Old 03-26-2012, 01:34 PM   #1
1968 26' Overlander
Durham , North Carolina
Electrical hookups at campgrounds...
Hope this is the right place to ask this...when looking at campgrounds with electrical hookups I see Electricity Hookup: 50. Does this mean I will not be able to hook up my 30 amp service? Just not obvious to me...and electricity ain't my thing.
Thanks.
goswick is offline   Reply With Quote
Old 03-26-2012, 01:43 PM   #2
Frank&Mike's Avatar
2016 27' Flying Cloud
Georgetown , Texas
I Asked Similar Question
A couple years ago when I was new to all of this I asked a similar question. See the following thread with various replies:
http://www.airforums.com/forums/f449...ant-53004.html
Frank&Mike is offline   Reply With Quote
Old 03-26-2012, 01:46 PM   #3
2007 27' Safari FB SE
Wheat Ridge , Colorado
the 50 means 50 amp service. you can hook your 30 amp plug up to it if you have an adapter. the adapter has a 50 amp plug on one side and a 30 amp plug on the other. plug the adapter 50 into the 50 amp service and your 30 amp plug into the other side of the adapter
The Driver is offline   Reply With Quote
Old 03-26-2012, 01:51 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Every place that I have camped that had 50amp service also had a 30amp outlet. There may be some that only have a 50amp outlet, but I have not found one yet.
Richard
Old 03-26-2012, 02:37 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I'm with Richard on this one...we have never seen a site that had 50 amp that did not also have a 30-amp outlet... BUT if you do run into the situation where there is only 50 amp, you can use a 50amp-to-30amp-converter plug... We carry one but have never had to use it.
TB & Greg and Abbey Schnauzer
#3954
Old 03-26-2012, 02:42 PM   #6
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I have stopped two places that had only 50 amp service. Both places had previously been mobile home parks. In both cases, I was warned when I made reservations that I would need a 50 to 30 adapter.
BTW. I often use the 50-30 adapter even when a 30 amp outlet is available. If you plug in to 50 amps with the adapter, you will never pop the outside breaker if someone accidentally happens to start the microwave with the electric WH and the AC/heat pump running. This has saved me a trip outside several times in the past.
John W. Irwin
WBCCI #9632
Old 03-26-2012, 02:55 PM   #7
dznf0g's Avatar
Oswego , Illinois
Bingo! X2 on having found 50A only at a couple of parks.....and I was too lazy to post the using the 50A even when a 30A is right next to it for the same reason above!
-Rich-
Old 03-26-2012, 02:57 PM   #8
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Like John, we use our 50-to-30 whenever this is 50 amp service. Just another layer of protection and comfort.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 03-26-2012, 03:56 PM   #9
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Should you have the rare occasion to have only 50amp service just purchase a 50 to 30 pigtail and plug it in. Very easy. Have fun.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 03-26-2012, 04:28 PM   #10
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Lucy has hooked-up at hundreds of different campgrounds. Only once did we run into a site with only 50amp service. That is the one and only time that I have used my 50amp to 30amp adapter pigtail.
Brian
SuEllyn & Brian McCabe
Old 03-26-2012, 05:09 PM   #11
Wise Elder
Jammer's Avatar
2010 30' Classic
Thanks.
Well the question comes up often. Here's what a typical 50 amp pedestal in a campground looks like. Lower left, 50 amp. Lower center, 30 amp. Lower right, 20 amp with GFCI. Above them are the circuit breakers, a pair for the 50 amp outlet, and one each for the 30 and 20.
Old 03-26-2012, 05:11 PM   #12
Wise Elder
Jammer's Avatar
2010 30' Classic
So in most cases that's what you get and you can plug in anything.
I've heard reports of 50a-only pedestals but have never seen one. The people who have say that the office at places like that usually has adapter plugs you can buy or rent.
More common is the situation where the 30a receptacle is worn or broken from frequent use, so that if you have a 50a adapter you can plug in there instead.
Old 03-26-2012, 06:14 PM   #13
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, we always carry a 50 Amp adapter and have used it twice. In the picture, it was 50 Amp or 20 amp only.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-26-2012, 07:25 PM   #14
2010 25' FB Flying Cloud
Davenport , Iowa
I also carry a 50/30 adapter; but I kick it up a notch by also using a "Surge guard". As luck would have it, the campground where I was had an electrical problem and one of the campers cord burnt. I had just got the surge guard. (30 amp)
Airtandem is offline   Reply With Quote
Switches at door batt Lights - Interior & Exterior 4 10-24-2012 07:07 PM
Bob Wheeler at The Motorhome, Caravan & Camping Show at London's ExCeL WK57ABF Airstream "In the News" 9 03-25-2012 04:41 PM
Went to look at AS for the first time farmerdave Buyer Guidelines 11 03-25-2012 02:04 PM
Noob looking at a 31' '77 AS 270win 1974 - 1979 Sovereign 61 03-23-2012 10:13 AM
