Old 05-02-2016, 07:01 PM   #1
2015 27' Flying Cloud
Olympia , Washington
Caravan - what CB Radio?
We are going on the WBCCI Alaska caravan this year, and a CB radio is required. Any good guidelines? We are probably not going to install one in our tow vehicle, but use the 12v sockets to power. A handheld has been suggested to supplement for parking.
Pat.Mann is offline   Reply With Quote
Old 05-02-2016, 07:12 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
What you really want is a high power "export" or "10 meter" CB radio, with the best magnetic antenna you can buy plopped in the exact center of your tow vehicle roof.
You can add an "Echo mic" for entertainment value, if you like.
Old 05-02-2016, 07:15 PM   #3
Sioux Falls , South Dakota
Be aware that 10 meters is NOT a CB band. It is a ham band, and unlicensed users can get in big trouble. Yes, I know that some truckers are using it, but the FCC is watching and listening. If the requirement is a CB radio you ought to get a CB radio. CB is 11 meters, anyway, so a 10 meter radio won't be able to communicate with an 11 meter one.
The advice on getting a mag mount antenna and putting it in the center of the tow vehicle's metal is a good one.
Check the specs on the radio you buy. Look at how much power it draws (how many amps) and compare that to the limit on your 12V power port. If the radio draws more than what the power port can provide you will be blowing a fuse every time you transmit.
Suggestion: Get some 12 gauge two conductor wire long enough to run from the tow vehicle battery to inside the tow vehicle. The wire will have a white and a black wire inside the sheath. Peel back enough of the sheath so that the two wires can be easily attached to the battery terminals of your tow vehicle battery, but don't attach them yet. Use some red fingernail polish to paint the end of the white wire red. Feed the wire into the tow vehicle near where the radio will go. Remove some of the sheath on the inside end of the cable and paint the end of the white wire with the same red fingernail polish you used outside. The radio should have an inline fuse in the red lead. There may also be one in the black lead. Attach the red line from the radio to your red wire and the black radio lead to the black wire. Go back to the battery and connect the red wire to the positive batter terminal, then connect the black one to either the negative or to a ground.
If you can find a good ground inside the vehicle you can just run a single red wire inside. That may be simpler, but you will have to buy the proper length of RED wire (12 gauge, remember). That wire is usually sold by the foot, whereas you can buy a roll of the two conductor cable at any hardware store and some Wal-Marts.
David Lininger, kb0zke
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (sold)
2022 Grand Design Reflection 315RLTS
kb0zke is offline   Reply With Quote
Old 05-02-2016, 07:24 PM   #4
interstateflyer's Avatar
2017 25' International
Los Osos , California
I'm going to Alaska with a group in a few weeks. We are using GMRS/FRS handhelds that have a much longer range than CB. In addition to the GMRS/FRS channels they have 2 meter and 70cm HAM capabilities, all for the price of a CB. Ours will be connected to roof mounted magnetic antenna for longer range.
GMRS license, a $60 instant online formality for US use. No GMRS license required in Canada. No license for shorter range FRS use.
CB is a WBCCI tradition albiet a bit outdated.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 05-02-2016, 07:34 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
I am assuming the OP needs a radio for talking to other vehicles on the caravan. If so, ultra long distance isn't a requirement....I have a Cobra Roadtrip handheld. It has a short whip antenna for portable use and a magnetic mount for the roof. It is powered by batteries when handheld and a lighter adapter when in the truck. It does a fine job.
CRH is offline   Reply With Quote
Old 05-02-2016, 08:19 PM   #6
Just out of curiosity, how close or far away do the participants in the caravan travel?
Old 05-02-2016, 08:21 PM   #7
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Check with the Caravan leader before buying. Several of us on a recent caravan bought CB radios for it only to be told at the opening meeting that we would not be using them. I think the caravan leaders are just reprinting the WBCCI caravan equipment list without updating it.
