Old 05-23-2016, 08:29 PM   #1
Mcwey's Avatar
2008 30' Classic
Fort Collins , Colorado
Bike Rack
My Wife (Best thing that ever happened to me) Says she is tired of putting
our bikes in the Airstream!! Any one know of a good rack, other than the
Airstream, ($$$$$$$) that works and will attach to the back or other???
Monty
Mcwey is offline   Reply With Quote
Old 05-24-2016, 05:42 AM   #2
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
I keep thinking that adding a 2" hitch received under the back bumper would make sense. Then you could add any commercial bike rack you wish. I've seen some post regarding this idea.
However, I have not done this myself but am considering doing so. The if's and how's and pros and cons are yet to be deliberated thoroughly, so it may or may not happen. I'm just throwing out the idea!
Old 05-24-2016, 06:18 AM   #3
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
We use this one. Rides up front, above the propane bottles. If you order, I'd call them, give them your trailer and they will send the correct one. We've used it on a 25' and now our second 30', works fine. Only in the way of the front window opening and if propane is needed both bikes need to come off. Other than that, simple, easy and secure to use. When bikes don't go, just two base tubes remain in place on the front A frame. I thought long and hard about the 2" receiver on the rear and the 35 plus year experienced mechanics at what was Airstream of Western PA said "not a very good idea". So, we opted for what we have.
http://www.arvika.ca/index.php/us/
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 05-24-2016, 07:22 AM   #4
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
The bikes racks aren't inexpensive, and having the bikes on the outside means they are exposed to weather, bugs, potential theft, etc., but even that will matter to a more or lesser degree depending on your situation. After considering all the options - rack on back or front of trailer, bikes on or in the truck, or carrying them inside the trailer, I ended up making a simple fork mount rack that allows me to carry our bikes inside the trailer, while still allowing access to the kitchen, bathroom, beds and dinette if we are making a short or quick overnight stop. It only takes a couple minutes to put them in or take them out of the trailer.
SeaLevel is online now   Reply With Quote
Old 05-24-2016, 08:34 AM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We carry our bikes with the rear mount Airstream rack, terrific. However if you have a rear access hatch you may consider the rack Can-Am Airstream in Ontario assembles from various factory parts. It can released at the upper brackets to drop down for rear hatch access.
Doug and Cheryl
Old 05-24-2016, 09:09 AM   #6
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
This is a terrible idea which has been discussed to death on the Forums. I'm not going to rehash the reasons here, just use the "search function " and see for yourself.
Bob Martel
WBCCI# 5766
Old 05-24-2016, 09:41 AM   #7
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . we are considering that rig from Can-Am that Doug mentioned. It's not cheap but you can access the rear 'trunk' by swinging it away. Looks like I can probably install myself.. . . regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 05-24-2016, 09:45 AM   #8
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I use the Arvika. With the exchange rates you should be able to get a better price than I did when I ordered in 2013.
Some tips on use:
I found the straps that go around the tire rims would come loose due to the bikes moving in the wheel channels due to road travel. The fix is to use a velco strap around one of the brake handles of each bike to keep the bike from moving. I also use a Velcro strap around each rim too.
If your tow vehicle is an SUV or a pick up with a camper shell be careful of turning to sharp, otherwise the bikes may contact the back corners of the vehicle. The longest trip I took with my bikes was from Missouri to Utah and back. No issues with the bikes on the rack using the Velcro straps as described.
The weight of the rack and bikes will add some tongue weight.
The Fiamma rear bumper rack looked to complicated to install with the Classic bumper and pull out tray. The bikes obscure the license plate and the rear lights somewhat.
The Arvika can be installed in about an hour. I didn't have to move any LP lines.
http://www.airforums.com/forums/f516...ml#post1339473
Kelvin
Old 05-24-2016, 10:09 AM   #9
Hans627's Avatar
Thanks for the input. If it's not a good idea then it's not a good idea. I'll do a search.
Again thanks!
Old 05-24-2016, 11:31 AM   #10
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Front Hitch on TV
I have now used a front hitch and a Hollywood brand dual rack from my local bike store on two separate trucks. On my F-150 the bikes were too high and headlights reflected back in my eyes at night. So we tried mounting them in the trailer. I bought an inexpensive home two-bike rack from Amazon. It was a small version of the commercial ones you see around in parks, etc. just a base and two loops for the tires to go in. I put it at the center nightstand and put a couple of pad eyes under the foot of the twin beds and used a ratchet strap. That works when you are not stopping for the night, but got cumbersome with overnight stops.
I looked at my new TV, a Ram 2500 and decided to give the front mount another try, since I already had the bike rack. It works really well on the larger truck. The cost of the two is probably only about $100 cheaper than the Airstream rack, but I already had the bike rack, and it gives you the flexibility to take the bikes away from the trailer.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-29-2016, 07:47 AM   #11
nickclifford's Avatar
1972 31' Sovereign
felton , California
We put our bikes in the truck flatbed with front wheels over the tailgate using a Yakima pad .
nickclifford is offline   Reply With Quote
Old 05-29-2016, 05:11 PM   #12
We just bought this bike rack for use in our truck bed. It'll give us the capability of carrying our bikes and the gear we take along with us on trips.
StrmyWeather is offline   Reply With Quote
Old 04-25-2018, 11:00 AM   #13
lynnsoltys's Avatar
2017 23' Flying Cloud
Hiawassee , Georgia
How’s that working out for you?
lynnsoltys is offline   Reply With Quote
Bike Friday / Swift Folder / Airnimal folding bike? 85MH325 Off Topic Forum 47 09-26-2008 06:21 AM
Bike rack on a Suburbban Les Gilliam Our Community 2 04-06-2003 07:25 PM
bike rack mount on rear of AS trailer rmmm68 Repairing/Replacing Floor &/or Frame 7 11-26-2002 10:55 AM
Bike Rack ALANSD Our Community 3 03-19-2002 10:57 AM
