Old 01-23-2011, 10:18 PM   #1
MonaxLisa's Avatar
1975 31' Excella 500
undetermined , Washington
Exclamation California cities...any way around?
Does anyone know of any good routes around all of those huge cities in CA??
I'm just outside of Medford Oregon now and will be heading out on I-5 in the AM.
I so do not want to go through Sacramento.
Any suggestions would be appreciated, (good roads and no snowy/giant passes).
Also and suggestions on how to get to Joshua Tree without going through LA? Ugg!
I would love to spend a few days in Joshua Tree and then head over to Arizona (I think Quartzite was on the agenda)
Bring on the suggestions!!
My AS is 31' long and this is my first trip hauling her (or anything) so good roads are really important, no curvy, windy, scary, narrow roads for me this time.
I can't get onto the forums on my phone, I'll check responses in the morning but if anyone has a tried route that they know is good if you could send me an e-mail I'd appreciate it!(I can check email on my phone)
disturbedxsilence @yahoo.com (without the space)
MonaxLisa is offline   Reply With Quote
Old 01-23-2011, 10:48 PM   #2
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
Stick to I-5. It will take you right past Sacramento. No problems. Straight and flat and very boring.
ddstech is offline   Reply With Quote
Old 01-23-2011, 10:49 PM   #3
1968 28' Ambassador
Ridgecrest , California
Re: California cities...any way around?
You could go US-395 down the east side of CA, which has spectacular scenery. You can cut over on I-80 from Sacramento (though this is Donner Pass). Some passes on US-395, but everything should be clear -- there hasn't been a storm in a while. From US-395, you can head to Joshua Tree either via I-15 to I-10, or via CA-18/247 at Hesperia if you're allergic to Interstates.
Or, you can cruise down I-5 or CA-99 to CA-58 at Bakersfield and cut over Tehachapi Pass (low pass) to catch I-15 or CA-247 at Barstow. This approach avoids LA.
No reason to slog through I-5, particularly in Southern CA if you don't have to!
Maturango is offline   Reply With Quote
Old 01-24-2011, 12:09 AM   #4
batman's Avatar
1964 22' Safari
modesto , California
No worries going through Sac. It is well marked and a kinky straight shot South. Minor madness only, don't panic. I-5 is the easiest route. Go I-5 South to CA-58 East then CA-247 South until it tee-bones into CA-62 go east toward 29 Palms. you will see the signs to the park. This will avoid L.A. and most of that traffic. From Sac. you could take CA-99 South. However there are more towns and cities to go through and that CA-99 seems to have more pot holes and big rigs to deal with. Good luck.
Dennis
batman is offline   Reply With Quote
Old 01-24-2011, 06:56 AM   #5
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
I live in So Cal you can take the 5 south to the 210 east which is a big easy new frwy then take the 15 south to the 10east and continue to Joshua tree..this is the way I go when I go to Palm Desert
LilNomad
LiLNomad is offline   Reply With Quote
Old 01-24-2011, 09:27 AM   #6
Crusty's Avatar
1992 34' Excella
I really like the drive on US395. It's a US highway through scenic terrain and a lot more enjoyable than the freeways though there are sections of it which are relatively remote so pay attention to your fuel levels.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 01-24-2011, 09:38 AM   #7
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Sac is no problem if you go through in non rush hour times.
To avoid L.A. traffic take Hwy. 58 East to the 14 south. Exit on the Pearblossom Hwy 138 and head east. After the town of Pearblossom you'll hit a fork and head left to Victorville and follow the signs to Apple Valley. The Hwy. will end at Hwy 62 in Yucca Valley so turn left and you're in Joshua Tree in 30 min. Though you seem to stay on the same Hwy the number keep changing. So follow the town signs.
