Old 08-30-2015, 04:52 PM   #1
demijac
2014 27' FB Classic
Livingston , Texas
Send a message via Skype™ to demijac
Black Tank Handle Problem
Have a few questions about an issue we are experiencing with our black tank handle. First some background, then our questions:
After the last blank tank clean and rinse, we could not push the black tank handle back into position to seal off the black tank. The result is leakage - first the leakage accumulates behind the closed sewer hose connection and then, we think, when it has nowhere else to go, it finds a way to leak onto the ground. When we get to a new campsite and open the sewer connection to hook up the sewer slinky, black water comes pouring out and during the day, it seems we are leaving liquid on the ground which we think is from the black tank.
Here are our questions:
1) what caused the problem?
2) can it be prevented?
3) is there a fix we should try on our own before taking it in to a dealer to
fix?
Thanks for the help!
demijac is offline   Reply With Quote
Old 08-30-2015, 04:58 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Something is blocking closure of the flap. Time to put on your gloves and get dirty. Reach up inside the valve and wipe it out. It does not take much accumulation to block complete closure. I had an issue with this right after buying my trailer. A marble sized chunk of unknown material was blocking the flap.
MICHAEL
Old 09-02-2015, 11:33 AM   #3
gpt
2014 25' FB Flying Cloud
sequim , Washington
FWIW, a good friend who has been a travel trailer person for about 35 years and counting told me, '...no paper in the black tank...'. combine that with the idea that most of us use way too much paper, and you have a recipe for problems. i have a stick on hook with a plastic bag for paper disposal, emptied daily, no issue to date with valves. another of his suggestions, 'trick', is to not empty the black water tank until they have moved to the next days spot. that allows for plenty of sloshing time to stir things up and dissolve the solids.
gpt is offline   Reply With Quote
Old 09-02-2015, 11:39 AM   #4
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I've been a travel trailer person for 40 years and am here to tell you paper is fine in the toilet. Use water when you flush - which you need anyway as you pointed out - and it'll be fine.
Also, it's probably not paper blocking the valve.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 09-02-2015, 11:50 AM   #5
Ravenna , Ohio
Rather than trying to reach inside and clearing the obstruction you might want to do the better job of taking the valve apart to ensure the seals are not damaged.
You didn't mention the age of the valve assy but they aren't too expensive as only $16 at Amazon and are easy to replace.
1. Dump and flush the tank and lines a few times.
2. With everything empty unbolt the valve (4 small nuts & bolts.
3. Remove old valve and inspect the rubber seal.
4. Get new seals or a complete new valve which has new seals.
5 put it all back together
Throw away the rubber gloves you wore and clean your tools is a bleach water bath and you should be good to go.
I would estimate 30 min or less once the tank is flushed out.
Tireman9 is offline   Reply With Quote
Old 09-02-2015, 12:04 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
Can the OP easily get to the valve? I just replaced both valves on my 1995. I had to cut a hole in the belly pan.
CRH is offline   Reply With Quote
Old 09-02-2015, 01:37 PM   #7
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
As fir water pouring out when you remove the drain cap, in my experience, this can happen even if your valves are closing properly.
It dependents on the slope that the trailer is on when you dump it and one campground versus the corresponding slope at the next.
I think it is possible to have wastewater still ling in the plumbing after the valves depending on the slope of the trailer, (side to side). If the next campsite has more of a slope, the accumulated waste can then exit whenyou remove the cap.
To deal with this, I have put a third easily attached valve right at the exit (where the cap normally goes. I then put the cap on after that valve
You can get these twist on/off valves at Camping World or other places.
I close this "third valve" at campsite A before removing the stinky slinky, then don't pen it again until I have reconnected the slinky at campsite B !
I guess it could be a bonus also if one of your main valves suddenly will not close properly.
The thing that worry about most is a black tank valve that I cannot open becsuse the handle has just pulled out of the valve blade!
I dread the day that happens and wonder how to deal with it!
I suppose one way would be to call a septic tank outfit and see if they could pump the tank out via the toilet.
I don't know why Arstream in their wisdom make these valves so inaccessible - at least on my mode trailer.
If I was facd with the problem of a handle that had pulled out, I guess I would cut an access hole in they belly pan and then see if I could manage to grab the valve blade end with vice grips or something to pull it open. Might have to cut away park of the valve housing to get a grip onto the blade.
