Old 04-19-2004, 01:30 PM   #1
Oregon City , Oregon
Cool Dual Cam Anti-Sway
I want to install the Dual Cam Anti-Sway system on my 1965 22' Safari. My concern: I will need to drill into the frame to install the frame brackets and don't want to damage the electric cord inside frame. Any suggestions?
Darrell
Roswell is offline   Reply With Quote
Old 04-19-2004, 02:08 PM   #2
gregg's Avatar
Dual cam install
everything bolts on to the frame.
gregg is offline   Reply With Quote
Old 04-19-2004, 02:27 PM   #3
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Go ahead and drill
I would recommend the new HD Dual Cam which is an impressive set of bronze castings. It does require drilling, but I far prefer that for a permanent installation to clamp-on hooks. Also, with the bolt-on, there is never any interference with the tanks, battery boxes, or whatever may be on the A-frame.
There are wires in the street-side frame. I simply used a long cedar shim inserted from the front of the frame to hold the wires out of the way while drilling. You can leave the shim in place to prevent the wires rubbing on the end of the screws, but my wires didn't touch the screws when I was done.
John W. Irwin
WBCCI #9632
Old 04-19-2004, 04:43 PM   #4
Thumbs up This is why I joined!!!!!!
Thanks for the great tip. Installation: how difficult? I am handy but not a certified mechanic!
Thanks again
Old 04-19-2004, 04:45 PM   #5
Thanks, everyone!
Old 04-20-2004, 10:25 AM   #6
Pahaska's Avatar
Hays County , Texas
Installation took between an hour and an hour and a half including hitching up the trailer and towing a short distance to align the links after mounting the hardware.
Clamp the links in place, mark your hole locations, and start with a small drill bit and go to progressively larger bits until the holes are the proper size. use a shim of wood to get the wires in the street side out of harm's way before drilling. I used a 12v battery powered drill motor; if I had 120v available for a more powerful drill, it would have gone faster.
The instructions are pretty good.
John W. Irwin
WBCCI #9632
Old 04-20-2004, 01:20 PM   #7
Thanks John,
Your support and knowledge is grand. May all you travel be safe and happy!
Darrell
Old 04-20-2004, 09:57 PM   #8
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I just did it a few weeks ago. I got a colbat tip drill bit and it took literally 30-45 seconds to chew a hole into the frame. One word of caution....measure 20x and drill once. Little room for error. Also, as an added precaution, I took some GE silicone caulk and sealed the brackets to the frame so that water would not get into the raw exposed steel that I drilled. Kind on excessive I know, but it took only a few seconds extra.
As for the power line, I didn't hit it when drilling, but the silicone calk also helped insulate the wires from the bolt.
Reese Friction Control or Dual Cam? donreitz Hitches, Couplers & Balls 34 06-24-2004 12:43 PM
Is dual cam better than friction sway control? Fogducker Hitches, Couplers & Balls 6 02-12-2004 09:37 PM
Reese dual cam sway - fit??? Craig Hitches, Couplers & Balls 4 06-18-2003 04:50 AM
friction vs. dual cam sway Craig Hitches, Couplers & Balls 8 04-29-2003 11:30 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
