Old 12-30-2014, 11:47 AM   #15
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
I know the Big Horn Mountains well. Some decent trailer camping off the highway at elevation, making it a wonderful breather... until going down.
I keep my speed with the Tundra 5.7L at 50 to 60mph and in 3rd. Sometimes if I am using the trucks brakes more than I want, I will manually apply the trailer's brakes... but they are minimal in effect. The Big Horn Mountains of Wyoming are a challenge. Just stay at a speed you are comfortable. After this practice... most other highways with big drops in a short distance will seem easy.
Buffalo, Wyoming... home of Sheriff Longmire, Wyoming County 24 plates and home of the Author that Longmire is based upon. By the way... there are only 23 counties in Wyoming. And the "Rez" has to be the Wind River Indian Reservation way WEST which has two small Casinos. Close Encounters of the Third Kind also used the Wyoming County 24 plate when the Aliens arrive at Devil's Tower... that looks nothing like the movie's version... but only those from Wyoming know.
Ray Eklund is offline   Reply With Quote
Old 12-30-2014, 06:23 PM   #16
2014 25' Flying Cloud
Dexter , Maine
All internal combustion engines have some type of "throttle plate" you have to regulate the intake of air into the engine. More air = more fuel = more power. A diesel without a "exhaust brake" will still use the engines compression to resist acceleration. Diesel engines are a more effective engine brake because of the higher compression (2x or more than most gas engines)
Always followed a simple rule that whatever gear I needed to climb a hill was the gear I used to descend the other side. Both climbing and descending are fighting gravity, in theory the work load to maintain a given speed should be similar.
Dexterpix is offline   Reply With Quote
Old 12-30-2014, 06:39 PM   #17
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Not sure what diesel engine(s) you are referring to, but I disagree if you are including my 1995 PowerStroke in that comment. I don't have an exhaust brake yet and there is hardly any engine braking. Wayyyyy less than any carburated vehicle I've ever driven. In gear, heading downhill with my foot off the pedal, the engine is basically just acting as an air pump..... breathing in air, passing it straight through the engine. At a certain point, the injectors are not even firing, which is real strange because of how quiet it is as the vehicle continues to pick up more and more speed. An exhaust brake is needed to create some back-pressure to help slow things down, otherwise you need to use the brakes to slow down.
Edit to add: my truck has an automatic transmission. Otherwise, with a standard transmission, I could use the transmission to help slow things down, to an extent.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 12-30-2014, 07:10 PM   #18
jcl
Vancouver , British Columbia
All spark ignited engines have some form of throttle plate. Not true for compression ignition engines. Thus, diesels have no significant retardation effect unless fitted with an auxiliary brake such as a Jake or other design. Compression ratio doesn't enter into it as the work to compress air on the up stroke is returned on the piston down stroke.
jcl is offline   Reply With Quote
Old 12-31-2014, 01:10 AM   #19
2005 19' Safari
GLENDALE , AZ
Link to explanation of how a diesel engine "Jake brake" works:
Compression release engine brake - Wikipedia, the free encyclopedia
Old 12-31-2014, 06:39 AM   #20
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
We have had an F150 Eco Boost as well as F250 6.7 Diesel and now F350 6.7 Diesel. The F150 did an admirable job towing, a fair to poor job braking on long steep down hills, as any gas powered vehicle would do towing 9,000 pounds. The F250 and F350 are identical except in load carrying capacity and therefore their engine braking and braking in general are identical as well. Both the diesels can slow our rig(s) down on most hills with only an occasional use of the actual brakes. The engine gets up in RPMs, but have never reached the danger level.
As to methods, the CDL drivers test and recommendations for commercial drivers is to slow down at the top of the hill to the speed limit posted OR a little under so one is starting the decent at a reasonable speed. Then using all braking available, engine, jake and foot activated brakes keep to the posted limit and when the speed increases by five miles per hour slow down by using the foot brakes to the speed limit or slightly under. Both my wife and I have CDL licenses and we use this method with our truck and AS and it works, now with our gas powered SOB motorhome out west it's a whole different story, white knuckle even on I70 going towards East getting to Moab was an interesting experience to say the least. But joyous day the MH has been sold and we are awaiting pick up by new owner.
To summarize, the F350 Diesel with engine brake towing the 30' AS is a joy to drive, down hills are not really a big issue with this set up (A 3/4 Ton would give the same results, except with added payload and 20" tires we get a little less bed sway on tight turns going down hill).
