Old 08-04-2008, 08:09 AM   #1
mandolindave's Avatar
Cruise control MPG controversy
My brother says he gets better gas mileage with his Prius when he uses cruise control. I attributed the better gas mileage was on account of the
vehicle being a hybrid. But then, my lovely, sweet tempered, charming,
ex tried to explain to me that she gets better gas mileage using cruise control on her gas guzzler. Her point was that the cruise control prevented her from driving at 80 miles an hour up hills. That makes perfect sense to me. But I was always under the impression that MPG suffered when cruise control was activated. What is the deal? Dave
mandolindave is offline   Reply With Quote
Old 08-04-2008, 08:33 AM   #2
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
Although I am not a big fan, and don't use it as often as I could, I have found the cruise control to be more efficient when it comes to mileage. Ron
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 08-04-2008, 08:55 AM   #3
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
I'm a fan of cruise control but my reasoning is a bit different from the 80 mph up a hill reasons. I remember back when cars had carboraters and to reduce response time between when you push the gas pedal down and the engine starts to speed up the manufacturers added accellerator pumps which would squirt a small amount of gas so that response time was instant. Push the accellerator down over and over and you would send multiple squirts of gas to the combustion chamber and gas mileage suffered. It is my belief that the same principle has been carried over to the electronic fuel injection systems. When you first push the gas pedal down, a little extra gas is shot into the combustion chamber to give you quick response. As you cruise along you can ease up on the gas just a bit to maintain the same speed. Every time you hit a good bump in the road your foot presses the gas pedal down just a bit causing a little extra gas to be sent to the combustion chamber for just an instant resulting in lowered miles per gallon. It seems logical that the cruise control would eliminate these little bumps and jiggles in the gas pedal, resulting in a steady position and lean, smooth, even flow of fuel and thus, higher miles per gallon.
The proof would come from knowing how the electronic control system is programmed.
To me it makes sense, but then I haven't had all my coffee this morning.
So Long!
Bob Thompson is offline   Reply With Quote
Old 08-04-2008, 09:17 AM   #4
Central , Mississippi
My '06 diesel truck will get better milage with the cruise off, if I allow it to slightly vary the speed on hills. On the other hand my '91 Jag's cruise seems to jump on and off the throttle for small adjustments but it still beats my best MPG when I try manually controlling the speed.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-04-2008, 09:20 AM   #5
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
My 08 Sequoia gets better millage on cruise, but I don't like to use it while towing.. Just makes me a little to relaxed, and you never know what is gonna happen.....
Old 08-04-2008, 09:26 AM   #6
Incorrigible
Ike T's Avatar
1976 Argosy 24
-- , Georgia
In our 4-cyl (2.4L), 5-speed manual Accord, the cruise puts in a good additional amount of fuel pedal when climbing hills. In level cruise, the pedal is barely depressed at 65mph.
In our 8-cyl (5.7L), 3-speed automatic Travelall, the cruise doesn't put near the additional amount of fuel pedal in when climbing. Of course, it's putting in a good amount already in level cruise.
The Accord has a tendency to overshoot the desired speed when maintaining speed through hills. The Travelall is consistent on speed through hills and does not "overspeed" when cresting a hill.
I think the difference in engine sizes is the key factor here. Greater capacity to perform additional work with a similiar amount of energy.
Tim
1976 24' Argosy
1973 International Harvester Travelette 1210 4x4 'Bernard' 164" WB
1997 Georgie Boy 30' SuperDuty v10
Ike T is offline   Reply With Quote
Old 08-04-2008, 09:56 AM   #7
Liquid Cooled
RedSHED's Avatar
2014 16' Sport
Columbus , Indiana
I agree totally.
RedSHED is offline   Reply With Quote
Old 08-05-2008, 11:33 AM   #8
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Our Ridgeline does better with the Cruise on, towing or not.
Ahab is offline   Reply With Quote
Old 08-05-2008, 02:23 PM   #9
tpi
Trabuco Canyon , California
On a technical level I can't see many reasons why the fuel economy would change whether under cruise control or not. Under closed loop conditions the air/fuel mixture is 14.7 to 1 on nearly all gas engines. The ignition timing at various engine speeds vs. MAP would have no reason to change under cruise control Perhaps auto transmission shift points could be more conservative under cruise control-keeping high gear engaged longer prior to a part throttle downshift-since throttle "response" isn't as much of an issue.
