Old 11-03-2010, 04:58 PM   #15
2010 27' FB Classic
N/A , Texas
A while ago, I briefly looked at various trailers and the Artic Fox is a nice trailer with some good features but, correct me if I'm wrong, aren't all the roofs on those made with wood ceiling joists? I believe even the ones that use aluminum studs in the sidewalls also have wooden roofs on them. That seems like a draw back to me as far as life of the trailer, although it would insulate a lot better than aluminum.
Old 11-03-2010, 05:50 PM   #16
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
The advantage of the AF is the 4 season insulation for winter campers they can't be beat.
We all know the advantages of the AS and cold weather camping is not one of them.
Garry
Old 11-03-2010, 05:57 PM   #17
lewster's Avatar
Naples, FL , Hood River, OR
The Holiday Rambler 'Alumalite' series and several of the larger, more expensive 5th wheels produced today use aluminum rafters in the roof structure, along with aluminum 'cages' for the wall and floor structure. All aluminum tubing is the construction standard on most larger diesel powered motor homes also, where the only wood you will find is in the cabinets.
Old 11-03-2010, 07:07 PM   #18
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I see more Arctic Foxes the further north I go—they like to migrate north. I met a guy in British Columbia who was trying to get his water heater working properly after 15+ years, so they last that long. The trailer looked fine on the outside and a month later we saw it parked at Denali NP.
I believe they make a full line of trailers—travel trailer and 5th wheel plus truck campers. I looked at their website a couple of years ago and some of the floor plans looked better than Airstream's.
Gene
Old 11-03-2010, 09:40 PM   #19
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
IF I were to get a trailer to take places where I can't take my 31 foot AS (which is a lot of places), I would definitely look hard at the Arctic Fox. Perhaps one of their truck campers would be great for that.
Ken
Old 11-03-2010, 10:22 PM   #20
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
I owned a 2001 Artic Fox Cabover. It was a beast! It also had alot of quality issues and I think I paid around 23k for it out the door. The slide was constantly problematic and a few leaks were discovered as well. I sold it after a couple years of ownership and took a bath on it.. I will stick with the airstream.
Arctic Fox Camper: 1150
Specifications:
Dry Weight Extended Cab:3953Dry Weight Extended Cab-kgs:1793Interior Height:79Floor Length:11'4Overall Length:19'Exterior Height (approx. w/ A/C):112Exterior Width (approx. w/o awning):96 1/2Fresh Water Capacity (approx. gal):55Gray Water Tank (approx. gallons):44Black Water Tank (approx. gallons):43LPG Capacity (approx. gallons):14
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Comparing a 2007 and 2009 27' International worksology Trailer Values 9 08-08-2010 06:55 PM
Stats comparing F-150 vs. F250 FordTruck Tow Vehicles 9 06-24-2008 01:35 PM
Travel Trailer - Mid 20's ft. - Airstream vs. Artic Fox macsfriended Buyer Guidelines 2 04-17-2007 11:41 AM
Comparing... '80s Avion...to...Early '90s Airstream..?? route66 Full-Timing 6 04-29-2006 09:28 AM