Al
Old 05-02-2016, 08:22 PM   #8
CRH
1995 25' Excella
xxxxx , xxxxxx
Never been on one, so I don't know....The portable I referenced is only good to a mile or so when used as a handheld. Using the antenna on top of the truck stretches the range out to maybe 3 miles under good conditions.
Old 05-02-2016, 08:30 PM   #9
2015 30' Classic
Pleasanton , California
GMRS/FRS operate in the UHF, while CB operates on HF (11 meters). UHF communication is typically line-of-site, while HF can experience atmospheric bounce and hop to greatly increase range. So for the same power, CB wins.
Pat, if you think a radio would be valuable in your future consider getting your Ham technician license. There are many one-day classes to help you through the examination and the utility in case of an emergency is invaluable! They are a great community.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 05-02-2016, 08:35 PM   #10
drboyd's Avatar
1978 25' Tradewind
What you're not supposed to know about the "export" radios is some/all are easily modified to work on the CB radio band.
http://cbradiomagazine.com/Stryker%2...%20Review.html
Old 05-02-2016, 09:14 PM   #11
Thanks for pointing that out. Yes, with the correct atmospheric conditions CB wins.
Old 05-02-2016, 09:45 PM   #12
Southwestern , Ohio
I don't think anyone has answered your question directly as to equipment recommendations so I will put in my two cents worth. For what it's worth I got my general class amateur radio license more than 50 years ago and have used ham radio, CB, FRS, GMRS, MURS, aircraft and marine radio so I have no particular axe to grind.
Do check with your caravan leader and see what they expect to use CB radio for. If its just assistance with parking or communicating between units when parked, just about anything will do.
If you want to use CB radio for communicating between units on the road (which adds to the fun) then it will pay you to have a good CB installation. I will tell you what I use and am happy with.
The basic technology of CB hasn't changed much in 30 or 40 years so there is not a whole lot of difference between CB radios. I have a Cobra 25 NW which is one of the better ones and can be had for somewhere under $100. It has all the AM communications technology that was state of the art 50 years ago or so, like transmit audio compression and noise blanking on receive. The built-in standing wave ratio (SWR) meter on the Cobra 25 is also handy for checking your antenna on the road.
You can run your radio off of a cigarette lighter socket but like someone earlier, I highly recommend running power and ground wires directly to the battery. The reason is not so much being able to supply the necessary current (legal CB radios take very little power) but rather having the cleanest possible 12 Volts DC. (Modern cars have all kinds of digital stuff putting wideband noise on the 12 V power.)
The most important thing is your antenna, which affects both transmit and receive. A reasonable length (3 foot?) magnetic mount antenna in the middle of the roof as suggested earlier is as good as you can get without drilling holes in your tow vehicle, but a hard-wired antenna is better.
We tow with a pickup with a fiberglass cap, so I mounted a 3-foot fiberglass whip (K40 brand) on the cap and constructed an artificial ground plane out of sticky-back copper tape on the inside of the cap, bonded to the body of the truck at the ends of the tapes, soldered together at all intersections, and with a flexible jumper to the roof of the truck at the front end of the cap. (My 2 meter/70 cm amateur radio antenna is a few feet behind the CB antenna.)
The range you can expect with a rig like this depends entirely on the environment. Going around Chicago with a million truckers on Channel 19 you are lucky to work somebody a mile away. In this case the noise floor of the channel is set by all the other stations using it.
On the other hand, on a Canadian Rockies caravan out in sparsely populated western Canada, we were easily working other caravan units 20 miles away with this setup.
Nuvite-F is offline   Reply With Quote
Old 05-03-2016, 12:22 AM   #13
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
I agree, get a Ham license and be ready for most any radio someone wants to use. (Except the aircraft band)
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 05-03-2016, 05:49 AM   #14
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
Our CB is wired into the "up-lifter" switches on our F350. We only have the CB in the truck when going on a trip. We simply flip the switch off and up plug the radio and good to go. We use a roof mounted whip antenna. A Cobra something purchased at a truck stop and installed by them.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
Old 05-03-2016, 05:55 AM   #15
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Most caravans do use the CB some. Just go to a truck stop and buy one. Get one in the mid price range. I use a fiberglas antenna mounted on the good edge of the front fender. Rarely transmit. But good to hear directions, etc. When not on caravan we take it out. One disadvantage on not geing wireed in is that it changes to channel 9 every time it is restarted.
