Old 10-18-2009, 03:03 PM   #197
warbler5's Avatar
2004 30' Classic
Roseville , California
Send a message via AIM to warbler5
Originally Posted by ROBERTSUNRUS View Post
Hi, Neil. You might have something there. I thought about a bucket of water with some food floating in the middle to catch the free loader. After I know the coast is clear, I want to make sure they don't have a way to get back in.
Neil got lucky....I think the little guy was just thirsty (before rains).
Combine peanut butter, oats, and chopped walnuts (any nuts will do...walnuts are the cheapest) for bait, and use a snap trap. For back-up, maybe use one of those sticky traps. I keep expecting PETA to start picketing whoever makes those sticky traps....
If you are not finding any "evidence" of mice, I wouldn't continue very long. It could be they weren't hitch-hiking....maybe just lookin' for a free meal!
Cheers, former endangered mouse trapper
2004 30' Airstream Classic
2011 GMC 3500HD Duramax
Hensley Arrow hitch
Jackson Rancheria, 10-12 Oct 2014
Pinnacles Nat'l Park, 20-22 Feb 2015
Casini Ranch, 10-12 Apr 2015
AIR #6287
TAC #CA-26
WBCCI #3933/4CU
warbler5 is offline   Reply With Quote
Old 10-18-2009, 03:34 PM   #198
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Speaking of access for mice. This weekend I put a GFI plug in the bathroom as it had just a standard plug and also ran wiring for an additional plug streetside in the bedroom for a TV soon to be mounted in there. I decided to run another cable outlet too.. So needless to say I had things torn up.. While crawling around everywhere I came across 4 more large holes drilled into the flooring. Some under the water heater and in that area.. The cable wire up through the floor in the bedroom and one more near the wheel well. If you look through you can see daylight. Now I know they figure the belly pan is in place so what could happen.. lol
Alot can happen. It doesnt take houdini to get into that belly pan thats for sure. I did my best to seal off those holes a bit better.
Vin
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 10-18-2009, 04:31 PM   #199
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
I don't know about your trailer Vin, but on ours the 120 v. breaker in the converter assembly for the bathroom has the GFCI feature and that means every receptacle on that branch circuit is protected.
Gene
Old 10-18-2009, 05:03 PM   #200
moderator
Airslide's Avatar
Wilton , California
Images: 50
Gene
Hi Gene,
This 2001 doesnt have and GFI plugs anywhere. I checked high and low.
It looks like Airstream just runs romax through the trailer and strips and clips on these electrical plugs in place. In theory the wiring is not passing through the plug but rather the plug just hangs on to the wiring. I though it would be best to wire in a GFI plug so I dont look like this
Old 10-18-2009, 05:51 PM   #201
Gene's Avatar
'slide, please posts photos when you do plug in like that. I forgot to mention that each successive receptacle in the branch circuit will be protected by the GFCI breaker.
Sometime between 2001 and 2008, Airstream added the GFCI breaker.
Gene
Old 10-18-2009, 07:16 PM   #202
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Maybe he had a concussion from bouncing along the highway and then died of old age.
Look for the mummy next year.
Gene
I installed new axels in May. Maybe the smooth ride caused him to sleep walk into the 'pool'.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 10-18-2009, 10:51 PM   #203
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Mickey Mouse queen bed.
Hi this morning it was in the 60's and overcast; An oportunity to wash my Safari. I must have gone around my trailer four times before I got all the dirt that I missed or wouldn't wash off. Now for Mickey Mouse. I can't find him. All the traps are untouched, even the little pieces of cheese puffs are still on the sticky traps. Nothing for him to drink either. I found two more little droppings today so I still think he was a very little mouse and by himself. My wife noticed when I have the storage compartment light on, the queen bed glowed. I found no evidence in the storage compartment, but for future protection from varments and weather I decided to seal off the bed. This is an area that, I feel Airstream let me down. I think a relatively new Airstream should be mouse proof, But we know now for a fact that it isn't.