Happy New Year to all.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 12-31-2014, 07:56 AM   #21
Dexter , Maine
When you shift to a lower gear the braking effect is from the engines mechanical resistance, not from inside the transmision. The transmision does not create enough resistance to have a braking effect. A transmision disconected from the engine can easily be turned over by using a wrench by hand. The engine without heads in place can also be easily turned over by hand/wrench. When the heads are in place and compression is created then you have to overcome the resistance of the engines compression to rotate the internal mass of the engine. The high the compession the greater the resistance. This creates the braking effect. All interernal engines need a device (plate, buttefly, throttle body) to regulate the incoming air that is the basic function of an engine (air in = air out) restrict either one and you choke the engine from functioning. Jake brakes are a company name that has become the genral name of any exhaust brake added on to the exhaust side of the engine. Most modern large diesel engines employ "Compression braking" and utilize variable valve timing to restrict the exhaust flow out of the heads prior to it entering the exhaust manifold. Compression resistance is the only mechanical resistance strong enough when combined with gearing to give the braking effect. Yes if you do not shift to a lower gear the rolling resistance will not increase the engine rpm enough to effectively cause the braking effect if you do not have an exhaust type brake installed. Down shifting will increase the RPM and thus the resistance of work load the engine can product.
p.s. I have worked on heavy equipment diesel engines for over 30yrs.
Old 12-31-2014, 08:10 AM   #22
2008 31' Classic
Lake Charles , Louisiana
I recently had to use the tow/haul feature on my F-250 diesel when my Dexter 1600 actuator failed and I had to disconnect power to it which left me no trailer brakes. We were in the Ozarks in Arkansas and I had never had a need to use the tow/haul feature. I was really surprised at how well it worked. It worked so well the RV behind me (my 85 year old dad and mom)complained my brake lights were not coming on enough and it was really messing him up on when to brake. These were the first hills we had really gotten into with the F-250 and our 31ft. Classic. I felt totally comfortable in the ability of the truck to handle the trailer without any trailer brakes. I made sure I allowed for extra distance when in traffic. Since then I have replaced the brake actuator and all is good :-)
Steve & Mary is offline   Reply With Quote
Old 12-31-2014, 01:38 PM   #23
jcl
[COLOR=black] All internal combustion engines have some type of "throttle plate" you have to regulate the intake of air into the engine. More air = more fuel = more power. A diesel without a "exhaust brake" will still use the engines compression to resist acceleration. Diesel engines are a more effective engine brake because of the higher compression (2x or more than most gas engines)
Well, the OP wasn't asking about a diesel, but this should be corrected.
Agree the retardation effect is from the engine, not the transmission.
However, compression doesn't enter into it (unless a compression release brake is employed) since the work to compress the air in the cylinder is returned on the downstroke. It is just a spring.
With a gasoline engine, the air restriction at the throttle plate provides a choke that creates retardation. It takes work to force air past that restriction.
Diesels simply don't have that restriction. As much air as ambient air pressure, or the turbos, can force into the cylinder, enters the cylinders. Fuel is controlled for purposes of throttle, not air volume.
Compression only matters for retardation if there is a compression release around TDC, like a Jake brake, to release the compressed air. Not applicable to trucks towing Airstreams.
Modern diesel pickups wil have next to no retardation from the engine itself. They may have an exhaust restrictor, factory or aftermarket, that works like a choke to create retardation, but on the exhaust instead of the inlet.
Modern diesel pickups with pollution controls such as EGR and particulate traps have inherent restrictions due to these devices, making them act more like a gasoline engine. There is also the effect of any variable vane turbos. But this is exhaust braking, not engine braking, IMO. Perhaps not a significant difference.
PS. 24 years in the Car dealer network, plus time spent developing fuel systems for over the road (class 8) and larger off road trucks.
Old 12-31-2014, 02:02 PM   #24
1974 Argosy 20
Kooskia , Idaho
Originally Posted by BoldAdventure View Post
Actually, the 5.7L Hemi Ram features a form of engine braking, basically the computer tells the transmission to down shift automatically when in tow/haul mode when the brake is applied. It works incredibly well.
Since most folks ignore the USE LOW GEAR signs, it basically does it for you, thus slowing the vehicle. But only when tow/haul is engaged. It will do it without apply the brake too, I'm not sure how it senses it. But coming over a hill today, I took my foot off the gas and the engine brake engaged while going down the hill.
