05-31-2013, 06:16 PM
2012 27' Flying Cloud
W
, New England
Dometic fridge help?
Hi - good news - we're camping again this weekend!! Bad news - Dometic fridge is not cooling down. Have gone from auto to propane, turned up to 5 and it's still reading 60. Fridge is pretty full including cold food and some ice packs we traveled with. Any thoughts??? Thanks!!
05-31-2013, 06:20 PM
W
, New England
Also - I noticed some dripping outside near the city water. Felt with my fingers it's a drain - is that a drain for the fridge or AC condensation?
Should also mention we're plugged in to shore power and everything seems to be working including lights in the fridge and readout numbers.....
Should I open the fridge-freezer doors as the ac is cooling off the interior pretty well?
05-31-2013, 06:21 PM
W
, New England
I should also mention there is no manual for the fridge in my AS bag of manuals. :-(
05-31-2013, 06:25 PM
2012 28' International
Olympia
How long has it been on? It can take quite a while to cool off. You can feel the walls in the freezer and see if they're cold.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
05-31-2013, 06:36 PM
W
, New England
Thanks Daveswenson - the inside of the freezer walls feels cold (not freezing, but cold to the touch). So I'm guessing its just going to take a while to get from the 90s (as it was sitting in storage today) to something cool enough for food. It's been on for about an hour now and still reading 60. If it would just say 59 I'd be happy knowing its moving in the right direction!!! Thanks though - any other thoughts on the dripping near the city water? I'm thinking it must be the ac condensate...
2000 25' Safari
Davidson County
, NC Highlands County, FL
Leave the doors closed, if the temp inside the trailer is warmer than inside the fridge.
I always turn on the fridge the day before we leave to let it cool down. Mine may take 4-5 hours, or longer, to get cold.
You might improve the cooling if you open the exterior access hatch behind the fridge, to increase the draft.
Alan
05-31-2013, 06:38 PM
W
, New England
Thanks A W Warn. We'll leave the doors closed.
Should we go back to auto setting or will propane alone cool it faster?
05-31-2013, 06:45 PM
2000 25' Safari
Davidson County
my guess is propane would be faster
Alan
Naples
'on for an hour'............
That is your problem. Any RV absorption fridge should be on at least 8 hours prior to use to allow the unit to cool down properly. These units are extremely inefficient and take huge amounts of time to get the cooling process working. Further, you should only place pre-frozen or chilled food in them, even when they are operating at their normal temps.
Also, for every minute that a fridge door is open, the ammonia/hydrogen cooling unit requires one hour to replace the cold air lost while that door is open. This little factoid compliments of a one week tech certification and training course that I had the pleasure of attending from Dometic.
These fridges work nothing like a residential fridge that will get cool in an hour. Leave it alone and report back in the morning and hopefully the temps will be in the 30's by then.
Next time you take a trip, pre-freeze a few gallon water jugs and place a couple in the freezer and a few in the fridge during initial start-up. They will help the unit cool down much faster.
lewster
05-31-2013, 06:57 PM
2000 25' Safari
Davidson County
If you are near a source where you could purchase a small block of dry ice you may be able to get the fridge cold faster if you put some in the freezer. Our local grocery sells it.
Alan
05-31-2013, 07:01 PM
W
, New England
Excellent info! Thank you guys so much v. I'll check with the office an see what they have for ice. I'm guessing dry ice may be out of the question here but maybe some bagged ice cubes would help.
Thanks again. So much to learn!!! Next time:
1) level the trailer
2) relieve all WD tension for hitching
3) fire up fridge night BEFORE the trip!
4) make ANOTHER contribution to Air Forums!
05-31-2013, 09:41 PM
W
, New England
Ok. Fridge just hit 59!! We are making progress!! No dry ice but ice bags at the office here so we have the critical stuff in the cooler on ice and the fridge is finally getting colder.
Thanks again for all your help!!!
06-01-2013, 04:53 AM
W
, New England
And we're at 40 degrees this morning! Thanks again everyone!
