Old 03-25-2016, 11:33 AM   #57
2016 25' International
Los Angeles , California
Banderabob, thanks for posting those pictures. The Arvika rack looks like a great solution. They make a rack specifically designed to fit an AS coach. Went onto their website to see the installation demo. I especially like the idea of not compromising the skin of the coach (as is necessary with the Fiamma rack), and not hindering access to the rear compartment.
Bdinla is offline   Reply With Quote
Old 03-26-2016, 08:37 AM   #58
BoscoMN's Avatar
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount , Minnesota
I did read on another thread where someone had taken their Fiamma bike rack off of their smaller Airstream and placed it onto their new, larger Airstream. They noted that the top bracket that attached to the rear side of the older Airstream had loose screws where they only went into the skin and not the frame member. When they installed it onto the new Airstream they used rivets on the inside holes of the bracket. So each bracket had 2 screws on the outside holes that went into frame and skin and 2 rivets on the inside holes that went into only the skin.
BoscoMN is offline   Reply With Quote
Old 03-31-2016, 10:49 AM   #59
bullet661's Avatar
2014 30' FB FC Bunk
Fresno , California
Front mount
We bought a front mount hitch from thehitchstore.com The bikes bounce a bit so I usually stop once during the trip to tighten the bike rack. Visibility might be an issue for some. My wife says she can't see but it doesn't bother me.
It takes a big man to cry....it takes an even bigger man to laugh at that man.
bullet661 is offline   Reply With Quote
Old 03-31-2016, 11:41 AM   #60
interstateflyer's Avatar
2017 25' International
Los Osos , California
Originally Posted by bullet661 View Post
Attachment 259711
I would check with the CHP to see if that obstructed vision might cause one of their officers to cite you. Would be a a shame to have to deal with that mid-trip.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 03-31-2016, 11:48 AM   #61
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Yeah, that might be pushing it. You need to see well on the road.
Doug and Cheryl
Old 04-01-2016, 02:52 PM   #62
bullet661's Avatar
2014 30' FB FC Bunk
Fresno , California
Yea you're probably right. I'm going to look for a lower profile rack.
Luckily for me during the 5 or 6 trips I've taken with the bikes on the front, the only law enforcement I encountered were more interested in fighting crime than ruining someones vacation.
Old 07-20-2016, 08:34 AM   #63
bullet661's Avatar
2014 30' FB FC Bunk
Fresno , California
Lower rack
This rack is lower, solid and easier to use. It's called a "Kuat". They are really expensive but I'd rather spend the money than drill holes in my Airstream.
Old 07-20-2016, 09:03 AM   #64
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I carry bikes the same way and have for the last 18 years or so - likely close to 100,000 miles without problems.
I already had a standard hitch mount carrier, but when used on the front of our 2500HD, truck it put the bikes way too high.
I just cut the vertical tube of the carrier down and re-welded it to suit.
As it is now, I don't have a whole lot of clearance between the road and the bottom of the bike wheels - but enough, never any contact!
The seats /handlebars are barely visible above the line of the hood. Just enough for me to see them so I can be constantly sure that our bikes remain properly secure, which I like.
In that regard, on our last trip south we saw a fifth wheel pulling onto the interstate with bikes on the back of the RV. One bike had come loose at one end, and was dragging along the road! Lots of folks flashing lights & blowing horns, but the driver seemed oblivious and carried on!
No perfect solution I guess, each method has pros and cons - pay your money and take your choice!
I will admit that on some trips our bikes up front get rather dirty, but they are just old beaters anyway so not a real big deal for us.
I would imagine that with turbulence at the back of the trailer, bikes carried back there would get pretty dirty also in inclement weather.
Many years ago I used to carry a 90cc Honda Passport scooter in the aisle of a
20 ft SOB.
It worked ok, but required a lot of securing and foam rubber to avoid damage to the interior! Never did cause any damage - but was a pain if we wanted to use the trailer en route.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Bike Friday / Swift Folder / Airnimal folding bike? 85MH325 Off Topic Forum 47 09-26-2008 06:21 AM
Bike rack on a Suburbban Les Gilliam Our Community 2 04-06-2003 07:25 PM
bike rack mount on rear of AS trailer rmmm68 Repairing/Replacing Floor &/or Frame 7 11-26-2002 10:55 AM
Bike Rack ALANSD Our Community 3 03-19-2002 10:57 AM
