Old 11-12-2018, 09:07 PM   #1
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
Diesel #2 Availability in the Midwest
I've heard recently that Diesel #2 availability in the Midwest is somewhat limited and that much of what is sold is either Diesel #1 or contains bio-diesel. Can anyone in the Midwest states comment on this please.
Modern diesel truck are very particular about what goes in their tank. We'd like to know what we're in for if we travel that way.
SilverWind is offline   Reply With Quote
Old 11-12-2018, 10:25 PM   #2
jcl
Vancouver , British Columbia
#1 diesel has the paraffin removed. It doesn't gel as readily in low temperatures. It has lower energy content (so you will use more by volume). It has lower lubricity. It is often mixed with #2 diesel to match lower ambient temperatures in that area in winter, with the percentages dependent on the expected lowest temperature. A small percentage mixed in with #2 is simply termed a winter blend of #2.
You will generally find #2 everywhere. It may or may not have biodiesel added to it depending on the local laws, supplier, etc.
jcl is offline   Reply With Quote
Old 11-13-2018, 04:36 AM   #3
2017 FC 28 Twin
Plymouth , Indiana
^^Correct in my area all Diesel contains biotheres only 1 station north of Indianapolis that gives a choice of non bio, Subsequently I put additives in every time I fill to maintain lube of the fuel
2017 FC 28 w/ Shocker hitch
2014 RAM 3500 4x4 mega cab drw
Dragline is offline   Reply With Quote
Old 11-13-2018, 05:46 AM   #4
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
We country folks in the midwest can afford “modern diesel trucks”.
And surprisingly, we can buy fuel to operate them on here, too.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 11-13-2018, 05:53 AM   #5
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Yep - you will be fine. Like any diesel truck make sure you change the fuel filter per the manufacturer's schedule.
A shot of Stanadyne additive and extra filtration for my truck. The injectors are much quieter with the additive.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 11-13-2018, 06:54 AM   #6
2016 28' International
Sioux Falls , SD
#2 ULSD is available at all stations w/Diesel.
When #1 is added for winter blend, often a lubricity additive is added to the fuel at the plant.
I have seen bio at the really big truck stops.
You may (doubt it) if wandering in very rural areas see #1 at a pump but, that is off road / machinery fuel only and says so. Read the pump.
You will have no issues finding fuel.
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Old 11-13-2018, 09:36 AM   #7
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
My truck Manuel says no bio over 10% so when traveling I always look for the #2. I've noticed that many Flying J's, Pilot, Love amount others are slowly switching to bio 20% so finding # 2 can sometimes be a challenge but not impossible. This past spring we did a cross county trip without fuel issues, Texas along much of I-10 had only bio but it was just 5% so no problem.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 11-13-2018, 09:48 AM   #8
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
......very little paraffin in the low sulfur fuel....
Old 11-13-2018, 09:54 AM   #9
Francisco , Indiana
We have a 2011 Dodge Ram diesel with over 100,000 miles. Most of them towing. I never have worried about whether fuel has bio or not. I just look for stations that sell a lot of fuel. Fresh fuel works best for me.
YMMV
Hickory
hickory is offline   Reply With Quote
Old 11-13-2018, 10:00 AM   #10
Anna Maria , Florida
Not to be testy but !
Have you ever been east of the Sierras ?
Not only do we have every kind of Diesel Fuel available much of it is refined and distributed from here.
We also have Modern Diesel Trucks, flushing toilets running hot and cold water.
franklyfrank is offline   Reply With Quote
Old 11-13-2018, 10:38 AM   #11
1986 31' Sovereign
Miami , Florida
In Minnesota (in the summer) , state law requires B20 biodiesel. I am sure it would work fine in my truck but it is still under warranty and Cummins says no greater than B10. So, kind of a conundrum. Illinois also presents a challenge as most stations are sell ing biodiesel blends.
Pilot and Flying J (at most locations) placard the pumps for B20 even though it may well be pure dinosaur. No way to tell.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 11-13-2018, 10:52 AM   #12
jcl
ULSD continues to have paraffin. It has less than higher sulphur diesel due to the refining process, but it is still there, and because the refining process changes the size of the wax crystals, there are more issues with gelling at low temperatures than previously. If there was very little paraffin there wouldn’t be the same low temperature issues.
Old 11-13-2018, 10:58 AM   #13
jcl
Wouldn’t that be more likely to signify off road (marked) diesel than anything else?
Where I worked years ago we sold #2 and #1 (aka kerosene) for off road equipment use, depending on ambient temperatures, and both could be dyed. The dye was just about the road tax, not about #1 vs #2.
Do some rural stations carry two grades of marked fuel?
Old 11-13-2018, 11:18 AM   #14
PCJ
2018 30' Classic
Eden Prairie , Minnesota
I have a 2018 Duramax and have no problem with any of the fuel anywhere in MN
PCJ is offline   Reply With Quote
Availability in Florida Lee Davis On The Road... 23 10-06-2005 05:49 AM
Rubber trim availability Safari Tim Cabinets, Counter Tops & Furnishings 1 02-17-2005 03:17 PM
WBCCI number availability? blucloud WBCCI Forum 11 08-07-2004 05:50 PM
rear bumper (57-62) availability ? p.dow Bumpers & Bumper Storage 3 03-16-2004 11:48 AM
Safari Availability JLD 1974 - 1979 Safari 4 09-12-2002 08:32 AM
