpentig is offline   Reply With Quote
Old 06-20-2002, 10:18 AM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Need help
EAP,
If you are coming any where near Phoenix and need something. Even just directions as to where to go to buy parts. "Call me"
480 345-1939 wk #.
Now I have to question your sanity as to why you want to come to AZ in the last week in June. It is supposed to get to 112 today. Humidity is somewhere between 3 and 7%. It's drier than the moon up north and most of the National forest is closed due to fire restrictions. Water is getting a little short, however no restrictions.
Sure you don't want to wait till November?
>>>>>>>>>>>>>>>Action
Old 06-21-2002, 11:00 AM   #5
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Tool kit
My wife gave me a tool kit from Pep Boys last birthday. It is in a fitted plastic case and rides on the hump under the back seat of my extended cab Chevy. There are both metric and English sockets and wrenches. Not real high quality tools, but plenty sufficient for emergency repairs. My quality tools stay in my workshop.
I also have a toolbox in my covered truck bed with some larger sockets, a breaker bar, big water pump pliers, a small hammer, and several of the laminated Sears pliers. I make sure I have a socket along to fit the wheel lugs. With the breaker bar, I always have enough leverage to get a lug nut off without too much strain on my arthritic hands.
I carry a compartmented plastic box in the trailer with an assortment of wood and metal screws, washers, hose washers, and the like.
John W. Irwin
WBCCI #9632
Old 07-04-2002, 07:11 AM   #6
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Talking tools
Eugenie,
Congrats on your new (77) A/S..~!~
One thing that I don't think anyone mention is a 12volt air compressor..It sure beats hoofin it if a tire goes flat or gets low. Some of the hand tools mention are excellent to have with you. In addition, plse don't forget a first-aid kit and, not one but, several fire extinguisher ( baking soda is good for stove fire). Point of references: If you have a fire under the hood (god forbid), don't lift up the hood to put the fire out but, rather, point your fire extinguisher right into the grill~! This'll put the fire out quicker than anything..If you have a fire in your A/S, by all means try to put it out but, don't lose sight of this fact: A fire in any trailer can and, will spread very quickly. Keep your exit in sight just in case you have to bail out~!(I've not seen it actually happen but, it's been reported that most trailers can be totally consumed in matter of minutes. Be prepared to jump ship~!~Your life is worth more than any trailer.
I always carry extra oil, diesel fuel, tranny fluid, several gallons of anti-freezes and, a jug of distilled water.
Carry a cellfone, even an old bag fone is great for the extra range.You can always call 911 for help, even if your account is no longer active.
I'm sure others will think of something else for you. It's good you asked~at least you'll have a few options to look over.
During the trip, take freq stops, while you're walking around, touch things on your A/S..like doors latches, even the fastener for the propane tanks. Check your tires by lightly touchin with your fingers to check for tires,wheel bearing overheating.What you're looking for is uniformity in the feel of the tire or wheel temp..
Have a safe trip and, by all means stop often to smell the flowers along the way~:-}
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 07-04-2002, 09:30 AM   #7
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Exclamation A very handy tool....
I always keep a 7/8 open end wrench handy for removing the propane tanks for refill. I keep mine in the front battery compartment next to the tanks. It doesn't chew up the nut as an adjustbable wrench is apt to do. I also keep a roll of teflon tape on hand to seal the connection.
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 07-08-2002, 07:35 AM   #8
64GT's Avatar
1964 19' Globetrotter
Glenside , Pennsylvania
I always travel with my heavy duty hydraulic jack. Haven't needed it yet, but I'm sure I will some day!
64GT is offline   Reply With Quote
Old 07-08-2002, 08:44 AM   #9
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Re: tools
Originally posted by towner7
Eugenie,
One of the things I have heard at fire safety seminars is to occasionally take your extinguisher and shake it up. Apparently the typical extinguisher that comes in RV's tend to sit in one position for very long periods of time. The chemical power eventually packs together and will not discharge at a proper rate of flow. I normally pull mine out at least twice a year to shake it up.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-08-2002, 10:16 AM   #10
Pahaska's Avatar
Hays County , Texas
12v Air Compressor
I bought a heavy-duty 12v truck air compresser at Academy Surplus. It has an internal fan and can run continuously without overheating. It is a lot sturdier than any I have seen before and this is the first 12v compressor that I have found that will get D-rated tires up to 60# in a reasonable time.
I noticed that Camping World had the same compressor on one of their latest mailouts.
John W. Irwin
WBCCI #9632
Old 07-08-2002, 12:39 PM   #11
jcanavera's Avatar
Fenton , Missouri
Images: 143
Re: 12v Air Compressor
I just picked up one from Walmart last weekend. It cost $20 and it has an internal fan. Whether it is as heavy duty as the one you found at Camping World is up for question. My old one (no fan) seized this spring when I added 10 lbs. to each tire and put about 15 into the spare. I guess I shouldn't complain since I had that unit for almost 20 years.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-08-2002, 12:53 PM   #12
Pahaska's Avatar
Hays County , Texas
Compressor
This one was about $35 at Academy and their prices are very good. It is about twice as big as the usual 12v compressors and has much stronger gear train. It is a lot sturdier than the usual ones that I have found at around $20 and the only one I have found that is rated to run continuously. It will bring a tire up to 60# in no time at all.
John W. Irwin
WBCCI #9632
Old 07-08-2002, 01:06 PM   #13
jcanavera's Avatar
Fenton , Missouri
Images: 143
Air pump
Hmmm....sounds pretty good. I will probably hang on to the one I have at this point. Usually I'm only doing a 5 lb. or less touch up, so while the unit gets hot it usually is not enough for a melt down. I think the filling of the spare tire and the others was the straw that broke the camel's back. I have never pulled the spare out of its underside storage since I picked up the trailer in May 2001. It was way overdue for a fill. I'll keep better tabs on it in the future.
If I burn this one up I'll keep what you bought in mind.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-08-2002, 02:14 PM   #14
Jim W's Avatar
Pahaska, is that Acadamy a local store or is it on the www? That sounds like a good one.
SF CA area
77/31' Airstream
99/Suburban/454/4.10
#18248
Jim W is offline   Reply With Quote
Olympic rivet tools smallfry Ribs, Skins & Rivets 9 10-16-2014 05:37 PM
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
Website Design Tools... InsideOut Off Topic Forum 24 02-19-2005 03:33 PM
