Old 04-05-2011, 07:50 PM   #1
Retired Fishing Guide
Cap-N-Red's Avatar
2005 28' Classic
Port O'Connor , Republic of Texas
Break away brake cable
How much slack do you have in your break away brake locking cable ?
Cap-N-Red
2005 GMC CC D/A
2005 28' Classic
WBCCI # 3133
Cap-N-Red is offline   Reply With Quote
Old 04-05-2011, 07:57 PM   #2
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Enough to not pull the switch while turning extreme left and right. Make sure it doesn't rub on the ground.
newroswell is offline   Reply With Quote
Old 04-05-2011, 08:31 PM   #3
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
My cable is pretty long and I have to manipulate it around things so that it does not drag on the pavement or be too tight. Come to think of it, my umbilical cord is also too long.
4RXLA is offline   Reply With Quote
Old 04-05-2011, 09:29 PM   #4
1963 19' Globetrotter
Moline , Illinois
I was at the AS dealer today and they were just setting up a display that had a neat little coiled breakaway switch cables (like a phone cord) that you replace the original with. Had two sizes. Don't remember the company name but it looked like a good idea . Maybe someone else has seen these.
63air is offline   Reply With Quote
Old 04-05-2011, 09:37 PM   #5
dznf0g's Avatar
Oswego , Illinois
I'd rather have the "straight" version and connect it to something remote to any of the hitch stuff. ie., I connect a very long break-away tether to the spare tire wheel under the TV. If ANYTHING breaks on the hitch-up, I'm good with a brake apply.
A coiled tether gives no clear indication of break away point.
Old 04-05-2011, 10:04 PM   #6
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Yes, it really does need to be enough for tight turns. As we found out.
Lynn
WBCCI 21043
Old 04-05-2011, 10:07 PM   #7
dznf0g's Avatar
Oswego , Illinois
Lynn
Hmmmm. I see no tether..just a shovel and butts....sup wit dat?
Old 04-05-2011, 10:44 PM   #8
1985 31' Excella
Fresno , Texas
The brake away brake should be installed by the ball coupler close to center line of the hitch. It should be shorter than you have slack in your safety chains. You want the brakes to set on the trailer if you have a trailer tongue uncouple and falling into the cradle of the safety chains. With the cable slightly off to the drivers side of center of the ball you need very little slack to turn either direction. I wrap mine around the 2" solid stock bar behind on the TV side of the Ball until I have taken up slack and clip it back to itself.
Wes
Wsmith is offline   Reply With Quote
Old 04-05-2011, 10:52 PM   #9
4RXLA's Avatar
Images: 33
I do similar to Wes except my receiver shank has a carrying handle bolted on to it. I loosely wrap the cable around that hande once to remove the excess slack.
Old 04-06-2011, 05:23 AM   #10
2011 30' Flying Cloud
Arvada , Colorado
Here you go. Just bought one and it solves the problem of proper length.
Fastway Trailer Products - Fastway Zip Breakaway Cable & Switch
Jack46 is offline   Reply With Quote
Old 04-06-2011, 07:06 AM   #11
dznf0g's Avatar
Oswego , Illinois
Wes
And if your reciever comes loose from the TV? I still say the tether should be attached to something other than the receiver. Yes, close to the center line, and of a length to apply if the coupler falls to the chain "cradle". Although, I don't think it is critical to apply the brakes unless there is a complete separation. I believe you can safely stop the combo if the coupler is in the chain cradle. A brake apply might save some tongue/bumper damage, but the trailer is not going anywhere if you have the chains set up properly.
Old 04-06-2011, 07:20 AM   #12
1986 25' Sovereign
Plant City , Florida
I would think connecting to the TV spare tire could be dangerous. What if it comes loose? I know there are always the "what if" but it seems like something more stable like a bumper or frame bolt or mount might be better.
ck21084 is offline   Reply With Quote
Old 04-06-2011, 07:27 AM   #13
dznf0g's Avatar
Oswego , Illinois
Yeah, I know. Problem is so many modern TVs have nice slick fascias over the bumpers and no place to hook anything to. Sometimes I find someplace on the back of the bumper reinforcement, etc. I use many different tow vehicles. However, if a spare tire hanger, made for heavy truck tires, isn't strong enough to pull the pin, I think I got bigger problems than an emergency brake apply.
Old 04-06-2011, 07:38 AM   #14
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
breakaway cable length
We have friends whose receiver separated entirely from truck -- how's that going to work if the breakaway switch cable is attached to the receiver? Not good. And if the trailer decouples from the ball hitch but remains attached to the tow vehicle via the chains, why "pull the plug" and apply full breaking power to the trailer's wheels? The umbilical cord, still attached, provides proportional control to the trailer's brakes and will allow controlled turning and braking.
This has been covered in the forums before, the one I remember is here
The literature (manufacturers of brakes, switches, controllers, RVs, hitches) doesn't provide a clear answer on any of this. And we are all over the map on the issue. We end up deciding for ourselves our own setup. I'm happy with mine, and am sure you will find one you like too.
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Another Newb Question-Power Cable? jambie 2005 and newer - Bambi all models 1 03-08-2011 09:24 AM
Cable install.. JKnight General Appliance Topics 2 02-23-2011 06:10 PM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
Breakaway cable length? oceantribe Brakes & Brake Controllers 12 01-10-2011 04:18 PM
