Old 08-30-2015, 01:35 PM   #1
2015 25' FB Flying Cloud
Huntley , Illinois
electrical power in Canada
we are planning an extensive trip through out Canada. is there an issue with the electrical like the differences in Europe?
cegardner is offline   Reply With Quote
Old 08-30-2015, 01:41 PM   #2
cameront120's Avatar
1972 25' Tradewind
Yes, we have it. And yes, we use the same outlets as you. No converters necessary.
North Vancouver, BC
Old 08-30-2015, 01:50 PM   #3
dznf0g's Avatar
Oswego , Illinois
Really!?!?!? When did you get it. (juskiddin')
-Rich-
Old 08-30-2015, 02:29 PM   #4
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . we just stayed in several Canadian campgrounds on the way to & from Alaska. No power problems for us. Regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 08-30-2015, 03:33 PM   #5
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Yes we have the same voltage as you, give or take a few volts. Brown outs do occur if and when the bicycle generator guys start to tire but at least Ontario hydro have the team switch overs down to a science.
One thing of note, just like North Korea, to give the generator bike guys a break we turn out all lights, TV's which only work in the cities with rabbit ears and all other electrical devices at 9:30 pm and power up at 7:00am.
Enjoy your stay in the cold snowy Great White North.
Cheers
Tony
PS Remember snow chains are mandatory, except in the cities which do allow studded tires.
This was written on an IBM XT computer. Hopefully next year I'll be upgrading to a Pentium.
Old 08-30-2015, 05:02 PM   #6
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
It's already been alluded to (both seriously and in jest) but the only difference is that in some parts of Canada they call it "hydro" because that's part of the name of the public utility. 60 hz and nominally 120v.
— David
Old 08-30-2015, 05:13 PM   #7
Dazed and Confused
Isuzusweet's Avatar
Canadian summer sports. I jest you not!
Cheers
Tony
Old 08-30-2015, 05:13 PM   #8
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Cheers
Tony
George
gandttimes is offline   Reply With Quote
Old 08-30-2015, 05:15 PM   #9
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Cheers
Tony
Whoops, the guys on the bikes didn't make a timely switch and only part of the message was sent.
George
Old 08-31-2015, 11:22 AM   #10
Gordon
2014 30' International
Scarborough , Ontario
One thought to consider if you have a Honda 2000 generator. You'll need two of them to operate your ac - and one of the pair must be the "companion" version connected together with the special kit.
Be sure to buy your "companion" generator and the connector kit in the U.S. as they are not sold in Canada.
Gmoore is offline   Reply With Quote
Old 08-31-2015, 05:12 PM   #11
macofpei's Avatar
2003 30' Classic
Stratford , Prince Edward Island
Send a message via Yahoo to macofpei Send a message via Skype™ to macofpei
Check the Internet. Canada is a civilized country, just north of your country. We share the same electrical grid.
You will also find most campgrounds even have sewer connections..
Mac from PEI
Canada
WBCCI #4782
"Southern Belle"
'03 Classic 30'
'10 Toyota CrewMax
macofpei is offline   Reply With Quote
Old 08-31-2015, 05:36 PM   #12
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Be careful of your electronics in Canada. Their AC power is backwards from ours. Positive when it should be negative. And negative when it should be positive.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 08-31-2015, 06:00 PM   #13
DKB_SATX's Avatar
1976 Argosy 28
And back again. 60 times per second.
— David
Old 08-31-2015, 06:54 PM   #14
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
HuH???? what part of England did you come from????
As someone above stated; "We share the same grid as you guys"! The polarity doesn't switch at the border. But be advised that some campgrounds can have voltages down to 108 VAC. as depicted on the cute little wall plug-in gauge.
Brownouts??? Possibly! And the "NIMBY'S" still bitch about wind turbines, and solar panels.
MelGoddard is offline   Reply With Quote
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
Canada border crossing and power tools Bo2020 On The Road... 21 05-26-2011 08:16 PM
