09-01-2017, 06:38 PM
2019 27' International
1964 17' Bambi II
Ogden
, Utah
Best portable tire inflator
We have a 2017 25' FC TFB, we are interested in punching the best brand tire inflator on the market. Any suggestions? Thank you!
09-01-2017, 07:01 PM
ObviouslyKnot
KAILUA
, HI
The VIAIR 450 is pretty good for me.
https://www.amazon.com/Viair-Automat...keywords=viair
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
09-01-2017, 07:14 PM
Biloxi
, Mississippi
Tricky question "best". Unless someone has tried every brand and model available it is frankly an impossible question to answer. I can tell you what have and carry. Both are from Harbor Freight. A small D.C. powered one and a 120 volt 3 gallon pancake. I have only used the D.C. one a couple of times. Sort of slugish and slow but does the job. The AC powered one is much more effective. When boondocking I can plug it into the inverter in my Jeep or any available AC power source.
MICHAEL
09-01-2017, 07:43 PM
2014 30' International
Ellicott City
, Maryland
Originally Posted by james.mileur
I second the VIAIR 450. I own one and it has worked really well.
09-02-2017, 09:35 AM
2017 19' Flying Cloud
Madison
, Wisconsin
ditto, nice unit!
09-02-2017, 09:39 AM
Mike from Canmore
2018 27' Flying Cloud
Calgary
, Alberta
I use a Motomaster 12V/120V pump that works great, plugged into either a 12V receptacle, or a home 120V outlet (two cords). It has a digital readout- you set the pressure you want, and it stops automatically when it reaches the desired pressure. Good range of pressure, too. My trailer tires require 80 psi, and it handles it with no problem.
The 120V cord is ridiculously short, so an extension cord is required.
09-02-2017, 10:02 AM
Something Shiny
2017 27' International
Mosinee
, Wisconsin
I've the Vlair 450P-RV. Not inexpensive, but the quality and function exceeded my expectations. With 2 hoses, it will reach to the back of the longest Airstream. The connection componentry will address all needs (including the spare tire without having to remove it). I find myself using this unit at home instead lieu of my large compressor.
Mark & Gina
2017 International 27FB
700W Solar roof mount + 160W Zamp portable = 860A
ProPride hitch, 1400#
2018 Ford F250 Platinum 6.7L Diesel
09-02-2017, 10:09 AM
2012 25' Flying Cloud
Berlin
, Maryland
I agree the Vair RV is very good and I also recommend that you invest a very good digital tire inflator that you can use in place of the one that comes with the VAIR. I recently purchased the Astro 3018 Digital Tire Inflator with Stainless Steel Braided Hose. It is not inexpensive however I definitely like it better then all of the others I own.
09-02-2017, 10:22 AM
2019 30' International
Pennsylvania
, Pennsylvania
We have the vair 88p. It's a nice little compressor for 60 bucks.
I also use an awesome bicycle hand pump, some of the better ones can pump air pretty darn good. I use it all the time to top off the tires.
09-02-2017, 10:33 AM
2023 25' Flying Cloud
Anchorage
, Alaska
Kobalt Multi-Purpose inflator
I use the Kobalt 12-volt/120 volt Multi-purpose Car Sport Air inflator. It has worked well for me.
09-02-2017, 10:51 AM
2013 25' FB Eddie Bauer
Bonita Springs
Hello
I've had good results with this one from Lowe's
Kobalt 12-Volt Car Air Inflator
http://low.es/2pZa3bm
'13 Eddie Bauer 25'
sold
09-02-2017, 11:15 AM
Tampa
I just bought the Viair 400-RV. I choose the 400 over the 450 because although the 450 can run continuously, it doesn't provide as much air. I can't see inflating tires on an AS taking over 20 minutes. Meanwhile the RV package included a second hose and another air chuck.
I ordered through WalMart, because they beat Amazon on that day by a lot.
09-02-2017, 11:23 AM
2014 30' Flying Cloud
Tampa
Well, I'm going to break tradition and recommend the Ryobi inflator.
https://www.ryobitools.com/products/...power-inflator
It's the Home Depot cordless brand. And I got a great deal on two hi capacity lion batteries, and I now have a leaf blower, orbital wax machine, and flashlight.
I've used the inflator several times already, interestingly enough on my TV only, since my Airstream tires haven't needed it yet.
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
09-02-2017, 11:55 AM
2013 28' Flying Cloud
Penn Yan
, New York
I use the Kobalt dual voltage (12/120) portable air compressor from Lowe's. I think it was around $50 and works well. I would recommend purchasing the extra 1 yr warranty which was around $5.
09-02-2017, 12:29 PM
Tampa
That's the best advantage. Once you have one you don't need it. It's Karma.
09-02-2017, 01:27 PM
2015 30' Classic
Pleasanton
I started with the Kobalt, but it quit after a few hours. I've now had a Viair 450 for a couple of years and used it many times to top up. Highly recommended!
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
09-02-2017, 04:44 PM
2015 30' Classic
Saint Augustine
tire inflator
Ditto on the "Kobalt"
09-02-2017, 11:15 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
If you have AC available, either shore power or inverter, a small AC Campbell that does the job for me with 80 psi tires would work. It has a regulator that can be set for any desired pressure you will need. An AC/DC model would be more versatile. I have 110v outlets on both sides of my trailer and a large battery bank for the inverter. You could install DC sockets on both side near the tires if you only have DC.
guskmg
09-05-2017, 09:50 AM
demijac
2014 27' FB Classic
Livingston
PSX3 Power Station
We use a portable battery jump starter/high volume tire inflator. We like it because it is multi-purpose, rechargeable, portable and easily stowed in the forward exterior storage compartment. We mainly use it to keep both our truck and trailer tires at the right pressures. We can inflate anywhere without the need for shore power. We only need to recharge every couple of months or so.
Occassionally, we use the Power Station as an emergency power storage, e.g. left trailer parked under a tree (which blocked solar panels) for ten days and electric jack was without power. It could also be used to jump start our truck if necessary.
Bought it at Costco for around $80 a couple of years ago. One of our best Airstream accessory purposes and ranks just behind the heated mattress pad.
