Old 09-25-2018, 09:38 PM   #1
Mollysdad's Avatar
Both propane tanks open?
Do you leave both valves on the propane tanks open and trust the switchover to work, or do you keep one closed?
Also, in storage for a few weeks, do you turn off the propane tank valves?
Old 09-25-2018, 09:45 PM   #2
McDave's Avatar
2014 23' Flying Cloud
Fair Oaks , California
I leave the valve closed on one propane tank, so I know when one tank is empty. To me that is more important than the automatic switchover. I always turn off both propane tanks when the trailer will be in storage for more than a few days.
McDave is offline   Reply With Quote
Old 09-25-2018, 10:13 PM   #3
2007 27' Safari FB SE
Forest Grove , Oregon
I run with both tanks open, but check them every few days or more as part of my daily maintenance routines. Don't want to run out of gas in the middle of a cold night using the furnace. Partly because I like to run my tanks empty in case I have to fill by the size and not what is needed.
I do shut my tanks off when in storage.
bweybright is offline   Reply With Quote
Old 09-25-2018, 10:17 PM   #4
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Both options make sense.
Relaxing is hard work.
Vantair
2005 25ft International CCD SS
2014 GMC Sierra Denali 1500 4X4 int. 3.43 Int sway/tow controller
1981 Honda Trail CT110 1X0..no sway control
Vantair is offline   Reply With Quote
Old 09-26-2018, 12:34 AM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
I keep both valves open while I'm traveling or staying for an extended time. Never had a problem with the valve not switching automatically. A couple times I forgot to check the gauge and ran out of propane, both tanks, in the middle of the night.
I close both valves while in storage.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 09-26-2018, 04:32 AM   #6
Lakes Region , New Hampshire
One open, one closed. Same in storage, system doesn't leak so I don't need to close both.
"Anyone, who actually fought for it, would know that the freedom we fought for, was so no one could tell us what we have to do." -me
RandyNH is offline   Reply With Quote
Old 09-26-2018, 05:12 AM   #7
AirMiles's Avatar
2017 25' Flying Cloud
Apollo Beach , Florida
I converted my 30# tanks to 20# exchange tanks for weight savings and ease of refilling (exchanges).
I start by opening the valve on only the door-side tank. After about five days, I then open the valve on the second tank and begin checking daily to see when the first tank runs dry. When the first tank runs dry (about once per week), I swing by a Walmart to exchange the empty tank. I then rotate the tanks, so the partially used bottle is on the door side, and repeat this procedure.
In storage, I turn both valves off.
2017 Flying Cloud 25FB (Miles) 234 nights 31,732 miles
400W Solar, 230AH 6V Batteries, PD4655 Converter, Champion DualFuel Generator, ProPride 1400# Hitch, 16" Michelin's
2019 F250, 6.7 Power Stroke, 4x4, 1.5" Leveled (Sully)
Sold: 2013 Casita SD17 89 nights 16,200 miles
AirMiles is online now   Reply With Quote
Old 09-26-2018, 05:25 AM   #8
farafield's Avatar
2018 16' Sport
Charlotte , Vermont
I shut mine off for storage and also in transit.
Don't let the sound of your own wheels drive you crazy...
Kim
Charlotte, VT
2010 F-150, 5.4l, V8, 3.55; Bramble: 2018 Bambi Sport 16
farafield is offline   Reply With Quote
Old 09-26-2018, 05:26 AM   #9
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
I open both, and recently had the indicator show red on both sides, indicating one tank empty while it automatically switched to the other, full tank. Thankful, it was cold that morning, lol.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 09-26-2018, 05:27 AM   #10
r carl's Avatar
Lin , Ne
When exchanging 20# tanks many places have only 15# or 17# in their tanks.
Old 09-26-2018, 05:50 AM   #11
AirMiles's Avatar
Even more weight savings!
Old 09-26-2018, 06:57 AM   #12
1976 31' Sovereign
Oswego , Illinois
Smile
My indicator also shows red both sides when one is empty, then flip to full tank goes green. I leave both tanks open when remove from storage for summer then stay open until fall when goes back into storage for winter. Never had prob. doing this way for many yrs.
Old 09-26-2018, 07:18 AM   #13
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I keep both open for the benefit of continuous flow when one tank empties - trusting the switchover to work which it has for the past 5 years. I was confused by this at first but once I got familiar with it, I really liked the convenience of setting the switch to a tank and not having to worry about when the red indicator pops up. I just know when I see it, Iím running on the other tank, so I flip the switch to that tank and fill the empty one at my next convenience. Rinse, lather, repeat.
In storage (whether weeks or days), I shut both tanks off. The inconvenience there is when you head out on your next trip, it can sometimes take a while to get the fridge going. Probably not a big deal either way, but since Iím not with it when itís in storage, itís one less thing to worry about.
Old 09-26-2018, 07:35 AM   #14
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
I ran out of propane in one tank for the first time in our 2015 while camping a couple of weeks ago. My wife was cooking breakfast and the stove went out. I only had the one tank open so it didn't auto switch. It was no problem to turn on the second tank and manually rotate the switch, and breakfast was saved. I always turn off the propane when I store my trailer.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
Caffeinated is offline   Reply With Quote
Access to drain for both waste tanks PeterD 1981 - 1983 Excella 9 11-09-2015 05:18 AM
Open or not open, that is the question RoadHungry On The Road... 58 06-22-2015 03:47 PM
Electric heater? Propane furnace? Or both? handrew Winter Living 10 11-22-2014 08:29 PM
Replacement of both gray/black water tanks BethNit Waste Systems, Tanks & Totes 2 07-02-2012 08:46 PM
1st time filling both tanks,,,2010 Airstream THEPILL LP Gas, Piping, Tanks & Regulators 32 02-16-2010 03:13 PM
