Old 03-31-2015, 10:57 AM   #1
De-winterized
Does anyone have a recommendation for YouTube video on how to de-winterized your airstream? Many thanks.
RichP21 is offline   Reply With Quote
Old 03-31-2015, 12:49 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Not sure you need a video.
I fill the fresh water tank with CITY water while the fresh water tank drain is open. This cleans the tank. While the tank has water in it turn the pump on and go to each faucet, hot and cold, and run till clear water comes out. This purges the antifreeze from the lines.
Connect the city water to the city hook up. Now slowly open, just leave it cocked a bit, the bypass on the hot water heater and fill with water. You will have to open a hot water faucet while doing this to let the air in the tank out. I say to use city water for this because there may be some antifreeze in the piping from that connection to the rest of the system.
You have now added about 2 gallons of water to the gray tank and that can wait till your first trip to dump or you can drain it while flushing the system.
Nothing needs to be done at this time for the black tank.
I let the fresh water tank drain completely before turning off the drain cock.
2004 Excursion 4x4
Old 03-31-2015, 01:50 PM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Make sure you replace the inline filter under your kitchen sink if you have this feature after you have purged the lines of the anti-freeze.
This would also be a good time to sanitize your fresh water tank.
Use about 1/4 cup of liquid chlorine bleach per 15 gallons of capacity, fill the fresh water tank, run water from the fresh water tank into each faucet/shower/outlet using the pump and turn off when you smell the bleach at each outlet. Let it sit for around 4 to 6 hours. Then drain the fresh water tank and you are good to go. Some people object to the lingering chlorine smell in the fresh water tank and will flush it a couple of times. Baking soda helps to remove the chlorine odor more quickly.
Bob Martel
WBCCI# 5766
Old 03-31-2015, 02:30 PM   #4
Very helpful - thank you!
Old 03-31-2015, 03:05 PM   #5
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Do we have to put anoid in? I did not winterize. My hot water thingy under back side bed so just have to turn hot water until inline? I have to hold mattress up and reach un at same time....no time for a selfie trying to do that!!
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 03-31-2015, 04:14 PM   #6
Chelsea , Michigan
Images: 12
I assume you mean a sacrificial anode? Based on its design, your hot water heater either has one or it doesn't. If it does not have one, there really is no practical way to add one so the answer is you go with what you have. Just make sure the drain plug is back in and the bypass valve is turned off when you fill the hot water tank with water.
Bob Martel
WBCCI# 5766
Old 03-31-2015, 05:34 PM   #7
gpt
2014 25' FB Flying Cloud
sequim , Washington
i simply used my air compressor to purge all of the lines for winter storage. the only RV antifreeze i added was to the sink, shower and toilet traps as you can't get all of the water out of these.
to de-winterize i opened all the valves i had closed, including the hot water bypass and drain as well as the low point tank drains. without turning on the hot water heater, open a faucet closest to it, turn on to the hot side and let it purge the air from the system. this will get the air out of the hot water heater while filling it at the same time. do the same for each hot water line in your trailer followed by each cold water line. makes no difference if you are connected to water or are using your fresh water tank. you are just trying to get the air out of the lines so you don't end up with sputtering and splashing all over the place. pretty easy and quick
gpt is offline   Reply With Quote
Old 04-01-2015, 06:01 AM   #8
Thanks, I am going to give this a try today and will let you know how I make out. Much appreciate the tips and advice.
Old 04-13-2015, 03:10 PM   #9
Everything worked out great - no problems. Thanks for advice!
Old 04-14-2015, 03:00 PM   #10
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
Quick question -
What about building the hot water tank air bubble when filling it from a drained positions?
Dill it, let pressure out then add the air buble after that?
IanPoulin is offline   Reply With Quote
Old 04-14-2015, 04:03 PM   #11
HowieE's Avatar
Images: 12
Originally Posted by IanPoulin View Post
Quick question -
There is no reason to even consider this option. To fill the hot water tank from the fresh water tank or city connection just open the bypass valve and as the tank is filling open any hot water faucet. The air will purge through the faucet. When you have a steady water flow the tank if full.
2004 Excursion 4x4
Old 04-14-2015, 04:36 PM   #12
IanPoulin's Avatar
Aldie , Virginia
Well I am asking about setting the tank air bubble in place - I don't want to bleed all the air out, right? The bubble is there for pressure safety?
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
Old 04-14-2015, 08:42 PM   #13
HowieE's Avatar
Images: 12
If you look at the out let pipe on the tank you will see it is not at the Top and thus a small pocket of air is normal. It just happens without outside influence.
2004 Excursion 4x4
Old 04-20-2015, 07:41 PM   #14
MaineStreamer's Avatar
2007 20' Safari
Saco , Maine
Another newby here needing to de-winterize for the first time. When flushing the fresh water/city water tank, do you just empty that out on the ground, run through the waste hose?
Marty Womer
Saco, Maine
MaineStreamer is offline   Reply With Quote
Use it while Winterized Foiled Again Winter Living 12 12-26-2014 02:43 PM
To those New Englanders who have already winterized.... Bruce B On The Road... 2 10-18-2014 06:15 AM
How I winterized my Airstream Subzero-AK Winterizing, Storage, Carports & Covers 9 10-06-2014 10:11 AM
30 degrees at night, not winterized HeadWest Plumbing - Systems & Fixtures 7 04-25-2013 09:19 PM
De-Winterized Today! RDM16CCD Winterizing, Storage, Carports & Covers 18 05-15-2006 11:28 PM
