07-09-2016, 01:16 PM
Coast to Coast
2016 26' Flying Cloud
Winston Salem
, North Carolina
Dometic AC - Lo Med High
Our 2016 26U has ducted air (thankfully!) but there is no audible sound difference in the Lo, Med, or High settings on the Fan when set to Cool. Should there be?
07-09-2016, 01:18 PM
Coast to Coast
Winston Salem
, North Carolina
BTW. Don't you love Auto Correct? Dometic.
07-09-2016, 02:29 PM
2014 30' Flying Cloud
Tampa
I had a similar issue with my non-ducted 2014 AC. I did a thermostat reset per the user manual, and the problem was fixed.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
07-09-2016, 04:07 PM
Retired.
, At Large
Simply set the fan to "auto". It will then turn off when not needed, instead of endlessly droning 24/7.
07-09-2016, 04:33 PM
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach
In my 2015, I can usually hear a slight change in sound between the low and high fan settings, if I'm right under the unit. Joe
07-09-2016, 05:13 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
The auto correct issue is fixed.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
07-09-2016, 06:12 PM
2014 25' Flying Cloud
Cuddebackville
, New York
If we need the air conditioner at night, I find it better to leave the fan on one of the speeds rather than auto. On auto it cycles on and off and can wake me up when it comes on. That's not a problem if it runs constantly. I usually want the air circulation anyway.
2019 Ford Expedition Platinum
07-09-2016, 06:37 PM
1979 23' Safari
Wayland
, New York
Right now I've got a manual air distribution box. I perceive very little difference between the low med high settings. There is a difference that you can tell is there but it's so small it might as well always be on high.
07-10-2016, 05:04 AM
Sag Harbor
, New York
Wondering if you tried the thermostat reset per FCStreamer's suggestion? Although I don't have your model, IMO you should be able to notice the different fan speeds, especially as your system is quieter as I understand it.
07-10-2016, 12:25 PM
Coast to Coast
Winston Salem
, North Carolina
I did try the reset and it didn't seem to change anything. I'll try calling Dometic this week.
07-10-2016, 01:55 PM
NOAZRK
2004 34' Classic S/O
Kutztown
, Pennsylvania
Although my AS is not ducted, after installing the new Dometic Blizzard NXT air conditioner and two months experience with using them (FR. & R.) I can report that there's no compressor noise inside the AS at all, only air flow through the newly designed interior ceiling air box. The H, M, L & Auto fan speeds work the same as the Penguin I & II. The units run so cold that my 34' cools with just one, either F or R, unit running in 95 degree direct sun on the roof. On the medium and low speeds, they make about the same amount of air noise as a Fantastic Fan set to low. On high speed fan, they are about the same noise level as the Fantastic Fan on high speed. I've got no idea when the auto fan kicks on and off during the day or night. On the low setting, during the day, the unit trolls along quietly enough that it offers no distraction. Very happy with them so far.
07-10-2016, 09:35 PM
1979 23' Safari
Wayland
, New York
NOAZRK 2690.
Which air box style are you referring to?
The NXT looks interesting.
How was drainage plumbed from the drain pan?
Joe
07-11-2016, 04:45 AM
Sag Harbor
, New York
Thanks for this information. Do you have the 13.5k or 15k BTU units, and were they an easy drop-in replacement? Ditto to Joe about the condensate drain issues.
I don't see any noise/sound decibel specs offhand in the mfg. literature, and am wondering if you can quantify the noise reductions you mention?
Peter
http://www.dometic.com/USA/New-Produ.../blizzard-nxt/
http://www.dometic.com/QBankFiles3/E...-Web_32008.pdf
07-11-2016, 04:51 AM
Sag Harbor
, New York
Thanks for the update. Good luck!
Peter
07-11-2016, 09:10 AM
NOAZRK
Kutztown
, Pennsylvania
To answer some questions, Dometic redesigned the interior air box being used with the Blizzard NXT to reduce air noise by elimination of sharp corners, louvers, and so on. The redesign does a nice job quietly handling the increased CFM air flow.
I had two 15k BTU units installed because the 13.5k were not available at the time. It was a good move for me. I pressed a little cleaned out Keurig type coffee cup over the rear/bedroom temperature sensor to keep the direct cold air from blowing onto it, allowing the rear unit to stay on longer and cool the entire AS with one unit. I tend to run the A/C unit that is furthest from the area I'm spending time in when only 30 amps are available. If you check the specs closely, I think both units can be run at the same time on 30 amps if nothing else is drawing on the line however I haven't tried that yet.
There are no decibel specs posted for this unit, however they definitely are noticeably quieter then the Penguin I or II.
There is a drain kit available as an add-on. When installed, it easily connects directly to the existing AS tubing. All things considered, if you're planning to install a Blizzard it would be best to have about 4 to 6 inches of extra tubing and a connector fitting (90 degree) to eliminate any possible kinking. The only thing I don't particularly care for is that the kit is made of white vinyl plastic, so it is more visible. I plan to paint mine black.
07-11-2016, 03:55 PM
Sag Harbor
, New York
Thanks for the details.
07-11-2016, 04:06 PM
2020 Classic 33
Box Elder
, South Dakota
For your original question it is a very very slight difference in speed. Hardly noticeable and can't see any difference in output. So I leave mine on Auto.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
09-22-2016, 01:30 PM
1969 25' Tradewind
Port Washington
, New York
Hi NOAZRK,
Although my AS is not ducted, after installing the new Dometic Blizzard NXT air conditioner and two months experience with using them, I can report that there's no compressor noise inside the AS at all, only air flow through the newly designed interior ceiling air box. On high speed fan, they are about the same noise level as the Fantastic Fan on high speed. I've got no idea when the auto fan kicks on and off during the day or night. On the low setting, during the day, the unit trolls along quietly enough that it offers no distraction. Very happy with them so far.
Would you mind posting a pic or two of the a/c unit(s) on top of your trailer? I've been considering the lower profile Penguin or Mach 8 both for looks and to reduce drag, but sound is also a significant consideration for me.
Appreciate it!
07-09-2017, 05:31 PM
NOAZRK
Kutztown
, Pennsylvania
07-09-2017, 06:03 PM
2008 30' Classic S/O
Hampton Beach
, New Hampshire
Slide Out Society Recruiting
Hi NOAZRK2690,
Caught the picture of your AS and the description of a 34' S/O. Not long ago the Slide Out Society (S/OS) formed and is recruiting new members.
See this thread for details: http://www.airforums.com/forums/f366...ry-159166.html
I hear tell there's even a bounty for bringing in new members !
Come on over and get in on the S/OS Registry! You'll be warmly welcomed!
Tom - S/OS #25
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