06-01-2013, 05:36 AM
2012 23' International
Sevierville
, Tennessee
Great to hear the good news! One of my "favorite mods under $100" was a $10 remote thermometer from Walmart. It has a large display that shows indoor temp and outdoor temp via a remote sensor. I put the remote sensor inside the refrigerator rather than outside the trailer. This helps me monitor the temperature inside the refrigerator and I don't have to open the door. I also replaced the incandescent festoon bulb in the refrigerator light fixture with an LED bulb from www.led4rv.com to help keep the temperature from increasing inside. This little thermometer has been a real education by seeing what the effects are of having the door open or putting warm leftovers back inside.
Ho'onanea (Ho Oh Na Nay Uh) -- to pass the time with peace, ease, and pleasure.
06-01-2013, 07:30 AM
2008 27' Classic FB
Burkburnett
Originally Posted by SteveSueMac
... any other thoughts on the dripping near the city water? I'm thinking it must be the ac condensate...
The A/C has a drain tube that typically exits in the street side wheel well. It normally drips any time the A/C is running and may release a burst of water when the A/C cycles off. The fridge also has a drain tube that most often exits at the bottom of the fridge outside access/vent door. The condensation will drip down the side of the trailer from the bottom of the door. This only happens if the fridge cycles off long enough for the frost buildup on the cooling fins to melt (not often) and when the fridge is switched off and defrosts.
Any other drips need to be investigated. Many times it is a water line connection that needs to be tightened. Access on yours may be through the closet floor. Look at the clamps on the water inlet tube and the hand tightened fittings around the water pump.
If this is where the city water connects below the floor, there are fittings behind the metal panel that can be accessed by removing a few screws.
AIR 47751
06-01-2013, 07:39 AM
1964 19' Globetrotter
South Kingstown
, Rhode Island
I imagine a lot of RVers go through that shock the first time they start the fridge. I either start our fridge the day before, where it's stored or park it in the driveway overnight with the fridge going before we leave, and then put a lot of cold food in it.
Wherever you go, there you are
06-01-2013, 05:52 PM
Olympia
Originally Posted by Hoonanea
Great to hear the good news! One of my "favorite mods under $100" was a $10 remote thermometer from Walmart. It has a large display that shows indoor temp and outdoor temp via a remote sensor. I put the remote sensor inside the refrigerator rather than outside the trailer. This helps me monitor the temperature inside the refrigerator and I don't have to open the door. I also replaced the incandescent festoon bulb in the refrigerator light fixture with an LED bulb from LEDs 4, Recreational Vehicles to help keep the temperature from increasing inside. This little thermometer has been a real education by seeing what the effects are of having the door open or putting warm leftovers back inside.
But how can you tell if the light's off when you shut the door? Maybe a remote camera!!:
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
06-02-2013, 05:30 AM
Sevierville
, Tennessee
Well, funny you ask. . .
My refrigerator is one of the small ones that has two vents on the exterior sidewall and no roof vent. Which means it also does not come with an interior light. I bought the parts online and installed it myself. To test the placement of the switch to make sure the light turned off with the door closed, I put my iPhone in movie mode, set it on the shelf inside, closed the door, then watched the movie! ;-) Darkness in the middle of the short video confirmed I had the switch in the right place.
But methinks you were just kidding with the question. . .
06-02-2013, 07:07 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
a related thread talks about a second function of the fridge interior light. i would have quoted lewster himself but i found this thread first :-)
http://www.airforums.com/forums/f425...ved-79785.html
Ricky
06-02-2013, 07:28 AM
Naples
Originally Posted by richinny
Not all Dometic fridges have them, but many have what is called a 'low ambient temperature switch' located on the frame right above the top of the fridge door. This switch is designed to keep the interior light on in very low ambient temps, causing the interior of the fridge to heat up and force the cooling unit to operate. This is done to keep the food in the freezer section well below 32ºF.
If you intend to travel anywhere the ambient temperatures are expected to be below 40ºF, this function will do nothing to keep your fridge running IF you have removed the OEM incandescent bulb, as LEDs produce almost no heat. OTOH, if you never plan on being in any type of cold weather, or do not have the low ambient temp. switch, them LEDs will work fine.
lewster
