Old 01-01-2016, 07:44 AM   #1
1996 34' Classic
FordTruck's Avatar
1996 34' Excella
Locust Grove , Virginia
Images: 8
Educate me on 'Wide Body'?
Please educate me. In reading about some older 70's and 80's 30-34ft trailers, I have come across the term 'Wide Body'. Having owned a 2003 (8ft wide) and a 2008 (8.5') wide, am I correct that when a trailer is designated as 'Wide Body', it is 8.5' wide? Is there a clue in the VIN?
FT
FordTruck
2016 GMC 2500HD Denali (Betsy 4)
1996 34' Excella 1000 (Arvin3 as this is our 3rd AS)
2010 TREK 2.3
Fair is where they put ribbons on pigs.
FordTruck is offline   Reply With Quote
Old 01-01-2016, 07:48 AM   #2
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
The clue is in the tape measure. At 8.5' it's a wide body. Started in 1995 making some that width.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 01-01-2016, 08:02 AM   #3
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Add to Shacksman's post that "wide body" is also 25' and above.
When you see or go inside a vintage trailer the narrower body is more apparent. There is more curve on the roofline and less flat area on the ceiling. Wide body, I am told are all models from 25' and above which, I guess began around 1995 though from the archive, it looks like from 95-98 they were settling on which models would be wide or not. It looks like, from 1998 forward the under 25' were narrow and the 25' and above were wide.
There is just more headroom and inside space and yes, there is 6" more width (8.5')
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 01-01-2016, 08:01 PM   #4
1996 34' Classic
FordTruck's Avatar
1996 34' Excella
Images: 8
Thanks for confirming what I thought I knew
FordTruck
2010 TREK 2.3
Old 01-02-2016, 08:18 AM   #5
Chasmorgan's Avatar
1999 23' Safari
Our 1999 23' Safari is designated a wide body!
Charlie M
TAC TX-6
Chasmorgan is offline   Reply With Quote
Old 01-02-2016, 02:18 PM   #6
1996 25' Excella
Tillsonburg , Ontario
I understand they also make a narrow body version for export to Europe. From 1995 and later, is my understanding of the date they started making the trailers wider, which also corresponds with the wider flatter roof line. This is the easiest way to determine wide or narrow.
JCW
JCWDCW is offline   Reply With Quote
Old 01-02-2016, 05:41 PM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
In 1984, the Federal Government established 8' as the maximum allowable width for vehicles and trailers on US Highways and Interstates, with anything wider being considered oversized. This corresponded with the Federal Highway Administration's standard lane width increasing from 10' to 12', by the way. Not all states increased their maximum allowable widths to match; there are still a few states even today where the maximum permissible width on State highways is only 8', and anything wider legally must be towed during daylight hours only as a non-permit-required oversized load. But I've never heard of an RV owner being ticketed; it's normally only commercial drivers who bear the burden of state enforcement of width restrictions.
When the majority of states were increasing their maximum allowable width, it was common for trailer manufacturers in all fields, not just travel trailers but also semi-trailers, farm trailers, etc. to advertise "Wide Body" if their trailers were over 8' wide.
Once the industry had caught up with the change, and 8' became the standard width rather than a new feature, it was no longer necessary to advertise "Wide Body"; it's just assumed in a lot of cases, but some manufacturers still use the designation.
Side note, the measured width does not include "appurtenances" such as awnings (or side mirrors for vehicles) so the total width can be greater than 8'.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-04-2016, 10:50 AM   #8
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Easily visible/detectable if you can see the end caps.
The wide body end caps are wider and less curved.
The roof line isn't as rounded/crowned- it is more flattened out.
Really easy to spot with a bunch of trailers at a rally parked side by side-
Easy to tell which are wide body and which are not-
Another easily detectable difference:
The pre-wide-body trailers have many, many more rivets both horizontally and vertically along the ribs and cross members. I think they use an adhesive in lieu of rivets now.
Also, the pre-wide body trailers have an aluminum band around the windows and some have a nice extruded aluminum rear bumper storage lid.
If you ever enter both styles side by side, the difference is obvious inside, too. The older, non-wide-body trailers are obviously narrower, more rounded from the inside as well.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-04-2016, 08:12 PM   #9
2006 25' Safari
Images: 8
Yep, you are right- 8' 5.5 inches according to the spec sheet. Wow. It looks like they made the 23' wide bodied through 2002 then dropped it a few years. When It returned it replaced the 22' narrow bodied model as a 23' narrow bodied trailer. So that would mean that it started out as a wide body in 1999-2002 then later models became narrow bodied.
Old 01-04-2016, 09:01 PM   #10
Southwestern , Ohio
For what it's worth, 50s and early 60s Airstreams were typically 7 1/2 feet wide. Later Airstream went to 8 feet and 8 1/2 feet, but over the years they have continued to make a few 7 1/2 foot "narrow body" trailers. The 1980-81 Caravelle models were 7 1/2 feet wide, as is the current Sport 22.
Nuvite-F is offline   Reply With Quote
Old 01-15-2016, 12:33 PM   #11
Glenn T's Avatar
2011 20' Flying Cloud
Lemont , Illinois
The current Sport 22 model is a narrow body. It's listed as 7' 3.25".
Glenn T is offline   Reply With Quote
Old 01-15-2016, 01:20 PM   #12
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
wide body paper spec is 8" 5.5. In reality, it is wider. I had my new drive way gate built a month before getting my AS. The clear aperture is 9" dead.
The awnings and lights and anything that sticks out from the outer skin is not included in that 8" 5.5.
Due to my driveway it was not possible to make the gate any wider. So we do not park behind the gate...I was pissed. I mean really pissed.
I am sure a better driver could get through the gap, but I am done trying.
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Rear-end Sag, Educate me please! lebolewis Buyer Guidelines 16 08-13-2007 11:52 AM
Narrow body/Wide body jcanavera Our Community 11 04-05-2006 01:25 PM
Wide body? ipso_facto Airstream Trailer Forums 7 11-08-2004 01:00 PM
3 states don't allow wide-body trailers! yukionna On The Road... 9 04-30-2004 11:46 PM
