Old 11-07-2006, 07:40 PM   #15
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
As far as "bad" years, the '97-99 had some automatic transmission problems, but nothing of consequence for the engine. When they get over 300,000 miles, they may develop a head gasket coolant leak on the right bank at the rear of the engine. This can be avoided, or at least delayed a long time, by idling the engine for a couple of minutes after driving, before shutdown, keeps things from expanding and stretching the head bolts. But is anybody going to run their PSD over 300K towing?
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 11-07-2006, 07:41 PM   #16
_
hi streamer1
there is more to the truck than just the diesel right?
and what about the cost of new vs used?
2002 the last year of the 7.3 would be a fine truck.
if the cps has been changed the truck should perform for many many miles.
of course the warranty is gone and 6 years of proper service records is important...
the bugs seem to be gone in the 6.0 liters from 05 and 06.
these trucks also have improved steering and a much tighter turning circle.
05/06 also has the built in brake controllers, and HIGHER towing capacity.
also bigger, better brakes on the 05/06s.
i've got 30k+ miles towing on the 05 without issues. one recall and one leaky glow plug.
a plus for the later models is 100k power train warranty and on 06s 100k basic warranty i think...
should be some great deals on 06s still on the lot....lots of 'em too.
cheers
2air'
Old 11-07-2006, 08:38 PM   #17
nilesrob's Avatar
Marietta , Georgia
Images: 12
My experience is Excursion related, but basically the same thing. I've had two Excursions, a 2001 with the 7.3 liter and our current 2004 with the 6 liter engine, currently with close to 70,000 miles and about to add another 5,000 in the next few weeks.
While I did have an issue with the 6 liter engine (about 400 miles into it), it has worked flawlessly since. Given the choice, I'd take the 6 liter - it is every bit as powerful (I'm towing 10,000 pounds with our 34' w/SO), and it is quieter than the 7.3 liter engine.
In addition, at least in my 2004, Ford added the towing button on the shift stick that makes traveling SO much nicer and safer - particularly on grades, as it downshifts automatically and thus reduces some braking.
The one complaint I have, and I understand it was improved in later models, is the steering radius. On our 2004 Excursion (also our 2001) every parking job is a three point turn, which is interesting because the Expedition has a remarkably good steering radius. Anyway, I think this may have been improved in 2005 and later models.
Good hunting!
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 11-07-2006, 09:38 PM   #18
AZstreamin's Avatar
2005 30' Safari
Chandler , Arizona
Streamer1..
I'd echo BeBop and 2air comments on the preference for '05 '06 on the PSD. IMO the used value difference between the '03 to '05 is moderate compared to the gains you will receive in the '05 and up
brake controller- great feature
larger brakes- not much to say here
turning radius- huge advantage. CC u-turn with Short bed.. 2-2.25 lanes..
back up sensors- if you live in the urban jungle this is a must! It also has benefits when hitching.
I bought my '05 last July....until now, every vehicle I've ever purchased has been slightly used and still under mfg. warranty. Vehicles take a pretty good depreciation hit rolling off the lot. But trucks particularly diesel trucks hold their value. So I looked at the features that I really wanted because the price difference between a 03 and 05 is negligible when spread out over time if you buy and hold, like many diesel truck owners do. Before you buy, drive several and compare the features and buy what you really want.
AZstreamin
"Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did do. So throw off the bowlines, sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."- Mark Twain
AZstreamin is offline   Reply With Quote
Old 11-07-2006, 10:06 PM   #19
TIMEMACHINE's Avatar
Huntington Beach , California
me too
One more vote for the 05 and 06 F250 PSD for the reasons previously stated in earlier posts. I prefer the long bed because of the additional 1 1/2 feet and the larger fuel tank (38 gallon in the long bed vs 29 gallon in the short bed). The front end suspension on these later Super Duties are huge improvements. I think 2air is right about the great deals out there on the remaining 06s.
John
TIMEMACHINE is offline   Reply With Quote
Old 11-07-2006, 11:11 PM   #20
1971 31' Sovereign
Cleveland , Tennessee
I own a 97 and a 01 f250 7.3L I believe they are the best. I prefer stick shift when towing but I Tow car trailers and agricultural equipment on a freguent basis. I think the 96 and 97 models are the most simple and best, but lack allot in ride quality and availabilty and lack of intercooler.
The 99 year model used a smaller turbo which I do not see well suited for a intercooled truck so I would avoid it.
The 01 and later were the first with the higher cc injectors and correct programing which I think works best in the 7.3 motor.
I think if I had to go with a 6.0 it would have to be a 05 or 06. Lot of problems with earlier models in towing situations.