Old 05-03-2016, 11:26 AM   #16
2012 30' International
Key Largo , Florida
We went on the 2014 WBCCI Alyeska caravan. You will have the same leaders in 2016, JJ and Sandy. The CB is primarily to assist and facilitate the arrival and parking of people as they arrive at the campgrounds with a first call to the parking team from about 2 miles out. People mostly travelled between stops in groups of two or three and as everyone was on the same route you always saw others stopped or had others pass along the way and often people would a little. We know we would unlikely use a CB after the caravan on a regular basis so we bought a handheld Cobra and magnetic mounted roof antenna which, for the most part served the purpose completely. The handheld unit was useful when working as a parker, (which you will do) to communicate with the team to place arrivals in their spots. You will not do this from the comfort of your truck.
Martin R is offline   Reply With Quote
Old 05-03-2016, 12:17 PM   #17
Tyvekcat's Avatar
2014 28' International
Blacksburg , Virginia
Galaxy DX 959
Love the ole' 'silly band' CB radio. I have two I use consistently. I have a Galaxy DX 959 with the Single side band. You can talk a long ways with with the SSB. It's a 'horse' !
Then if you want a good basic CB that will not cost you an arm and leg, Uniden Pro 510 , it is small, has good modulation, and reliable. You can buy these radios at Amazon if you like.
Best thing is, I don't have 'spark plugs' so noise is minimal. That's why they only have diesels at the National Radio astronomy observatory, in Green Bank. ( or at least they use to only have diesel vehicles allowed on the campus). They don't interfere with radio telescopes, but I digress.
I have Velcro on the radio, stick it to the middle seat, run the antenna wire under the seat and rear floor mat, out the bottom of the rear door; underneath the truck and come up between the cab and bed and I use Wilson 'Little Wil' magnet mount antenna, or an Astatic magnet mount on the roof the truck. Great SWR readings and you can talk for miles. ( and I don't use linear amp). I remove the antenna at the campground if I like, and especially if I go into city for an evening. Very easy to remove and throw in back seat.
DW doesn't like trash talkin truckers and I don't either, so I generally turn up the squelch if it gets bad. But I like to listen and especially if there is a backup on the 'superslab' .
I have a older Cobra 25 GTL that is a good old radio. Also have a 23 channel Midland in my office somewhere, awesome radio !
I have a cheapie Radio shack TRC-444 that isn't to bad, modulation is not as high. It's no Midland or Galaxy, that's for sure !
Main thing is to get a good antenna. A good antenna will help a ten dollar radio. a ten dollar antenna will burn up a $400 dollar radio in a new york minute.
I like the Wilson 'Little Wil' mag mounts. Small compact for a antenna. Like
$45 at Loves. You can get the big Wilson or K40, they have good reputations and handles lots of power. I have two Astatic antennas and they have been super awesome. Low swr you can talk all day on them.
Hope that helps,
Have a good one!
Ra & Chelle
For my next trick, I will use my new AS & Dodge Ram CTD to make this pile of money disappear.
Tyvekcat is offline   Reply With Quote
Wally Byam Caravan Club Silvertwinkie WBCCI Forum 57 10-05-2019 09:16 AM
Radio Speakers but no Radio 1969 ???? tdoescher 1965-1969 Sovereign 13 04-21-2015 01:17 PM
cb radio, cassette radio jagcb750 Classic Motorhomes 14 04-19-2012 02:32 PM
Looking for a caravan/mini-caravan from CA to Perry Mac1 WBCCI Forum 3 02-06-2007 05:12 AM
1961 Caravan project new2me General Repair Forum 3 03-19-2003 08:35 PM