Hope I never have to find out!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 09-02-2015, 02:20 PM   #8
2002 19' Bambi
Lafayette , California
Several years ago we had a similar problem: valve would not close and the black tank leaked. In addition, the tank would not empty properly.
It turned out our valve was blocked by the plastic disk that had been cut out of the tank to attach the drain pipe. That disk had been in there for years!
The manager at the RV park said he and his wife had experienced the same problem in both a trailer and a fifth-wheel which they had owned. Neither was an Airstream.
Tim
Tim A. is offline   Reply With Quote
Old 09-03-2015, 01:25 PM   #9
1989 25' Excella
Albemarle , North Carolina
leaking black tank
Get an extension (twist on) this should solve your problem
eldin is offline   Reply With Quote
Old 09-03-2015, 02:38 PM   #10
1991 34' Limited
Tucson , Arizona
On our '91 Limited the ability to close the valve has been a problem twice. My father, from whom I inherited the trailer, treated the seals several times with suggested solvents and cleaners, which helped for a time, but eventually the black water valve was reluctant to seal completely.
Shortly after he passed in 2005 my mother requested that the valve be replaced. $600 later a new valve was installed on site by a reputable RV company in Show Low, Arizona, where the trailer was parked for the summer. The replacement required cutting an access panel and the black water valve was removed by cutting it out. We were told ahead of time that this was the only way to do the job on our trailer - and that 'alien' RVs often had a better system that could be more easily be removed.
Ten years passed before the same problem occurred.
Last year I had a wonderful handyman that works on all sorts of RVs suggest that I replace it with one of the newer styles where the valve seals could be replaced without cutting out the old ones. The valve assembly, including grey water valve and new handles, was only about $35. Total cost for parts and installation was just under $200. The handyman said that solids tend to build up along the seals and that unless they are cleaned religiously before shutting down for the winter we were likely to experience the same problem again in the future. The problem is exacerbated by the minerals in the water in Arizona. He suggested that when he comes to winterize that we remind him to use his special pressure washer adapter to clean the black water tank and valve.
BTW - toilet paper has never seen the inside of this tank. Mom and Dad forbade it, and I'm following suit with my friends and family. We keep a box of sandwich bags under the sink and encourage everyone to use two. Trash is dumped daily.
Hikingsolo is offline   Reply With Quote
Old 09-03-2015, 02:52 PM   #11
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
Danger, Will Robinson!
"Only dull people are brilliant at breakfast" - Oscar Wilde
2500HD DMax............30' Classic
Sky is offline   Reply With Quote
Old 09-03-2015, 03:18 PM   #12
CRH
1995 25' Excella
xxxxx , xxxxxx
If you own a trailer long enough, those valves are gonna need serviced no matter what ritual you follow using them. My 1995's original valves lasted 20 years. Matter of fact, I think they were still good, but the plastic tank adapters had cracked with age... I pulled out the big Airstream 3 ring binder...Right in it, it said Airstreams way of replacing the valves was too cut a hole in the belly pan. This past Monday I replaced both valves, both tank adapters, and all the PVC. It cost me 167 bucks and wasn't a complicated job.
Old 09-04-2015, 06:59 AM   #13
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
We've trailered since 1971, always used paper, and at times had five of us in the entourage, and never had a problem with paper messing up the shut off valve. We keep the valve shut until the black water tank is full, or we are ready to pull out. We arrange to have the grey water tank full just before a dump. When we dump the black water, I pour 2-3 five gallon buckets of clean water down the throat of the toilet after the tank has drained and this helps clear any paper that lagged behind. I fill them in the shower, so they are right there. We close the black water valve gate and then dump the grey water which helps get the nasties out of the slinky as well. And we use regular home TP designed for septic systems. Yes even after 44 years I guess the paper could give us a problem, but I will deal with it when it does. So far, it hasn't.
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Black Tank Handle Problem demijac Waste Systems, Tanks & Totes 0 08-24-2015 08:41 PM
T-Handle on black water tank Broke. Emh142 Waste Systems, Tanks & Totes 9 08-08-2015 06:36 AM
T-Handle on Black Water Tank won't lock in place RichP21 Waste Systems, Tanks & Totes 8 07-11-2015 08:14 AM
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Black tank handle Bing-Bing Waste Systems, Tanks & Totes 16 03-27-2014 01:51 AM
