Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 10-25-2015, 09:04 PM   #1
murrieta , California
Dead Horse Point campground in December ?
Greetings,
I would like to visit Canyonlands UTAH this winter. I booked the Dead horse point campground for 5 nights December 9-14. Daytime highs in 30' to 40's, lows 15-20. I told my wife if we are prepared with layers etc. -- we should be able to still enjoy the solitude and scenery that accompanies winter. Does anyone out there have direct experience visiting this area under similar conditions ?
Thanks for any advice.
2012 Classic 30 foot.
Marc
robovet is offline   Reply With Quote
Old 10-25-2015, 10:03 PM   #2
spenfolder's Avatar
2006 16' International CCD
Salt Lake City , Utah
I have been to Dead Horse State Park in February, but not December. The sites have electric hook ups, so I took a small space heater to take the edge off the cold. I also ran the trailer furnace a little to keep things from freezing. I had a great time. Even had a little snow.
It is a beautiful place. The point at Dead Horse is a great place to watch a storm roll in across the red cliffs.
Stan
Salt Lake City
Name:	Dead Horse snow.jpg
spenfolder is offline   Reply With Quote
Old 10-25-2015, 10:42 PM   #3
1974 Argosy 20
Kooskia , Idaho
I was there once in March and in a snow storm. It was very cozy sitting in the trailer looking out at the snow.
At the time I was there the electrical outlets were under the picnic tables and the weight of the cord could easily make the plug fall out. 20 amp circuits too. So, bring a couple of bungie cords to hold the cord in place if the same system is still in use.
Old 10-25-2015, 11:06 PM   #4
spenfolder's Avatar
All campsites now have 20, 30 and 50 amp connections on a post by the parking pad.
Campground Details - Dead Horse Point State Park, UT - ReserveAmerica
Stan
Salt Lake City
Old 10-25-2015, 11:12 PM   #5
Len and Jeanne
Len n Jeanne's Avatar
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley , British Columbia
We've camped there a few times, as well as at the nearby Horse Thief overflow BLM campground-- though not in winter. This is a very beautiful place, yet convenient to Moab.
My questions have mostly to do with the temperatures and your route to get there. We have a friend in Moab, who said that usually their winters are comparatively mild-- except for a couple of years ago when it got so cold that everyone's pipes froze in town. You'll be up a lot higher in elevation than Moab.
If it were me, I'd probably want to winterize the trailer before heading out. The daytime highs you list are probably averages, not the amplitude of temperatures that occur in this area.
Winterizing isn't a great camping solution, but you can get by with lots of water bottles, and doing a manual flush with the toilet. Put some kind of mild antifreeze like windshield washer fluid down your waste water tanks. An electric space heater is great when temps are above freezing, but it won't heat the pipes or tanks under the floor boards the way the furnace will. Using the furnace a lot will burn up a lot of propane, so it's best to start with your tanks topped up.
Also if you have to drive during freezing temperatures if you're not winterized, you'd want to think about driving with your furnace left on.
The other question is about winter driving to get there and back while towing a trailer. The Moab area doesn't get a lot of ice and snow but it does get some, and then presumably you'll be driving over some high elevations to and from the park. Hopefully you've had experience in serious winter driving conditions. I don't know if your route will take you across that 105-mile stretch of I-70 with no services, but we did it once in March and found ourselves in blizzard white-out conditions.
For sure, have a great and memorable trip, just stay safe, eh?
Len n Jeanne is offline   Reply With Quote
Old 10-25-2015, 11:20 PM   #6
Thanks for all the suggestions, I will remain flexible and check the forecast and road conditions when it gets closer--
marc
Old 10-26-2015, 01:26 AM   #7
IanPoulin's Avatar
2021 25' International
Full timer , Virginia
robovet - you're also prepared for generic wintertime camping rules as well, right? Or is this a discovery not only of the camp area, but also the winter camping experience?
2024 Airstream Globetrotter 30RB
2022 Ford F350 Lariat Diesel
WBCCI 4CU 8118
IanPoulin is offline   Reply With Quote
Old 10-26-2015, 06:58 AM   #8
I guess I need to learn the winter camping rules--- where do i find them ?
Old 10-26-2015, 08:16 AM   #9
IanPoulin's Avatar
*heh*
Jump into the Winter Living sub-forum (peer to this sub-forum) and get reading. Mostly it's centered around utilities and moisture management.
Fairly straight forward stuff. A few of the items I live by when I winter camp:
o If you want to use your utilities (water, toilet, shower), make sure you run your furnace to keep the tanks warm (frozen tanks = "bad".) The heat pump (even on ducted airstreams) wont work for this task - it must be the furnace. Else if you are going to use campground restrooms, water source, etc., a space heater may work.
o If you want to use your utilities (water,) its best not to use a spigot hose to city water inlet (even heated hoses as the join points can freeze,) but rather to manually fill your fresh tank daily and use the internal water pump for pressure.
o A Home Depot 5# bucket with a spliced open pool noodle on the edge, filled with kitty litter is a good temporary use commode if your black tanks are either frozen or not-for-use. keep the cover on when not in use. One day I'll buy a composting toilet and all this will be behind me..... (i think....)
re interior moisture -- showers, your own breathing and propane stove flames produce moisture. I am not sure the "warning levels" but when I start to see ice building up on the interior of my windows, I feel I am not ventilating enough to keep moisture down (moisture = mold/mildew = "bad")
o If you want to use your shower, get a squeegee to immediately wipe down the walls to help lower interior moisture (and take "navy" showers with as little water as possible.)
o stove burner flames produce A LOT of moisture. Consider prep-ahead cold meals to limit use.
