Old 05-03-2016, 12:28 PM   #15
2014 Interstate Ext. Coach
fairfax station , va
Diner smell
Kind of on topic
Since I have an Interstate without external storage. I'm concerned about odor.
The O-grill has a carry case.
Should a moderately clean grate and a carry case solve the smell problem?
VAtom is offline   Reply With Quote
Old 05-03-2016, 01:30 PM   #16
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Napoleon?
I'm leaning towards this one. http://www.amazon.com/dp/B00LA0Z5QS/...RN4DP7PI&psc=1
SilverHoot is offline   Reply With Quote
Old 05-03-2016, 01:49 PM   #17
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We use the Weber Q1200 with the fold-up stand, works great. So does every other brand/style that is "best" for any particular camper at any particular time. Ask them and you will see . . . everyone has their own "best" and good reasons why.
Doug and Cheryl
Old 05-03-2016, 02:04 PM   #18
JJ1
2009 23' International
Redondo Beach , California
This may not be exactly what your looking for, but the results are incredible. I use a Green Mountain "Davey Crockett" plellet grill. It's based on 12v power, legs fold up into a carry handle, temps range from 180-500 degrees, had a digital temp control that can put out its own wifi to control the grill with your phone.
Uses wood pellets for fuel, so if used low 180-220 you smoking and if higher at say 300-500 it's more akin to a wood burning oven.
Could be worth a look.
Cheers
JJ1 is offline   Reply With Quote
Old 05-03-2016, 02:52 PM   #19
millertimeUS's Avatar
1976 25' Tradewind
Second on the davy Crockett, never burn your food again and real wood smoke flavor all day long!
76 'Airstream Tradewind
Matt
millertimeUS is offline   Reply With Quote
Old 05-03-2016, 04:06 PM   #20
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by minddr View Post
I have been researching portable gas grills and would be interested to hear of those of you who are experienced with any of them. I am leaning towards the Weber Q1200. Probably won't be cooking for more than 4 at a time and it seems very compact.
Thanks for asking.
In the 10 years since the old thread was started, the grill market has changed, and Airstream has started putting low-pressure propane outlets on trailers from the factory.
I added a low-pressure port to mine, and use a Magma grill, with which I am well pleased. It is much more convenient and reliable to use the low-pressure port than to use the various alternatives: disposable 1-pound cylinders, Ting off the high pressure connector at the cylinders on the tongue, carrying another big cylinder, or using solid fuel.
Old 05-03-2016, 06:26 PM   #21
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Originally Posted by Jammer View Post
Thanks for asking.
Sorry if this is off topic but your reply made me think of 3 questions:
1) is the Magma anything like the Volcano (which can run on propane, wood or charcoal)? If so, think that could be my next grill option - we use it with charcoal but it would be fun to try on propane which I haven't yet...
2) I think the LP port (which I recently had installed) is already low pressure so are you saying it wouldn't work with the Weber Q1000 (since the 1lb tanks connect PRE-regulator and therefore the quick disconnect hose from the already regulated LP port would connect in from of the regulator)?
3) what's the longest hose I could expect to use from that LP quick disconnect port? It comes with a 4 or 5' hose but as you know, they install it street side but all your camping is done curbside so I think a 20-25' hose would let you bring the grill to where we would normally use it. But I wonder if there is some distance after which propane doesn't like to flow....
Thanks!!
Old 05-04-2016, 07:42 AM   #22
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
I use a Coleman stove/BBQ combo that does a good job.
I almost never use the stove burner tho, but got the item because of the aluminum grill. Great heat distribution.
I got fed up with those "goofy' little one pound fuel cans that cost 5 bucks in Canada; and then you have to discard them.
So I bought a 5 pound tank that cost about 5 dollars to refill. Had to refill it last year, first time in four years.
That. Four year usage paid for the cost of the tank.
MelGoddard is offline   Reply With Quote
Old 05-04-2016, 08:59 AM   #23
mcomeaux's Avatar
2016 27' Flying Cloud
Sunriver , Oregon
Gas connection
I have a 2016 AS and has the gas port will the Q1200 connect to it?
mcomeaux is offline   Reply With Quote
Old 05-05-2016, 08:33 AM   #24
1998 28' Excella
Little Rock , Arkansas
We bought a Napoleon portable grill because we have the larger model at our house. We like it because it is fully warranted. You can get worn out replacement parts anytime with just paying shipping. Very sturdy (a little heavy, I guess, but not too bad) and works well.
Gillpine is offline   Reply With Quote
Old 05-05-2016, 09:00 AM   #25
Tincampers's Avatar
Sneedville , Tennessee
Ditto on the Volcano Grill, very versatile and very compact. Been using it for a year now. The storage bag gave up the ghost awhile back after being shredded by the handle for the vents. Otherwise, good stove.
Tincampers is offline   Reply With Quote
Old 05-05-2016, 11:48 AM   #26
mcomeaux's Avatar
Sunriver , Oregon
Propane connection
Will these portable stoves connect to the propane port in front of coach?
The dealer insisted I buy their unit for compatibility. Any suggestions?
Old 05-05-2016, 01:02 PM   #27
Tincampers's Avatar
Any stove that uses low pressure LP can be connected to the LP port.
Old 05-08-2016, 08:15 PM   #28
mcomeaux's Avatar
Sunriver , Oregon
I've made up my mind to buy the Weber Q1200 I have the Port on the front of the coach.
Will it require an extra hose for length to run it on the right side of coach in front? I found a Weber on Amazon that I will be purchasing but unsure of hose? Any Help would be appreciated I'm heading out on road soon. Regards Mike C.
Best Portable Grill? Tin Hut Stella's Kitchen 718 11-05-2017 06:05 PM
External Gas Grill Teton Stream LP Gas, Piping, Tanks & Regulators 10 07-23-2017 12:38 PM
LP Quick Connect for Gas Grill Mod-Streamer LP Gas, Piping, Tanks & Regulators 13 06-10-2015 05:20 PM
What is the very best portable gas grill out there? Eaglemate Airstream Lifestyle 15 11-18-2011 12:29 PM
Portable Kitchen - the ideal AS Charcoal Grill tarheel1972 Full-Timing 25 08-03-2011 04:41 AM
