09-05-2017, 10:29 AM
#21
2017 19' International
Tallahassee
I use the Ryobi.
I'm sure it's not "the best," but it does a fine job topping up the tires and ... it fits in my toolbox.
09-12-2017, 09:56 PM
#22
2014 27' FB Classic
Cambridge
, New York
I've used the Viair 450 for a couple of years with good results. But I also bought the following air tank:
http://www.jegs.com/i/JEGS-Performan...81001/10002/-1
I modified the tank by installing a shutoff valve and standard quick connect. I also bought a good professional-grade Milton chuck with built-in pressure meter (and an Accu-Gage as a double check), and a 6' Goodyear air hose.
This way, I can fill the tank to 100psi from the Viair at the front of my pickup with the compressor attached to the batteries (truck running, as recommended by Viair) and carry the light tank, hose and chuck to the tire I'm filling. With a 27 foot trailer hitched to a 23 foot truck, it is a *lot* easier than trying to muck around getting the compressor to each tire! Also have a big commercial-grade compressor at home to blow out water system for winterization - but the Viair and tank are my road solution.
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
10-19-2017, 06:45 PM
#23
2017 25' Flying Cloud
Dallas
Does anyone carry a pancake compressor? You can run of the trailer inverter or my truck has a factory inverter. This would give enough volume to run an impact if needed. I’ve been kicking this idea around or getting a viair onboard setup installed on my truck. We have a very similar trailer and tow a lot at high speed so tire pressure is very important.
2017 25FB Flying Cloud
2022 Ford F-350 Platinum FX4
"Life is a team sport"
11-04-2017, 10:31 PM
#24
1994 34' Limited
Salem
, Oregon
well i cannot say what is best. but we carry a small campbel housefeld twin tank air compressor. i like it a lot, when in camp just plug it into any TT outlet. I always fill the tank before we hit the road for emergency but we also have a generator in the back of the truck for emergencies.
11-04-2017, 10:57 PM
#25
South East
, Michigan
Just another vote for Viair. Does the job for me.
Al
2017 29' SOB, 2022 Platinum F-150 SCrew, ProPride
11-05-2017, 07:48 PM
#26
2014 27' Flying Cloud
Rancho Cordova
If money is no object I would get an Oasis XD3000. That's one serious compressor. Probably a little overkill just to inflate trailer tires.
11-05-2017, 10:04 PM
#27
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
We have a 2000i....so, Black & Decker AC....since our first AS in 1988, $45
Never had to use it for a flat tire....but often for the water toys & tire loading adjustments.
11-06-2017, 04:36 AM
#28
Sneedville
, Tennessee
Ditto on the 88P, quiet, fast and has a pretty long airhose. Clips to the battery. Doesn't take up a lot of room. Wish it had a storage bag though.
http://amzn.to/2zB46Jp
11-06-2017, 07:13 AM
#29
2010 25' FB Flying Cloud
Davenport
, Iowa
I bought the Viair P 90 from Amazon. Used it yesterday and did car tires in 15 minutes; one tire 10 lbs low and rest 3 lbs. Now all 35. I also used on A$ and did well as I used 75 lbs, but dealer said to inflate to 85. Michelins suggestions.
Power cord could be 5 ft longer; difficult to reach rear tire opposite battery location.
11-16-2017, 04:24 PM
#30
2018 30' International
cary
, North Carolina
Ok new question re compressor. After listening to lots of folks I think I’ll go with winterizing using rv antifreeze products (there has been good input about what kind to get , thanks everyone) as I look at gett
In a tire inflator (compressor) I’ve noticed that the less expensive ones that would work only have about a 16 ft reach. I will be driving a f150 and I have factory installed solar panels. The dealer says I get different batteries. So my question is “ what compressor/inflator connects to the battery (not cigarette plug) and can reach all the way to the middle of a 30 footer The ones I e seen so far have a 8 ft battery hook up cables and a 16 ft air hose. That seems to not be long enough and I don’t think access to the new solar batteries will be easy to get to? Just so you all know I don’t get the trailer until early December
11-16-2017, 05:55 PM
#31
Dallas
gbradleync
If your cable or hose isn't long enough you could,
A) use the batteries mounted on the front of your trailer. Even if you have 6volt batteries, they will still equal 12v.
B) turn the truck around where the hood is nearest the area you're working in
C) buy a longer hose or add a quick connection so you can carry extra hose
11-16-2017, 05:57 PM
#32
Bartlett
I use this little compressor to air up my Jeep Wrangler tires after off road trips. It will compete well with the Viair models at a much lower price. It connects to the battery terminals not the 12V socket. I know of no little compressor that has enough cord to make it around a 30 Ft trailer.
https://www.amazon.com/Industries-MV.../dp/B000BM8RT8
11-16-2017, 07:43 PM
#33
Davenport
, Iowa
I was going to use the trailer batteries until I read the instructions. Instructions: connect compressor to truck battery with engine running.
11-16-2017, 08:36 PM
#34
Rancho Cordova
The other option other than an air compressor is a CO2 tank.
I have a ViAir with a 2 gallon tank installed in my Jeep, I am not really all that impressed with how long it takes to "air up" my 33" tall tires after a wheeling trip... and I only fill those up to 32psi.
Now I have a requirement for my tires to be filled to 80psi in my RAM 2500 (and the trailer tires). I am looking into a CO2 tank system. Does anyone out there have any experience in this arena?
11-19-2017, 09:09 PM
#35
2014 27' FB Classic
Cambridge
, New York
I use my ViAir with a portable tank. Fill it to 100psi and carry it to the TT or TV tires that need a top off. I also use it to fill my Airsafe hitch. The tank comes with what you need, but I added a shutoff valve and quick-connect, so I can use my 6' standard air hose and Milton chuck with built in gauge. Still like the combo after 3 years. Here's the tank I got:
http://www.jegs.com/i/JEGS/555/81001...SABEgLaUvD_BwE
11-20-2017, 08:00 PM
#36
2007 28' International CCD
Springfield
, Missouri
Best portable tire inflator
I have a Stanley purchased at SamS Club $59 it has auto pressure shut off which is handy for winterizing.Led light,usb charging and is a jumper box which is useful when transferring water from 12 gallon containers running a auxiliary water pump to fill water tank when boondocking not to mention jump starting the occasional dead battery.
11-23-2017, 01:41 PM
#37
1973 Argosy 24
Kitchener
, Ontario
I am a scuba diver and I have an adapter that mates a scuba tank with an air hose. I can run impact wrenches and fill tires with it.
12-23-2017, 06:49 AM
#38
2019 25' Flying Cloud
2018 23' Flying Cloud
Ocala
, FL
Originally Posted by Bluestar99
Same here, I used this in my off-roading days. Works great for topping off 80 psi tires. The power cable and hose length give you enough to reach the tires. Fits nicely in the included storage bag. I also have a pancake compressor, but don't take that on the road with me.