WBCCI 4CU 8118
Old 10-26-2015, 09:43 PM   #10
Wow I'm glad you set me straight. I'll take your advice, read up. I don't think I'll have problems keeping the furnace going since I'll arrive with full propane (80 pounds). Staying 4-5 days so I'm sure that will last. Thanks again--
Old 10-26-2015, 10:46 PM   #11
spenfolder's Avatar
robovet,
Keep in mind it is pretty dry out here in the Utah desert. Even in the winter. You will need to watch for moisture, especially if there is a storm. But it's not like winter weather and rain on the coast. I find I get pretty good control by keeping the Fantastic fan open just a bit, and even turning on the fan once in a while if it starts to get damp. You will be plugged in, so power will not be a problem.
Be careful on the roads, watch the weather and temps. and have a great time!
Stan
Salt Lake City
Old 10-26-2015, 11:08 PM   #12
Len and Jeanne
Winter camping can be great, but Ian's "rules" list is a good one.
Moisture management is huge, even if it's not snowing or raining, because once the windows and vents are closed to keep out the cold, condensation on the inner walls from your breath, let alone boiling water, wet towels or snowy jackets, can be a problem. The most obvious solution is just to leave the vents open a bit, and keep the furnace or space heater running; and leave anything really wet in the tow vehicle. We're normally content to sleep with cooler temps and a second comforter on the bed, but this doesn't do much to evaporate the condensation.
Ian, your toilet alternative with the pool noodle seat looks ingenious. Our alternative is to get a double layer of new (not old, pin-holed) trash bags opened up in the toilet bowl and over the rim. Add a few scoops of garden-store peat moss to the bowl, and then replenish after a couple of uses. Baking soda could be sprinkled over to minimize the odour. When one's comfort level is surpassed, simply tie up the bags and discretely deposit in the campsite dumpster. Peat moss is really light and absorbent.
For clothing, we'd take some winter pac boots, heavy socks, jackets, hat, mitts. Longies or windpants may come in handy, too.
Just one other point about winter camping, robovet, is that it does get dark awfully early and stays dark in the early morning. How will you pass the time?
Dead Horse point should be a great location for star-gazing (bundle-up!) but it probably won't have Wi-Fi: I'm not sure what TV or cell phone service is available up there. Possibly Verizon, but maybe the Utah folks can comment on that. AT&T, Sprint, T-Mobile, &c are pretty worthless in most of the rural West, although Moab will have service available. We're pretty low-tech, and tend to rely on books, DVDs, and the odd game for our evening entertainment.
We hope you have a super trip-- and at that time of year, you should avoid the crowds.
Old 10-26-2015, 11:49 PM   #13
spenfolder's Avatar
I remember a tiny bit of Verizon service on my MIFI, and a signal on my ATT phone in the right location in the park. I would not plan on "good" service from any of the providers. You can get full bars in Moab, about 30-45 minutes from Dead Horse State Park.
Stan
Salt Lake City
Old 10-27-2015, 01:24 AM   #14
IanPoulin's Avatar
Len'n'Jeanne --
The toilet alternative is not my idea - but it works. It's a combo of (the kitty litter part) a reccommendation on emergency toilets from Paula (aka Foiled Again here in the forums) and the other is a video from a FANTASTIC "guerilla DIY'er" channel on youtube (seriously, check the vid out and then check out some of his other items, such as the backyard planter that doubles as the metal foundry!):
WBCCI 4CU 8118
Old 10-27-2015, 01:38 AM   #15
Sag Harbor , New York
As long as this discussion is already going to pot,
may I recommend adding this seat, upon which one can put one's full weight, in order to concentrate on the matter at hand?
http://www.amazon.com/Reliance-Produ...Z9D8RNFNQ83ZG3
And the lid, although not airtight, controls odors better than an open top, especially if one has just added some kitty litter on top of the recent deposit.
Old 10-27-2015, 09:37 PM   #16
Livingston , Texas
Great Business Bucket video. If you want a super deluxe bucket toilet seat that closes tightly shut - trust the Luggable Loo - peat moss is your friend - black bags are nicer! Useful for camping when winterized of course and reminds you why you bought the Airstream for the rest of the times!
P.s. That tight closing lid will be a plus if you are using indoors in the middle of the night! Luggable Loos at REI and other retailers.
Seemore2006 is offline   Reply With Quote
Old 10-27-2015, 11:35 PM   #17
Len and Jeanne
Love the pics-- that pool noodle rim actually looks comfy. We have a Luggable Loo, as well (aka "the Biffy Bucket",) but it mostly sits in our mud room as a compost bucket these days. With the garbage bag/peat moss alternative, we don't require an extra bucket, however, and can use our regular toilet. For winterized camping, we would mostly use the CG facilities to save on waste water, except for during the middle of those frosty nights.
Incidentally, in Moab we like Zax pizza buffet, Lin Ottinger's rock shop, and the Back of Beyond book store.
Dead Horse Point CG/Moab UT bonginator On The Road... 7 11-14-2010 08:14 AM
4CU 004 : Dead Horse 3 - The Luau azflycaster WBCCI Rallies & Events 278 10-25-2009 04:52 PM
4CU 004 : Dead Horse 2 -The Return of the Peeps! azflycaster WBCCI Rallies & Events 234 02-24-2008 04:55 PM
Don't want to "Beat a Dead Horse" but...? Baby Whoopie Electrical - Systems, Generators, Batteries & Solar 1 09-27-2006 03:57 PM
