Old 03-05-2016, 07:08 PM   #1
firstwave's Avatar
2006 30' Classic
Santa Fe , New Mexico
Electrical Help
Stopped in Santa Fe this evening and my furnace,fridge and exhaust fans have no power. I've checked breakers and seem ok. Anyone have any idea what could be the problem? It's going to be a cold night with no heat
firstwave is offline   Reply With Quote
Old 03-05-2016, 07:28 PM   #2
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
I thought the breakers are for your 110 items. The stuff that is not working are on fuses so I would look at your panel again and check the fuses. If they appear ok, pull them in and out in case they are corroded. Jim
Jim Flower is offline   Reply With Quote
Old 03-05-2016, 07:54 PM   #3
firstwave's Avatar
2006 30' Classic
Thanks Jim. One of the 12 volt breakers had tripped. Thanks to you we'll be warm tonight.
Old 03-05-2016, 07:59 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Do you have any 12v power at all? Lights, water pump, tongue jack?
Make sure your batteries are delivering 12.5 volts up to 12.9. Maybe you have low batteries for some reason. I hope you have a volt meter handy.
If you are connected to shore power, make sure your batteries are receiving about 13.3 volts and even up to 15 volts charging from the converter.
Make sure the cables to the batteries are not loose.
If the batteries are charged, and the converter is delivering voltage to the batteries and thus the 12v system in the trailer, then you have to dive into the 12v fuse panel and verify every fuse is ok, not blown. If you find a bad fuse, replace it with the same amperage fuse.
David
Old 03-05-2016, 08:35 PM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
My 2001 Safari had fuses. My 2002 Classic has breakers for 12 V.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 03-06-2016, 06:16 AM   #6
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Al
Clearly, one should not assume. My 2012 has breakers for the 110 v and fuses for the 12 v. It would appear that the problem was found and the op had a warm night. All is good. Jim
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
HELP! Electrical problem FranceyS Electrical - Systems, Generators, Batteries & Solar 6 08-03-2010 02:57 PM
IVOLT?electrical questions. Please help! chasgould Electrical - Systems, Generators, Batteries & Solar 4 12-04-2003 06:01 AM
electrical help. poorboycjs Electrical - Systems, Generators, Batteries & Solar 1 09-16-2003 08:53 PM
Need help!-Finding thread about electrical cord. WayWard Wind Our Community 5 03-25-2003 07:37 PM