When you are ready to head to Q Town. Fuel up and head east on Hwy 62 and when it ends turn right and you'll end up in Desert Center on I 10. Turn east and you are on your way to AZ.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 01-24-2011, 09:42 AM   #8
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Check your maps for scenic Hawthorne, Luning, Tonapah, Goldfield. Skip that CA word.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 01-24-2011, 10:31 AM   #9
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
That's about the only other option, but be careful that route too. You could be surrounded by big rigs all wanting to go 80, and they'll have less lanes to get around you. If you go through L.A. in the late evening or very early morning, the traffic will be a lot lighter and have lots of lanes for the traffic to spread out.
newroswell is offline   Reply With Quote
Old 01-24-2011, 11:35 AM   #10
tpi
Trabuco Canyon , California
I didn't find Sacramento to be any big deal. I went thru in rush hour so it was slow, you may want to time it better.
As for LA if you're nervous about it, go thru on Sat morning about daybreak. I've pulled past the skyscrapers downtown and it was a bit of a "thrill" so to speak, and would definitely go around it if you can. I recommend branching of on the 210 when the 5 dips into San Fernando Valley. Remaining on the 5 all the way south thru LA results in lots of awkward transitions, although on a Sat. morning it shouldn't be too bad.
Sometimes its good to find a truck thats going at your desired speed and looks like through traffic. Match their lane changes to avoid the exit only scenario.
tpi is offline   Reply With Quote
Old 01-24-2011, 11:45 AM   #11
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
Watch for snow
395 in California is a great route but not at this time of year with a trailer......sometimes there is snow and the road can be closed.....south of Mammoth Lakes it is about 8000 feet in elevation. Last July we traveled North on 395 to Susanville, then turned west by Lake Almanor to avoid 80....but the roads were clear of snow.....and it was a wonderful alternative to the I5.
Goin camping's suggestion is a great way to go around LA....happy travels...
Paula
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 01-24-2011, 01:48 PM   #12
Grand Master's Avatar
1963 24' Tradewind
Anderson / Sun City , Indiana / Arizona
When we drove the I-5 around Sacramento last summer it was very washboardy. I had to slow down because of ridges in the road surface.
There were signs everywhere saying that the money Obama was sending would build a new retaining wall. I thought they should resurface the road first.
Mike Brumback
WBCCI #1200
Grand Master is offline   Reply With Quote
Old 01-24-2011, 03:35 PM   #13
2010 27' FB Flying Cloud
Sunriver , Oregon
Medford to California
You didn't mention what you're going to be towing your 31FT'r with, so I'm assuming you have a full size diesel truck.
You'll want to check your road conditions first, but I'd head south on I5 with a short trip to the Seven Feathers RV Resort in Canyonville, OR. Then take I5 to Red Bluff (2 nice parks there) and get off on 99 south. This two lane route allows you to take your time through farms and orchards and the road is pretty good except for some bumpy sections between Sacramento and Stockton. You can take your time.
I grew up in the LA Area but am now in La Quinta, near Palm Springs in the winter and Bend, OR in summers. I like to avoid the LA area just for the sake of avoiding some of the worst drivers in the country. So, continue on 99 south and take 58 to 395 to 15 and come in the back door to Southern California. From 15 take 210 to 10 east to the Joshua Tree area.
Regarding winds. You can have decent winds on any of these highways, but if you have the right tow vehicle and hitch setup it will be a cake walk. We've done 50 MPH desert winds easily.
Hope this helps. Enjoy the back roads but use your iPad, Smart Phone or laptop (with a 3G wireless card) to check the weather and road conditions each day. They even have traffic programs which can save time and hassle.
Bill & Sheri Dettman
2010 Flying Cloud 30
2011 Ford F250 Diesel
ShinyRoad is offline   Reply With Quote
California Silver Sisters Rally in Coloma, California March 25-27, 2011 kristiana Forum Rallies & Meet Ups 47 03-27-2011 03:57 PM
1962 Safari numbers jaclaw Airstream History 5 01-18-2011 07:48 PM
Courtesy parking or rental parking needed, Perris Valley, California skydiva Our Community 1 01-13-2011 06:13 PM
