Old 05-13-2012, 08:40 PM   #15
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
And the most important lesson of all,
. . is to shoot GYM tires to put them out of their misery.
Old 05-13-2012, 09:16 PM   #16
JFScheck's Avatar
Rockville , Maryland
Images: 33
Now that is funny!
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 05-13-2012, 09:38 PM   #17
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
A Mother's Day you will remember forever. Hope you did not say any bad words.
Dave
Old 05-13-2012, 10:46 PM   #18
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
I'd invest in a torque wrench instead of a breaker bar... you should never tighten with a breaker on aluminum rims... most spec to around 90ft/lbs... you can easily damage them unless you've got a good sense for 'tight enough'.
Friday is offline   Reply With Quote
Old 05-14-2012, 12:18 AM   #19
1974 Argosy 20
Kooskia , Idaho
Originally Posted by ROBERT CROSS View Post
WIWD>>
UNDER COVER OF DARKNESS, replace the "evil rock" with the sabotaged tire and a sign...."no tires on the lawn".
Under cover of darkness, replace the evil rock with a rubber rock from "Acme Sales". Actually rubber rocks are available at about half the Acme price from Harbor Freight, and with the 20% off coupon....
Old 05-14-2012, 05:34 AM   #20
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Originally Posted by finalcutjoe View Post
Should we turn this into a 'get rid of that Goodyear Marathon garbage' thread?
Originally Posted by AirsDream View Post
Yup, sure ... clearly all the fault of the tires ... yadda, yadda, yadda.
Or: they just shouldn't allow rocks on lawns, or roadsides, or .... yadda, yadda, yadda.
OK, that's a 'yes'
Roughly 30k miles, and 4 years (on just our 2008), we've gone through 5 GYM's. 3 total failure, and 2 were caught in the process-- massive sidewall bulges
>>>GRAPHIC IMAGES BELOW<<<
More commentary can be found at my blog, here: Wheel Upgrade
I know what you're thinking Airsdream, 'cause I see you coming a mile off, and the answers are 'yes, yes, and yes' to your questions:
1. Did you have TPMS for constant PSI monitoring?
2. Did you CAT scale your rig to confirm proper loading?
3. Were you always cognizant of the 65mph max speed rating?
JFS': Looks like you're running the OEM 15" rims, so between that size and your weight, there are no options other than ST. From my own personal experience, and anecdotal evidence found here and at the other arr-vee dot com forum, I've found horror stories with ALL manufacturers; Carlisle, Commodore... MAXXIS having the least failures. But that might just be from a reduced market share...
The only thread I haven't found yet, is detailing a failure on an LTX
AFA running up against a lawn rock
We used to spend all weekend crawling all over rocks much scarier than that in my loaded up CJ-7, with nary a puncture. Now, granted, we're talking TT vs. truck, but my point is the BFGoodrich and Mickey Thompson tires we were running, were every bit loaded to capacity, doing what they were designed for... and that's my point, durability/dependability under intended use.
-Joe
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 05-14-2012, 05:40 AM   #21
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Couldn't you have saved your self some work? You were already at your destination, you could have just parked, then taken off the damaged tire and put the new one on when you got it. Even if you were going to tow to a tire shop, you could do that with only one wheel on that side.
Old 05-14-2012, 05:42 AM   #22
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Our first tire-changing experience WAS along the highway, unfortunately, and during the second trip with our trailer no less. I look at that spot and think about the tire changing every time we go by it (it wasn't too far from our house). It took roughly as long as yours did, or perhaps a bit longer because, without thinking, I pulled it onto the blocks before loosening the lug nuts. D'oh! Of course I didn't stop to take pictures either.
Fortunately I had checked the camper's spare tire pressure before we left. I now make sure to check it (and the truck's spare) when I'm checking the 8 tires actually on the ground before every trip.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 05-14-2012, 05:58 AM   #23
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
OK this is going to sound a bit silly but so far it has kept us out of trouble.
When driving around tight corners for some reason an old song pops into my head "Swing low sweet chariot" but I always change the words to "Swing WIDE sweet chariot"
Swing Low, Sweet Chariot - Wikipedia, the free encyclopedia
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is online now   Reply With Quote
Old 05-14-2012, 06:05 AM   #24
Dearborn , Michigan
Images: 21
Good one!
FWIW, the Hensley also improves cornering and tracking (i.e. it doesn't 'cut' the corner as much as a conventional hitch)
Old 05-14-2012, 07:02 AM   #25
Skater's Avatar
1995 30' Excella
Bowie , Maryland
How does it do that?
Old 05-14-2012, 07:06 AM   #26
JFScheck's Avatar
Images: 33
Read the thread again - I learned the hard way about torque wrenches and busting bolts in the Navy, plus the spare rim is steel...
Seriously - The breaker bar is just to get the nuts off, and to get the wheel back on the hub "evenly" but tighter than what my fingers would allow - I only tighten to full specs via the torque wrench and I always keep it with me when towing the Twinks. Still - excellent advice to point out to everyone!
Where I was not preparied was for my leveling blocks, although I could have used my jack, it's so much eaiser to drive up on the blocks...
**I Love U.S.A.**
Old 05-14-2012, 07:10 AM   #27
JFScheck's Avatar
Images: 33
So again - I think my big lesson here was to stay alert, and just like when landing an aircraft "fly it to the ground" when towing your Airstream, keep vigilent or those damn lawn boulders will jump out and bite ya!
**I Love U.S.A.**
Old 05-14-2012, 07:21 AM   #28
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Try Goodyear G-26 Cargo tires, they come in 225/70/15 if you can afford them, although they save the expense of new wheels. Hard to find but tire rack has them. Approx 200.00 each, made in France & Germany.
jkcru is offline   Reply With Quote