My 2102 Jeep Grand Cherokee with the 5.7 hemi and 6 speed auto has the tow/haul mode which I use virtually all of my towing time. I live in an area of long steep grades. It is amazing to me how well the braking works, all automatically. I come over a pass crest and down the other side. I touch the brakes lets say at 45 mph, and the Jeep seems to automatically try to keep that speed as max by automatically downshifting to hold the speed. Occasionally I have to further brake, but for the most part the tow/haul setting and how the computers are set do all the slowing by gear shift and compression.
I went down a 6/7% 10 mile grade with the FC 20' behind me and only touched the brakes twice more after the initial time. I have no idea what gears were being used, as that does not show up on any readout, but the effect is very impressive.
If you have a Tow/haul mode on your rig, no matter who makes it, give it a try to see if it essentially does the work for you. The Jeep certainly does.
Old 12-31-2014, 03:25 PM   #25
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
Idroba is right on. Towed our Pete a 27fb 150 miles today with our 2014 F150 5.0 over some Florida grades 😄. Just put it in tow/haul tap the brake going down and let it handle the shifting.
ShinyPete is offline   Reply With Quote
Old 01-01-2015, 10:19 PM   #26
1975 27' Overlander
High River , Alberta
Originally Posted by sandrade View Post
So, my questions are....how does engine braking work? Can ones engine really survive the RPM's of being pushed down hill by a TT? What is the best approach to truck brake, engine brake, and trailer brake combo?
Came down the Big Horn Pass, WY this summer and was shocked at how much gravity influences the whole rig. I mostly kept it in control. At the bottom ran into another RV'er who proclaimed his awe and said he was turning around and going back to Maryland after that ordeal. I rode my rig down in 2nd gear, avoiding 1st in fear I would explode the engine. Alternated truck and trailer brakes, but avoided all out foot stomping. I have a 2013 Ford F150 8 cyl. auto, 2013 International Signature 23'. Any recommendations about how to safely handle steep downhill grades without burning out the brakes? thanks!
When you live in flatland areas, you can avoid ever revving a vehicle's engine past 2500 rpm, if you drive gently. It's very different in the mountains. We have gotten quite accustomed to holding lower gears with the engine spinning in the 4000+ rpm range while climbing or descending, and no longer think anything of it. I have never detected any harm as a result.
You probably needed first gear on that descent. I think you would find a major difference between 2nd and 1st in terms of engine braking. Crest a hill slowly, so you have time to manage your speed and determine what gear you need to be in. Mountain driving is not difficult or dangerous, as long as you are patient and thinking ahead. And don't worry about being slow; there are lots of trucks and older motor homes that are slower than you, and the locals will understand.
AlbertF is offline   Reply With Quote
Old 01-01-2015, 10:49 PM   #27
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my Lincoln does a good job of engine braking; I have gone down many mountain roads with little or no use of my brakes to maintain a safe speed. In the past, I have done things with automatic transmissions that would make you cringe. You can manually shift your trans into first gear at 100 miles per hour and it won't hurt anything. It will down shift to a proper gear at the right time and not sooner. You can also lock your trans in first gear while going down a steep hill and when your engine hits a certain RPM it will upshift on you.
My new F-150 Eco-Boost has Tow / Haul mode and will down shift when you touch the brakes going down hill to help maintain your speed. I don't have a new shank yet, and I don't have enough miles on it for towing duty yet. It has been a concern as to how much engine braking the 3.5 L engine will do. My Lincoln's 5.4 L engine holds my trailer back just fine. I will report on how the Eco-Boost does when going down hill when I get to that point.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-03-2015, 08:45 AM   #28
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
The last time I towed an Airstream with a V8 in the mountains was about 30 years ago everything since has been with a V6 think you will find you need the run the 3.5 about 6-800 RPM higher to get the same amount of braking from it.
The two extra gears and the lower first gear ratio will give you a better operating range and first gear will give you just as much total breaking.
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Losing engine elec. engine dies while driving ccgartman Airstream Motorhome Forums 4 12-10-2011 08:46 AM
Diesel Engine Braking guy99 Mechanics Corner - Engines, Transmission & More... 5 02-10-2006 01:42 PM
Toad Saturn braking questions pbnjsellers General Motorhome Topics 5 06-02-2005 07:49 AM
Braking systems question? zduke4x General Motorhome Topics 7 03-29-2004 08:05 PM
