Old 02-05-2016, 08:59 PM   #1
Suzbp's Avatar
2013 25' Flying Cloud
Longwood , Florida
Bike rack permanent or not?
Just recently bought our first AS and looking for advice on a bike rack. Don't have room to carry bikes in truck bed but wondering about having one attached to AS. Any disadvantages? Can we still access all storage compartments with a bike rack on AS? Appreciate advice from your experience.
Suzanne
Suzbp is offline   Reply With Quote
Old 02-05-2016, 09:51 PM   #2
Adiredneck's Avatar
2014 27' FB Classic
Vicksburg , Mississippi
I think that there is only one approved one for a rear-mount, on an A/S; but I'll let those that know comment on that. Another option, if your TV is a P/U, is mounting a front hitch receiver; there are a number of hitch mounted bike racks.
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
Adiredneck is offline   Reply With Quote
Old 02-05-2016, 09:55 PM   #3
aftermath's Avatar
Spokane , Washington
I have one and it works just fine for us. It is permanent and still allows access to our rear compartment. I suppose you could remove it and use some screws to fill the holes. This thing works great, is solid and doesn't damage the trailer.
aftermath is offline   Reply With Quote
Old 02-05-2016, 10:06 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Discussed earlier today . . .
http://www.airforums.com/forums/f368...ml#post1745326
Doug and Cheryl
Old 02-05-2016, 11:22 PM   #5
2015 28' International
Ofallon , Missouri
Had the Fiama on my 25', liked it so have it on my 28' now. You can still open the rear door, but the rack makes it a little harder to get things in and out if you have the model with the rear stowage compartment.
mpsgolf is offline   Reply With Quote
Old 02-06-2016, 10:59 AM   #6
1998 28' Excella
Little Rock , Arkansas
Aftermath, Which one do you have? The one I saw didn't look like it would work with the rear bumper compartment
Gillpine is offline   Reply With Quote
Old 02-06-2016, 11:01 AM   #7
2012 30' International
Livingston , Texas
Bike rack issues
We used our AS Carry-Bike for the first time last summer and we're thinking of ditching it this summer. On the plus side, it carries the bikes securely with really nice straps. On the minus side, accessing the trunk storage is difficult. The access door does hit the bike rack when opening. Our bikes (Townies) fit very well but the support arm is not at the right angle to hug the center bar real well. Also, the handle bar grip is really close to the rear window glass. As it bobbles around, it actually hits the glass so I put a tennis ball on the end of the grip to help cushion the glass tapping. One more thing; in my AS, the rear window is an emergency escape and it is impossible to open that window far enough if you had to get out. Besides that, it is OK. You have to remember that the back of the trailer does a lot of bouncing and I used pipe insulation to cushion any contact between bikes and the carrier.
glenrms is offline   Reply With Quote
Old 02-06-2016, 11:04 AM   #8
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
I was lucky to have a FRAME-mounted (never a bumper-mounted!) receiver on my AS. So I have successfully used a slide-in bike rack for the past 5 years. Problem is, there is no good place such as a rack or hook or other protuberance on the back of an AS to secure a rope to stabilize those bikes a little more. But as far as the primary concern (damage to the AS)...there has been none. jon
B00merang is offline   Reply With Quote
Old 02-06-2016, 12:24 PM   #9
N Barrington , Illinois
It is important to use shock cords to secure the bikes. Also use a cord between the tires to keep the wheels from spinning, and causing unusual wear on the bicycle axels/bearings.
Banker is offline   Reply With Quote
Old 02-06-2016, 12:32 PM   #10
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Interesting!
When we bought our AS (used) it had a welded 2" receiver on the back.
I was gong to use it with a back rack (Not sure what the PO used it for) but in the end I cut it off the frame because I read to many negative comments on this forum!
Possibly the comments related to older trailers though. I don't think there has been damage to ours from whatever the PO used it for.
In any event, I decided to carry our bikes on the front of the truck as O had done with other trucks and other trailers before. Works fine for us.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 02-06-2016, 02:50 PM   #11
Suzbp's Avatar
Longwood , Florida
Thank you everyone for your input. We are moving forward with our bike rack install. Glad to hear storage access is not compromised.
Suzanne
Old 02-06-2016, 03:51 PM   #12
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
We purchased an Arvika rack from Canadian company Arvika. It is visible on our avatar, mounts in front behind the tanks. Put on +/- 5,000 miles last fall with it and no problems. I'm not a whiz on uploading pics but will try (probably show upside down!). If they don't show, send me your email at jrgrimes@flash.net and I'll email the pics. Very happy with this unit.
Name:	bike rack 1.JPG
ID:	256906   Click image for larger version
Name:	bike rack 2.JPG
banderabob is offline   Reply With Quote
Old 02-06-2016, 04:55 PM   #13
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Is that Fiama easy to use, as my back ain't what it use to be?
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 02-06-2016, 05:27 PM   #14
aftermath's Avatar
Gillpine,
I have the one that fits my 25FB. I don't think there are different models.
As far as access goes, the rack itself creates a minor problem but when the bikes are in place it gets really bad. I keep my electric umbilical and my water hoses back there. I don't need to get at these unless I am setting up. By that time the bikes come off anyway.
I looked into all the options mentioned here and this one best fits us.
Bike Friday / Swift Folder / Airnimal folding bike? 85MH325 Off Topic Forum 47 09-26-2008 06:21 AM
Bike rack on a Suburbban Les Gilliam Our Community 2 04-06-2003 07:25 PM
bike rack mount on rear of AS trailer rmmm68 Repairing/Replacing Floor &/or Frame 7 11-26-2002 10:55 AM
Bike Rack ALANSD Our Community 3 03-19-2002 10:57 AM
