Old 10-12-2015, 07:00 AM   #43
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
"I'm reading that the consensus is don't change gain once set? This is contrary to what I've been told verbally by other drivers."
LR,
Setting once might work if every outing was exactly the same....not so much in the real world.....
Better to set once for every outing.
My routine, start TV, after idle stabilizes, put in gear adjust gain to stop & hold, keep it at that threshold, ck again at 10-15mph to dial in. Setting to just before trailer lock-up has not worked well with our Classic & TruControl combination.
Major load change may require further adjustment.
In my experience, (Tekonsha & TruControl), more gain does not effect engagement timing. I have found that if your controller is wired into the brake light wiring, your trailer brakes will engage before the master cylinder applies pressure.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-12-2015, 11:20 AM   #44
1975 31' Sovereign
North Fort Myers , Florida
As the Duke stated above, I am a former owner operator and have driven several million miles accident free! tHE BIGGEST REASON--- I KNEW HOW TO CONTROL THE TRAIER BEHIND ME! Increase trailer braking on any pavement that is not dry. You'll always keep the two of them straight and under control. You never want to look out and see your trailer passing you!!!
TLBIJOU is offline   Reply With Quote
Old 10-12-2015, 09:32 PM   #45
2011 27' FB Classic
Camp Hill , Pennsylvania
I agree that changes to loading require re-testing/setting the brake gain. But the only significant load change I do is to add or drain the fresh water tank depending if I am boonieing it or not. Brakes are set up for the greatest possible load.
My Ford manual says not to routinely use the brake controller knobs to stop. But In slippery conditions braking the trailer first seems a better idea. That will keep things in a straight line and avoid a jackknife. TLBIJOU I think we are saying the same thing with different words. I.e. Leave the gain alone and use the trailer brakes alone in slippery conditions. I'm not sure why Ford doesn't agree.
LyleRussell is offline   Reply With Quote
Old 10-12-2015, 11:25 PM   #46
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I believe routinely is the keyword. I am not going to do the research to be sure, but I'm guessing that trailer brakes are not designed to routinely brake for the trailer and the TV. It seems to me that the time between trailer brake overhaul would be reduced and the chance of failure wound be increased if the trailer brakes were routinely manually actuated.
Ken
Old 10-13-2015, 08:22 AM   #47
2011 27' FB Classic
OK Thanx everybody.
Old 10-13-2015, 12:53 PM   #48
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The reason for the hand control other than testing is to regain control if sway begins or the trailer is trying to pass you. Trailer brakes first to straighten the rig.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-13-2015, 08:48 PM   #49
2011 27' FB Classic
Got it. Thanx all.
Initial brake controller gain setting Will_Brule Towing, Tow Vehicles & Hitches 20 08-09-2013 07:58 AM
Rain, Rain, Rain knunut Off Topic Forum 12 01-10-2013 07:25 PM
Elec. brake gain setting xo1rider Tow Vehicles 8 11-16-2011 12:39 PM
Rain V. Walbernize - Rain Wins monkeypants Our Community 0 08-22-2009 08:18 AM
Rain, rain, go away... Twinkie Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-29-2007 04:50 PM
