Old 08-28-2004, 04:11 PM   #1
Boondocking in Missouri
Ok, so it isn't exactly "On the Road"; but the experience is the same.
While building on our land here in southwest Mo., I have been living in our '85 Sovereign 25'. No utilities, no sewer. So not only is this my longest extended period in the Airstream, it is my first try at boonedocking.
Here are some observations, most of which would be applicable to a new Classic 25', as the floorplan and size is largely unchanged:
The large, top hinged windows provide marvelous cross ventilation. Without those and the Fantastic Fan I could not have made it through a few incredibly humid, hot nights.
It continues to amaze me how livable the space is. Living room, kitchen, bathroom, bedroom. Ok, so bathROOM is stretching it. Bath closet, maybe. Even so, it works quite well; especially the shower. I am about ready to take out the headache inducing, largely useless overhead cabinet, though. I note it is no longer used in the newest coaches. I do like the window, though, which is no longer available.
Storage space is beyond belief. And everything is easily to hand. The roll out pantry is a real convenience for full time living.
Those gas refrigerators don't use much gas, do they? Amazing.
Cell phone reception inside is terrific, which surprises me.
I can heat water just once a day, shut off the heater, shower (two showers when my wife stays over), and still have hot water to do the day's dishes.
RidX works great in the black tank. No odors at all, and the tank has been filling for 10 days.
If I can't cook it on the grill or over the gas cooktop on my cast iron pan, I don't need to eat it. NOTE: I have seriously modified my galley area which, in my opinion is about useless in stock configuration. See my photos.
The generator will keep the batteries charged on about 90 minutes a day runtime.
While not a place to ride out a major storm, the Airstream seems exceptionally stable in our summer thunderstorms. I am guessing the same aerodynamics which aid us on the road work in our favor during windy conditions as well.
Problems: Very few. I could use a vestibule in some form as I am parked on a forest floor and tracking-in is a nuisance. And I need several pairs of shoes and boots, all of which tend to be dirty. Where do you put them?
Final observation: In the summer in Missouri, shade is your friend.
Mark
Old 08-28-2004, 04:43 PM   #2
North Central , USA
Mark
We are recently retired and have spent weeks at a time in our 25' Safari with similar accolades for it's 'use-flow' with the 2 of us. I leave wet boots & shoes in the back of my aluminum (Mountain Top (r)) tonneau-covered pick-up, it's not airtight.
About the RidX: How long have you been using it? Is it an enzymatic action solution?? Safe for the tanks??
RivetED is offline   Reply With Quote
Old 08-28-2004, 06:57 PM   #3
RidX is an enzyme. I've always used it when we are set up for more than a couple of days. It is pointless to use for a weekend as it takes that long to get started.
But anything I wear from the truck to the coach will track. I could keep the extra pairs in the truck, though, that would help with floor space.
Mark
Old 08-28-2004, 07:17 PM   #4
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
We bought an outdoor rug - 6'X9' - looks like astroturf - at Home Depot for about $25.
It really helps knocking the stuff off our shoes before entering the trailer.
Dennis
cosmotini is offline   Reply With Quote
Old 08-28-2004, 08:05 PM   #5
LOST , Hawaii
Knock together a 4x4 or 4x6 deck out of some scrap wood. It will give you a place off the ground to scrub your boots off. If you make it big enough to put it back under the trailer you can leave them outside and out of the weather.
John
74Argosy24MH is offline   Reply With Quote
Old 08-28-2004, 08:25 PM   #6
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Just a thought~
The others had some great thoughts on how to keep dirt out..
I go one step further in that, I keep a small trash can by the door and, when I step inside, will put my dirty shoes there. Same with wet shower flippers...
It's low tech but, works for me.
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 08-28-2004, 10:18 PM   #7
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Good one, 53FC!!! That'll keep you from putting your foot in 4 inches of water in your well-isulated boot the following morning. Or worse yet, finding spider bites on your toes the next evening.
bredlo is offline   Reply With Quote
Old 08-29-2004, 01:27 AM   #8
JohnG's Avatar
Almost the same as 53FC's idea. You could use a dish pan. One of those plactic jobs about 12" x 14" and 6" deep and just place your shoes in there and keep it by the door.
Somehow I don't think AS was designed to keep many pairs of shoes by the door. Maybe you could hang then in the magizine rack............
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-29-2004, 05:29 AM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Get a couple of old pallets and put a piece of astro turf over them for instant dirt trap/deck, plus it gets you up out of the mud. We keep a small plastic tub with a cover outside that slides under the AS to keep dirty shoes in. We use a similar system at home...white carpets
Aaron
WBCCI #XXXX AIR #2495
Old 08-29-2004, 06:47 AM   #10
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
another idea,
since i have white carpet in the trailer, i use throw rugs and a boot tray inside just to the right of the door. cheapie from target, 3 or 4 bucks as i recall.
sure makes a big difference when i take the trailer deer hunting. hmmm, if i only had a rack for the rifles.......
john
you call them ferrets, i call them weasels.
Old 08-30-2004, 12:50 PM   #11
Ok, got it, I think. White astro turf next to the rifle in the trash can under the dish pan.
Actually, some good suggestions there. I may be able to "liberate" a pallet, depending upon how well the drivers can count when they pick up the extra materials.
On a related note, the laminate flooring I installed was one of the best ideas I ever had.
Mark
Old 09-09-2004, 09:27 AM   #12
Update:
I have been living the Airstream life for three weeks now, and my initial reactions have changed very little. The shear livability of the limited space available continues to amaze. Some observations.
- Laminate flooring is an absolute godsend.
- As time goes on I appreciate more and more the roominess of the shower.
- How do people survive in coaches with no bathroom counter space?
- Having to stoop to look out of windows gets older every day. The old Vista View windows gave you a chance to see out, at least until they clouded up.
- I knew I liked the Fantastic Fan, but did not know how much until I had to use it every day.
There is progress on the construction, and the utility company set a pole and meter yesterday. As soon as I can get some wiring in I will have electricity! Yahoo!!
Mark
Old 09-11-2004, 01:50 PM   #13
Our Airstream's new home
Work progresses. I plugged in the trailer last night to real utility power, and I can now dump the tanks in the septic system!!!
Here is the new "home" for our Airstream. It will live under the shed roof to the left.
Mark
Old 09-11-2004, 05:47 PM   #14
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
Mark, this looks great! Ours just keeps giving us dirty looks, having to stand outside under the tree branches with all the weather and leaf litter coming down on her. Maybe one day we'll be able to do right by her with a shelter and septic! Is the building for a residence? Shop area? You are building a little slice of heaven down there, I think!
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Missouri State Fair zamboni Forum Rallies & Meet Ups 4 07-14-2007 12:34 PM
New guy in Missouri fogy44 Member Introductions 14 04-13-2007 08:20 AM
Missouri to Montana to Pick her up! 2kids&adog On The Road... 6 08-09-2005 07:35 AM
Bluegrass in Missouri. . . maxandgeorgia Our Community 1 01-15-2005 02:41 PM
Missouri till On The Road... 2 03-25-2004 07:59 PM