The Prius uses an unconventional drivetrain and I haven't thought out all the possibilities there.
At least on my vehicles I can't see a difference. On my car (Camry) I use a scan gauge and specifically checked this out.
tpi is offline   Reply With Quote
Old 08-05-2008, 02:55 PM   #10
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
This is my take on it...
Only possible way I could see a FI system getting worse mileage on cruise would be in the hills where it is accelerating to maintain set speed. If a person is driving they may let the speed roll off a bit and then speed up on the downhills.
Aaron
WBCCI #XXXX AIR #2495
Old 08-05-2008, 03:23 PM   #11
tpi
That sounds logical. I've had my cruise control force a downshift on an uphill at 70 MPH where if I was operating throttle, I'd accept a speed loss to avoid the downshift.
In my vehicles the cruise control uses stronger throttle motions than I'm accustomed to using while steady cruise.
All in all though its the braking (or excessively high cruising speed) which kills fuel economy.
Old 08-05-2008, 03:44 PM   #12
2004 19' Bambi
Denver , Colorado
Images: 32
Having just completed our 4000 mile trip to Oregon and back I found that I did get better gas mileage using cruise control but with a few caveats:
1. The better mileage comes to you as an average over longer distances and greater periods of time (i.e., the longer you keep the rig moving at a consistent RPM the better the mileage). On days that we drove 150 miles or more between stops our mileage was better.
2. Best to use it on 4-lane+ interstate settings so that you can pass slower traffic when necessary without braking or accelerating (the consistent RPM thing again).
3. Don't just set it and forget it. When your rig begins to ascend a hill which requires a down-shift to maintain speed you blow some of the fuel savings you've earned prior to the hill. On milder hills you can reduce your speed just a bit (use the "coast" button on your cruise control) and often keep your momentum up the hill without forcing a downshift. I found that my F-150 and 19' Bambi had a sweet spot right about 62mph which would hold the tranny in Overdrive at about 1900 RPM's and allow us to ascend most hills of about 2% grade or less. This also seemed to be a good setting when we had the occasional stiff headwind. Obviously on the steeper hills your tranny will need to downshift in order to maintain anything close to a reasonable highway speed and I would recommend locking your tranny out of Overdrive any time it begins hunting while climbing a long grade.
Just my own observations and $.02
-Kevin
COLORADO_CAMPER is offline   Reply With Quote
Old 08-05-2008, 03:48 PM   #13
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Our experience..
1995 454 Suburban Throttle body injection, mechanical throttle (cable), got slightly worse (.2-.5 mpg) with cruise engaged. With the old gas prices, not enough of a difference not to use it when safe to do so.
2006 8.1 Suburban Sequential fuel injection, fly-by-wire, just the opposite. Even with the bigger engine and taller gears, 4:10 vs 3:73, the 06 has been averaging 2-4 mpg better than the 95 in or out of cruise.
I'm sure if you were really focused on driving for mpg's you might be able to beat the cruise, but for us the convenience of knowing we're NOT speeding is more than worth it.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-05-2008, 05:00 PM   #14
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I have no idea whether our Tundra gets better mileage in or out of cruise because I haven't run tests on the same highway with same weight, etc. Evening out the pedal movement would seem to improve mileage, though on small uphills the cruise shifts the transmission more than I would permit. I'd also let it roll faster downhill, though the cruise will let it anyway. I might give it more gas going down to roll uphill faster like a lot of trucks do. I only use it on 4 lane roads except when there's a lot of traffic and empty 2 lane roads without too many curves. Otherwise, it's too much fiddling with it.
What I like most about cruise is that my right leg feels better after a lot of driving. Thus I feel better. So a feeling better driver is a better driver and nicer husband.
Gene
cruise control choctawmel Mechanics Corner - Engines, Transmission & More... 13 12-27-2008 05:14 PM
82 310 Cruise Control classic310 Classic Motorhomes 3 06-17-2008 07:43 PM
Cruise Control Replacement djehnzen39 General Motorhome Topics 1 12-29-2007 10:07 AM
towing with cruise control brunoffrance Towing, Tow Vehicles & Hitches 7 06-14-2006 04:28 PM
Cruise Control Chaplain Kent Mechanics Corner - Engines, Transmission & More... 4 10-14-2004 07:56 PM