(1.) A few years back, I noticed between the bed and the night stand, I could see my water heater's styrofoam. I closed that off with 1"X2" Oak.
(2.) Hard to see in this picture, but at the head of the bed on each side of the aluminum strip, there was room to stick your fingers in. I closed them off with plastic channeling.
(3.) Where the bed meets the wall [should] and the convolute for the tail lights run, Airstream left about a 2" freeway into my storage compartment.
(4.) From the inside of the above bed corner, Airstream used a precission chain saw to cut this board.
(5.) Inside of bed with home made filler board installed. I made a small round hole in the corner to fit tightly around the wire loom.
(6.) This shows the outside view of the permament freeway closure.
Name:	IMG_1289 (Large).JPG
ID:	89315   Click image for larger version
Name:	IMG_1292 (Large).JPG
Name:	IMG_1284 (Large).JPG
ID:	89317   Click image for larger version
Name:	IMG_1285 (Large).JPG
Name:	IMG_1287 (Large).JPG
ID:	89320   Click image for larger version
Name:	IMG_1288 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-21-2009, 09:32 PM   #204
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
You mentioned the high cost of the heated water hose earlier in this thread. One thing you can do is to go to the big box hardware store (which ever is closest) and buy the water line heater that you install on your house's plumbing to keep it from freezing. Wrap the heater tape along the length of the water hose, including over the hose bib, and then add some water pipe insulation, again including the hose bib, and plug it in at the electrical post in one of the 20 amp outlets. This should cost below $50 and be as effective.
Family of Disney Fanatics
WBCCI# 4821
Old 10-21-2009, 09:42 PM   #205
Gene's Avatar
If you go the heat tape route, two things to remember: (1) don't wrap it over itself—it burns it out, and (2), the stuff they were selling 20 years ago doesn't last more than a few years; maybe it's improved.
Gene
Old 10-21-2009, 11:22 PM   #206
J&C
J&C's Avatar
2002 31' Classic
Hillsboro , Texas
Images: 11
Bob, Lately I haven't been spending much time on the Forums, it seems that the older I get, the busier life seems to be. I started reading at the beginning of your travel-adventure and spend almost two hours reading the whole thing and boy was it fun! Thanks for sharing it with me.
Who does most of the Driving while your towing? JB
J&C is offline   Reply With Quote
Old 10-21-2009, 11:34 PM   #207
Salem , Oregon
Images: 18
Hi, John. Glad you enjoyed our trip or trips. I do all the driving while towing and my wife handles the directions. She handled the Garmin, Woodalls, and AAA paper maps. I take care of the mechanic's of the trailer and all outside work and my wife handles all of the inside work.
2005 Safari 25-B
Old 10-22-2009, 11:30 PM   #208
tksbaskets's Avatar
2007 25' Safari FB SE
Dexer , Michigan
Sounds like you are a great team! Hopefully the hubby and I will be a fine tuned team after a bit more experience. Thanks for sharing,
TK
tksbaskets is offline   Reply With Quote
Old 10-22-2009, 11:54 PM   #209
Salem , Oregon
Images: 18
TK
Hi, we're a team at home too; What ever it is, or needs to be done, we just do it.
2005 Safari 25-B
Old 02-24-2010, 01:13 AM   #210
Salem , Oregon
Images: 18
Anniversary coming soon.
Hi, our anniversary is coming very soon and we are getting out of town. We had several ideas on places to go and what to do. This sort-of makes this another random trip. Our final decision is Las Vegas, Nevada. We have been there several times on one nighters, in hotels, but this time it will be for four nights and in our Airstream Safari. We don't drink or gamble, but there are lots of other things of enjoyment to see and do there. Hopefully I will be able to document our trip and post some pictures.
2005 Safari 25-B
How dusty is your vintage trailer? Stefrobrts General Interior Topics 32 11-17-2004 09:42 PM
