Old 10-29-2010, 04:02 AM   #1
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
bye bye window
Stopped to get fuel...dw comes running and screming in panic.....window in trailer is gone, gone, gone...checklist ignored...window not latched..whoosh.....airborne
anyone else done this??? Tracked down a dealer, I am in podunk Arkansas and am having one air freighted from Jackson Center...hopefully to arrive today dealer said...you did'nt latch the window...did you???
Baby, it's cold outside......cardboard and makeshift window keeping out cold...and it is not really cold, or raining...thank goodness
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 10-29-2010, 05:29 AM   #2
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
It's really nice to know those windows are still available huh?
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 10-29-2010, 05:38 AM   #3
Islander
yup
thankfully it is a newer unit and many in service...don't want to think what one would have to do if the window was not available at the factory
Kingfisher24
WBCCI 2541
4CU
Old 10-29-2010, 06:35 AM   #4
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
We had one blow out taking the Safari home from the dealer. I discovered it when we stopped 100 miles away and though I didn't scream, I sure was bummed out after spending so much and not even getting it home in one piece.
One of the latches had come loose and opened. It was not adjusted properly and slipped open itself. After some difficult discussions, I got it replaced free. They said it as a window problem (no warranty) and I said it was a latch problem (warranty) that meant it was not adjusted properly at the factory or dealer. They sent me a check and later adjusted the window so it would open and close properly (another problem) when I took the trailer to JC. It still doesn't work perfectly. This would a hard claim to make on a 2 year old trailer. But it is clear—leave a latch open, lose a window. Was it one of the streetside ones over the guacho like ours?
A garbage bag and duct tape solved it temporarily. WD 40 will take off the duct tape glue.
Gene
Old 10-29-2010, 02:43 PM   #5
Islander
window replaced
thanks to airstream of arkansas...their excellent customer service...and i had a window airfreight from JC in less than 24 hours...I installed the new window and wrote new checklist Number 1. SECURE ALL WINDOWS....!!!!!!!!!!!
All's well that ends well
Kingfisher24
WBCCI 2541
4CU
Old 10-29-2010, 11:07 PM   #6
2005 19' Safari
GLENDALE , AZ
Are you guys talking about the smoked plexiglass window cover in the front?
Old 10-30-2010, 01:49 AM   #7
Master of Universe
Gene's Avatar
I'm talking about one of two large windows on the streetside in the main cabin (kitchen, etc.). They open up on a hinge of two C channels. They have no metal rim around them and if the one of two latches is open, they can break easily. I think a passing truck could suck them out and they disappear into hundreds of little pieces (outside, fortunately, when it comes to cleaning inside) as tempered glass does.
Gene
Old 10-30-2010, 03:25 AM   #8
Baltimore , Maryland
Just be glad it was not a Hehr standard from a mid 50's trailer. Jackson Center ain't air freighting you one of those....
Old 10-30-2010, 05:12 AM   #9
Islander
windows
yes one of the large 30x30 smoked windows on the late model safaris on the road side....they can be , if not latched, sucked out into oblivion and graciousily, as far as i know mine did not hit or harm or damage something or someone else in its liftoff except for the monetary damage, it was quite easy to remedy, once the new window was retreived from FedEX...an easy install...even for a dummy like me
Kingfisher24
WBCCI 2541
4CU
Old 10-30-2010, 05:34 AM   #10
it's all a lesson. The only real mistake would be not learning from it.
Old 11-06-2010, 08:43 AM   #11
Ag&Au's Avatar
Port Orchard , Washington
Gene
Why would a "window problem" not be a waranty item?
Ken
Old 11-06-2010, 08:52 AM   #12
AZ-JH's Avatar
Peoria , Arizona
The same thing recently happened to us. When we stopped for fuel we noticed a street-side window over the couch was shattered. I never thought it could have been due to a latch issue though. Thanks!
Janet & Leon
2007.5 Dodge 2500 5.9L Cummins 16+ mpg towing
4CU
AZ-JH is offline   Reply With Quote
Old 11-06-2010, 09:01 AM   #13
warranty
Airstream's warranty policy does not cover abuse, accidents, negligence, acts of God, or misuse.
That, is covered by insurance.
Old 11-06-2010, 01:04 PM   #14
Master of Universe
Gene's Avatar
Glass is specifically excluded by the warranty. However, a loose, maladjusted latch would be the Company's responsibility.
I could also make an argument poor design causes this style of window to be susceptible to damage and the Company is responsible for that. It then becomes a product liability issue and could be asserted after the warranty runs out. You can expect Airstream would not be too receptive to that argument, so what matters is how far you want to go and how you talk to them. A letter to Thor's president helps in that case.
Gene
with a screach and burning rubber, it's bye bye belt !!! kepko Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-06-2008 02:34 PM
Bye-Bye Univolt tamis Electrical - Systems, Generators, Batteries & Solar 14 02-02-2007 06:10 PM
Bye Bye Dinette? Foiled Again Off Topic Forum 13 02-04-2006 07:47 PM
Good bye and thanks Ronnie..... Silvertwinkie Off Topic Forum 8 06-06-2004 05:46 PM
Bye bye Miss American Pie Rog0525 Our Community 4 04-13-2003 10:18 PM
