Old 05-10-2009, 09:34 PM   #29
Originally Posted by Relentless View Post
I find that I have to check those bolts every time I stop. Sometimes one or both are loose, sometimes not. I have yet to figure out what causes them to loosen.
John
Quite possibly, it's the design of the hitch.
Many owners report the same problems.
Reese doesn't have that problem, and offers a superior sway control with their "dual cam."
Also Reese's sway control is "torsion" not friction.
Rain lubes friction sway controls, but has zero effect on torsion sway controls.
Old 05-11-2009, 07:24 AM   #30
2007 25' Safari FB SE
Blaine , Washington
Andy;
Now you tell me. Where were you 2 years ago when I was buying a hitch?
Oh well. Maybe next time. I hope there are others who are reading this thread that haven't yet made the decision on which hitch to buy.
John
Relentless is offline   Reply With Quote
Old 05-11-2009, 08:49 AM   #31
Andy;
John
I was here.
Nobody asked the question.
Old 06-02-2014, 09:21 AM   #32
2015 25' FB Flying Cloud
Huntley , Illinois
please see my issue I just posted about a bolt shearing off our equalizer hitch while towing our 22 fb sport. We had much noise these last tows. we will call equalizer for feedback. this occurred after the noise became very excessive
cegardner is offline   Reply With Quote
Old 06-02-2014, 11:08 AM   #33
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, which bolt? Do you have a picture of it? Have you maintained your hitch, cleaned, and lubed where necessary?
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-03-2014, 06:00 AM   #34
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Equalizer Hitch noise...
Typically the noise generated from an Equal-I-zer brand hitch is generated from the L bracket as the bars slide along in its mounting. I've checked the pivot bolts next to the head annually and have only had to torque them to specs once in the 10 years I've owned this hitch. That was when the hitch was fairly new and was still breaking in.
Prior to owning this hitch, I used a Reese dual cam hitch. The hitch bars that sit in the dual cam saddle also creak and moan in slow speed turns as they slide through the saddle. The Equal-i-zer is louder than the Reese but the friction is what you want. It is not unusual for these to make noise when backing or driving slowly through a campground and is not always an indicator of something being too loose. Just make sure you inspect the pivot bolts and torque them to specs. Check the brackets mounted to the a frame of the trailer and make sure they are tight.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-08-2014, 12:20 PM   #35
2014 22' FB Sport
Atlanta , Georgia
So, beyond mere NOISE, I have damage to the small hitch where the friction bar attaches to the trailer hitch. The cup on the forward end of the friction bar is compressed just enough that I can't get it off the ball, and the ball is pushed slightly forward. I might have done this when I was backing into my driveway, and perhaps because I really tightened down on the tension. But in any case: do I need to replace both that little ball and also the piece of the tension bar that's on the inside?
Belbein is offline   Reply With Quote
Old 06-08-2014, 01:44 PM   #36
jcanavera's Avatar
Fenton , Missouri
Images: 143
Unless things have changed it sounds like you do not have an Equal-i-zer branded hitch. This brand of hitch does not require any adjustments for tension. You might identify your brand of hitch so that someone knowledgeable can help you.
Jack
Jack Canavera
STL Mo.
AIR #56
equalizer hitch - any negatives? spikesss Hitches, Couplers & Balls 126 02-10-2016 09:05 AM
equalizer hitch steviebam Hitches, Couplers & Balls 9 08-10-2008 06:49 AM
equalizer hitch chaunceyboy Hitches, Couplers & Balls 9 06-14-2007 01:02 PM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 11:48 AM
Need used equalizer hitch lebolewis Hitches, Couplers & Balls 5 05-22-2006 09:41 AM
