Old 10-27-2014, 07:31 PM   #1
2012 25' FB Flying Cloud
Portland , Oregon
Brake shimmy, Tundra pulling 25 ft Fly Cloud
Anybody notice brake shimmy on 2012 4WD Tundra pulling 25 foot Airstream Flying Cloud (7000 lbs loaded) downhill on 6% grade. Using 3rd and 2d gears, brakes stop OK on Tundra but start to shimmy after awhile. Toyota dealer says brakes and rotors work fine. Any feedback from similar users?
Hophead is offline   Reply With Quote
Old 10-27-2014, 07:33 PM   #2
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
It is simply the rotors getting heated up.
My Tundra towing my 30' does that occasionally.
Eventually the rotors will have to be turned or replaced.
I think my rotors overheating was caused by idiots pulling out in front of me and causing me to brake hard to keep from killing them.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-27-2014, 07:56 PM   #3
Goal15's Avatar
Dallas , Texas
How long was that 6 %? I went down one in TN 10 days ago using 3rd with my 2011 Tundra and only had to touch the brakes twice. The tow haul did the rest
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 10-27-2014, 08:25 PM   #4
peetoe's Avatar
2012 25' FB Eddie Bauer
SLC , Utah
I have a 2007 Tundra 4x4 (newer body style) my original brakes did this with a small pop up. Replaced the rotors and have had zero shimmy with a 25' Eddie Bauer. I replaced mine myself with a good pair of high end rotors took a couple hours no big deal.
peetoe is offline   Reply With Quote
Old 10-28-2014, 04:21 AM   #5
2005 19' Safari
GLENDALE , AZ
Some early Tundras had problems with mismatched rotors. See link below to see if your Tundra is affected by this TSB:
Toyota Tundra Brake Shimmy-Vibration Problem TSB | Tundra Headquarters Blog
Old 10-28-2014, 05:39 AM   #6
m.hony's Avatar
2013 30' Classic
I would think mismatched rotors would show themselves sooner, but maybe not-
My truck is a 2007. The shimmy started in 2014. It is a low mileage truck, though. 8 years old with 43,000 miles. All warranty will be gone in December. Hope everything will be alright.
TAC #MS-10
Airforums #70955
Old 10-28-2014, 06:32 AM   #7
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I agree with hot rotors.
2012 Dodge Durango Hemi/AWD
Old 10-28-2014, 06:43 AM   #8
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Sometimes 1st gear is needed. We just spent two weekends in the Smokey's, and I'm amazed how many folks have no concept of downshifting. I think this sign is to blame for most of it.
Most folks see it and think, oh that's for Semi's and doesn't apply to me. I know I'm preaching to the choir on here, but geez. lol
Anyhow, the point being, the slower you're traveling the less you'll have to worry about brake fad on steep grades. Who cares whose behind you.
I can't count the morons flying up my butt riding their brakes while I'm in 2nd going around a corner that suggests 25mph. Then they fly around at 45mph on the brakes the whole time. Do that long enough clown and your brakes might not work.
God you could just smell burnt brakes at every pull off. Come on folks! Ok I'm ranting in general and not talking about you. Sorry for straying.
Hot rotors can and do warp, especially if they're cheap rotors. This is a common problem on car forums where someone bought ebay rotors and they warp after a few months of use. Then rattle the car every time they brake.
Name:	Screen Shot 2014-10-28 at 8.39.12 AM.png
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 10-28-2014, 07:43 AM   #9
dznf0g's Avatar
Oswego , Illinois
Most of the time, pedal pulsation, as opposed to steering wheel shake is due to rotor thickness variation than "warped rotors"
See here: Recognizing Runout And Disc Thickness Variation €“ Tips To Decrease Comebacks - Tomorrows Technician
Roror warping due to heat is really pretty uncommon, unless you REALLY abuse the brakes, as evidenced by blueing of the rotor.
-Rich-
Old 10-28-2014, 08:35 AM   #10
m.hony's Avatar
2013 30' Classic
It only takes one panic stop to overheat the rotors-
TAC #MS-10
Airforums #70955
Old 10-28-2014, 09:48 AM   #11
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
So how does tow haul work for going down long grades vs not using tow/haul?
I haven't had an opportunity to travel any long grades yet. So far my brakes don't shimmy.
Kelvin
Old 10-28-2014, 10:23 AM   #12
m.hony's Avatar
2013 30' Classic
It seems to downshift going down a grade. I don't know how it knows, but it knows- Maybe a mercury switch or altimeter or bubble level?
It uses engine braking when going downhill.
If it doesn't slow down fast enough to suit me I move the selector to "M" manual mode and select a lower gear myself. This is a very rare occasion.
TAC #MS-10
Airforums #70955
Old 10-28-2014, 11:06 AM   #13
2002 34' Classic
Wellington , Ontario
Have a 2007 Tundra with the big V8, pulling a 34 foot Classic. Have travelled all thru Newfoundland (TERRIBLE roads!) and often travel the mountains in Pennsylvania which have gentle grades but run for miles. Never had a shimmy, but always use the Tow Haul option on the dash, and on the downgrade, use the manual gearshift into a lower gear, as the rig tends to gain a lot of momentum. Otherwise the truck runs perfect! Incredible quality! And... I often forget I have the A/S behind me, and tend to get my speed up a bit on the interstates... wife gets mad at my forgetfulness. Also using a Hensely hitch. The hitch is something that has taken me a while to get used to hitching up. After 5 years of lots of use with the Henlsey, I am quite good at hitching up... takes little effort to rig up and be gone. Trust this helps. I think the problem is with the rotors... possibly change them out and also get a second opinion from another mechanic.
LNorthway is offline   Reply With Quote
Old 10-28-2014, 11:14 AM   #14
dznf0g's Avatar
Oswego , Illinois
Part urban legend, and part truth....left over from the 90s when mfrs were so hell bent on reducing unsprung mass that rotors were very thin. I haven't seen, on my job, that issue for a very long time.
Riding the brakes down a hill will warp, but again you will see blued rotors if they were ever hot enough to warp, regardless if panic stop induced or from riding.
Well over 90% of pulsation I see is from thickness variation.
-Rich-
A/C in a 30 fly cloud or international? Howard L. Airstream Lifestyle 18 08-07-2012 07:50 PM
Towing Math Example: Tundra pulling '79 31ft Sovereign Airstream Dad Towing, Tow Vehicles & Hitches 8 10-18-2011 10:17 AM
08 Tundra Brake issues mustang Tow Vehicles 27 08-22-2009 10:48 PM
Replacing AC on my 1959 Fly Cloud apolaroid Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-24-2007 09:47 PM
Rear shimmy in 345? Honkity Hank Classic Motorhomes 3 12-04-2005 07:58 PM