I think any one towing should have a Exhaust Gas Temperature gauge you need to let the oil in the turbo cool to under 275 or so before turning of the motor. After running full tilt on the interstate it may take ten ten fifteeen minutes. Also owners need to add a cavitation additive to the coolant on a regular basis you can check this with ph strips. Like a previous post I think everyone should care a spare CPS Cam position sensor they are notorious for going out.
The Ford truck enthusiast website is a great resource for information if you want to know more.
Just as a side note to the overlander63. My first 7.3 powerstroke in a 96 model had 465,000 miles before we retired it and it was far from worn out. The 97 I have now has 190,000 miles and is highly modified, and the 01 is at 160,000 with no repaires other than CPS. The majority of these miles were all hooked to a trailer of some kind.
I would be best to search about a proper breakin on diesels if bought new. Most aren't considered broke it until around 25,000 miles.
Smuzz is offline   Reply With Quote
Old 11-07-2006, 11:15 PM   #21
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, same with any used vehicle, the newer one you can afford because newer usually means less miles. Less miles used is more miles for you to enjoy. Although my Navigator was three years old when we bought it, it only had 16,800 miles on it and came with a six year / seventy five thousand mile warranty. Now my six years have passed, [warranty expired] but I only have 40,000 miles on it now. Navigator and Airstream ready for Bob's retirement early next year.
Old 11-07-2006, 11:40 PM   #22
Hippo's Avatar
Battle Ground , Washington
I pull my 25ft tradewind with a 2002 F-250 4x4 v-10 crewcab shortbox all the time. It is a good truck made in the USA.
Hippo is offline   Reply With Quote
Old 11-08-2006, 04:54 AM   #23
2001 30' Excella
Crestview , Florida
We have a 2000 Airstream Excella 30' that we have towed with a 2003 Ford F250 for the last three years and it has done everything we expected it could do. There have been minimal recalls, but when there were, it was a simple in and out at the dealership. It pulls the 30 footer just great. You know it's back there, but that's about it, very smooth towing. We have both the 30' and the F250 for sale. Please see the link below! We are considering an Airstream motorhome. Thanks.
http://www.airforums.com/class...ct=2800&cat=16
eunasuniques is offline   Reply With Quote
Old 11-08-2006, 05:50 AM   #24
2007 25' International CCD
Arlington , Virginia
Originally Posted by BeBop
2003 7.3L PSTD (automatic) / Lariat / Crew Cab / Long Bed
I have owned mine for 2 years. Purchased used w/37k miles. So far it has been flawless.
See comments regarding 6.0L in the following link:
http://www.gooddiesels.com/UEQUAL.HTM
Thanks for the link BeBop. And the diesel search continues...
Streamer1 is offline   Reply With Quote
Old 11-08-2006, 06:30 AM   #25
ctdair's Avatar
I would go with the 7.3 over any 6.0 , I have the Dodge and like the Cummins beter but at work we have 7.3 and early to brand new 6.0 and the 7.3 is a much better engine in our work scene , it is not a towing situation but the 7.3 starts better idles better feels stronger altho I dont have the numbers to back it up it just has the feeling of more available power over the entire rpm range.
If I could get a King Ranch superduty with a Cummins I'd buy 2
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2010 Dodge 2500 Diesel 4x4 Megacab
ctdair is offline   Reply With Quote
Old 11-08-2006, 07:05 AM   #26
1971 31' Sovereign
Joseph , Oregon
We have 2000 PS Crewcab and it has 170000 miles on it and is running better all the time. It has pulled alot of stock trailers and other trailers and runs well. We have a manual (6 speed) which we prefere hauling anything heavy. If you look at the newer PS the automatics have gotten alot better 05-06 models.
Larry and Nicole
trea is offline   Reply With Quote
Old 11-08-2006, 07:20 AM   #27
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
on a similiar note, do most PSD owners tow with the overdrive off? Or just while in traffic? I have heard that turning it off spare the heat related trans issues.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-08-2006, 08:01 AM   #28
1971 31' Sovereign
Joseph , Oregon
Not being an automatic owner but knowing a little about alot. My under standing is when towing you should have the overdrive off, even when not towing if in town it should also be off. One thing that is of help with folks that have automatics, a transmition temp guage is highly recomended. The last thing you would want to do is over heat your trans.
Larry and Nicole
Late Model Vehicle Tow Ratings Andy R Tow Vehicles 2 07-20-2008 06:11 PM
year wood veneer changed to laminate? thx yukonsilver Interior Restoration Forum 4 04-18-2004 05:31 PM
Happy New Year! PeterH-Airstreamer Our Community 2 01-01-2003 12:47 AM
MH manufacturering Model years zamboni Airstream Motorhome Forums 3 06-19-2002 07:00 AM
